Question about Tascam DP-02 Digital Portastudio Regular 886830313974
Reverse ,ffwd and shift buttons dont work on dpo2 portastudio
The buttonns wont respond ..have had to press harder and harder as time went on ,,now there is no reponse
Touch screen wont work how to fix or unlock
Same Problem... You have to ReCalibrate it... But its harder then it sounds... EXPECIALLY if you dont have a remote like me...
Mar 02, 2013 | Clarion VZ401 Car Video Player
When i record and try to play back i get nothing dpo2 . 2 tracks armed. i stop rewind and play and theres nothing , headphones can be heard when recording
Very likely the over-write head does no longer function properly. Try again with a MD that already has recordings on it, try to record another track to it. If the entire disc seem blank after TOC was written, the OW head is bad. At this point the unit effectively becomes a player only....
Mar 10, 2010 | Tascam Audio Players & Recorders
How do I set the clock on my Kenwood kdc-2025 cd player?
Press [MENU] for at least 1 second. *MENU* is displayed. Press [FM] or [AM] button to select menu item (CLK ADJ). Press RWND or FFWD button for at least 2 seconds. The clock display blinks. Adjust the hours. Press [FM] or [AM] button. Adjust the minutes. Press the RWND or FFWD button. Press [MENU] button to exit adjustment mode. Reference page 20 in this link to your Kenwood KDC-2035 Operating Instructions.
http://www.kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/KDC-MP225.pdf
Dec 27, 2009 | Kenwood KDC-2025 CD Player
My 20002 mustang v6 its automatic
To shift from "P" to "R", there is a swicth that allows the shift button on the shift lever to be depressed. For this switch to work, the ingnition switch must be "ON" and the brake pedal depressed. If all yor brake lights went out (or if your brake switch on the pedal fails to work), then the shift switch wont work and you can not shift out of "P".
Jan 26, 2009 | 2002 Ford Mustang
Tascam dpo2 not burning a cd
You need to create a master first before you can burn it to a CD.
To create a master you'll need to set an 'OUT' point, then enter mastering mode (by pressing the master key so that it flashes) and then record your master by holding record and pressing play. The master recording stops automatically when it reaches the out point (the in point is always zero). The steps for creating a master are outlined on page 27 of the manual. Setting the in and out points can be found on page 30 and burning the master to CD is on page 67.
Hope this helps.
Cheers.
bd.
Dec 20, 2008 | Tascam DP01 All-In-One Recording Package...
Need codes to control symphonic 27" tv using rca universal remote control type rcr312w
  1. These instructions come from the RCA website. The crucial step is to keep pressing the reverse button.
  2. Turn on the component (the tv, dvd, etc).
  3. Hold the TV (or DVD) button and the on/off button at the same time. It will stay lit.
  4. Press the play button every five seconds until the component turns off.
    • Each time the Play button is pressed, the illuminated ON-OFF button blinks ten times and a block of 10 codes is sent to your component. This process continues until all the codes in the Code Lists have been searched. If the component has not turned off after all codes have been searched, the illuminated ON-OFF button blinks four times, turns off, and the Auto Code Search Entry method is exited.
  5. When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again.
  6. If the component does not respond, continue to press the REVERSE button EVERY TWO SECONDS UNTIL THE COMPONENT TURNS ON again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE button is pressed, the illuminated ON-OFF button blinks.
    • If the REVERSE button is accidentally pressed after the component responds, press and release the FORWARD button. Wait two seconds to see if the component turns off again.
  7. To save the new code, press and release the STOP button.
  8. The illuminated ON-OFF button turns off. You must press the STOP button to save the code.
Tips
  • Turn on TV
  • Hold in the TV button and the ON/OFF button until the ON/OFF button stays lit
  • Press the PLAY button every 5 seconds until the device turns off
  • Press the REVERSE button every 2 seconds until the device turns on
  • Press the STOP button to lock in the code...the remote should work now.
  • Important to press reverse button every 2 seconds, not just once.
Good Luck!!
Aug 18, 2008 | Televison & Video
RCA remote help
I GOT THIS FROM THE RCA WEBSITE...IT WORKED FOR ME...THE CRUCIAL STEP IS TO KEEP PRESSING THE REVERSE BUTTON!!! MY REMOTE WAS THE RCA RCR312W
  1. TURN ON THE COMPONENT (THE TV, DVD, ETC)
  2. HOLD THE TV (OR DVD) BUTTON AND THE ON/OFF BUTTON AT THE SAME TIME.  IT WILL STAY LIT.
  3. PRESS THE PLAY BUTTON EVERY FIVE SECONDS until the component turns off.
  4. Each time the Play button is pressed, the illuminated ON-OFF button blinks ten times and a block of 10 codes is sent to your component. This process continues until all the codes in the Code Lists have been searched. If the component has not turned off after all codes have been searched, the illuminated ON-OFF button blinks four times, turns off, and the Auto Code Search Entry method is exited.
  6. If the component does not respond, continue to press the REVERSE button EVERY TWO SECONDS until the component turns on again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE button is pressed, the illuminated ON-OFF button blinks.
  7. If the REVERSE button is accidentally pressed after the component responds, press and release the FORWARD button. Wait two seconds to see if the component turns off again.
  8. To save the new code, press and release the STOP button.
  9. The illuminated ON-OFF button turns off. You must press the STOP button to save the code.
Jul 01, 2008 | RCA RCR311B Remote Control
RCA universal remote
This is the eastest way to program your remote. To program a component using the Automatic Code Search method, perform the following steps: 1. Turn on the component you want the remote control to operate. 2. Press and release the component button that corresponds to the component you want the remote control to operate. info.gif The illuminated ON-OFF button turns on and remains on.
aud_remote_on-off.gif 3. Press and hold both the component and ON-OFF buttons. info.gif The illuminated ON-OFF button turns off. 4. After the illuminated ON-OFF button turns back on, release both buttons. info.gif The illuminated ON-OFF button remains on. If you press an invalid button during Auto Code Search, the illuminated ON-OFF button blinks four times and turns off. The last programmed code under that component button is retained. 5. Press and release the PLAY button. aud_remote_play.gif 6. If, after five seconds, the component does not respond, continue to press the PLAY button every five seconds until the component turns off. info.gif Each time the PLAY button is pressed, the illuminated ON-OFF button blinks ten times while a block of 10 codes is sent to your component. This process continues until all of the codes in the Code Lists have been searched. If the component has not turned off after all codes have been searched, the illuminated ON-OFF button blinks four times, turns off, and the Auto Code Search Entry method is exited. 7. When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again. info.gif If the component does not respond, continue to press the REVERSE button every two seconds until the component turns on again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE button is pressed, the illuminated ON-OFF button blinks. aud_remote_reverse.gif info.gif If the REVERSE button is accidentally pressed after the component responds, press and release the FORWARD button. Wait two seconds to see if the component turns off again. 8. To save the new code, when the illuminated ON-OFF button turns off, press and release the STOP button. aud_remote_stop.gif info.gif If some of the features of your component do not work, different codes in the list can be tried until you find the code that allows the remote to control the majority of your component’s
Aug 28, 2007 | RCA RCR450 Remote Control
Tascam DP-02 Digital Portastudio Regular 886830313974 Logo
Top Tascam Computers & Internet Experts
Ben Armstrong
Electric Dime
Electric Dime
Chris Larocque
Are you a Tascam Computer and Internet Expert? Answer questions, earn points and help others
