Question about Recordex Studiojet 50 Cd/dvd Auto Printer
Studio jet 50 only prints on the top and bottom of the disc
The cds are printed with the image on the top and bottom and there is an empty area straight through the center of the disc where the image is faded. I tried to use the automatic cleaner and it doesn't seem to work
I need the pdl_common disc
not required for any disc.....you need to download latest drivers for win xp from hp web site if you need download link pls send me one request mail to me...satyan476@gmail.com
Mar 21, 2014 | Hewlett Packard Printing & Imaging Hewlett...
Canon pixma mg5320
Their software is not the only game in town - try some other software
Sep 06, 2017 | Office Equipment & Supplies
DVD RW Drive not reading images from discs
if those come from pro studios, it's possible that they might be DRM protected. Call them and ask that simple question
May 22, 2012 | Toshiba Computers & Internet
Lines on print. There's are three lines on picture print only. Can't see the line on document. It's about 1/4 inch wide and going throught top to bottom.
Have ou gone into your menus. Into troubleshooting, then image quality.
You will want to run both the eliminate light stripes and eliminate smears procedures. that will purge the print head, blow air through the jets and hopefully resolve the problem. I do believe the 8550 has a Jet Substitutin procedure where you can do a workaround and make other jets make up for the light areas.
here are some directions, Will forward more
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Troubleshooting] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Print Quality Problems], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Troubleshooting Print Quality Page], and then press the [OK] button.
  4. Evaluate the 'Light Stripes Test' page for missing printhead jets, such as missing Cyan, Magenta, Yellow or Black color bars. The 'Light Stripes Test' page is the last page of the Troubleshooting Print Quality Page that printed.
    WARNING: To avoid injury, do not touch the sharp metal strip attached to the clear rubber wiper blade in the Maintenance Kit.
  5. Use a clean lint-free cloth or a new paper coffee filter to gently clean the maintenance unit's clear rubber wiper blade, use only a wiping motion across the entire length of the wiper blade, and then empty the waste tray. A dirty maintenance kit wiper blade can cause white lines and weak or missing printhead jets.
  7. Repeat step 3 to reprint the Troubleshooting Print Quality Pages. If there are no missing or partially missing color bars then the print quality problem has been resolved. If there are missing or partially missing color bars then the printhead cleaning procedure will need to be performed. Continue with the next section.
To clean the printhead using the basic eliminate light stripes procedure:
  3. Press the [Up] or [Down] arrow button to select [Eliminate Light Stripes], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select [Basic], and then press the [OK] button. The printer will perform a head cleaning, which will take about five minutes. The printer will then print a cleaning page and a light stripes test page.
  5. Repeat steps 1 - 4 one more time. If there are no weak or missing jets then the print quality problem has been resolved. If there are still weak or missing jets after two basic light stripe cleanings, continue with step 6.
    NOTE: Do not try the Advanced Eliminate Light Stripes Cleaning mode without performing two basic cleanings first.
    To clean the printhead using the advanced eliminate light stripes procedure:
  6. Press the [Up] or [Down] arrow button to select [Advanced], and then press the [OK] button.
  7. Select the missing jet color and number. If necessary, check the light stripes test page to determine the color and jet number of the missing jet.
    NOTE: Only perform the advanced light stripe cleaning once. If weak or missing jets still persist, continue with step 8.
  8. Print the Troubleshooting Print Quality Page. Evaluate the Light Stripes Test page for missing printhead jets, such as missing Cyan, Magenta, Yellow or Black color bars. If necessary, perform the basic eliminate light stripes procedure one more time. If the Advanced Eliminate Light Stripes procedure does not resolve the weak or missing jets, perform the Enable Jet Substitution Mode. See the Related Items below.
Feb 05, 2010 | Xerox Phaser 8550DP Printer
Not printing the top half of letters on HP OfficeJet 4680 printer
Well, this can be an almost entry print cartridge. Or a clogged print cartridge. Or a broken wire that connects to the print head so that it does not work the top half jets. Or a bit of dirt or stuff on the pad that connects the cartridge to the print head.
1. Remove the cartridge, and blow the area out with canned air. Shake the cartridge, both to redistribute ink and to verify the presence of ink.
2. Examine the ribbon cable that connects the cartridge to verify that it is intact.
3. If and only if you can't find a problem in the above, (or if they are empty) replace the cartridges.
Feb 01, 2010 | HP Office Equipment & Supplies
HOW DO i CLEAN THE PRINT HEAD ON MY HP 6940
Print heads become blocked for a number of reasons, but the most common is simply that the ink cartridge has dried out, and so has the print head. Anyway, here are a few hints and cleaning methods that MIGHT get things working again.
  • Never let the printer stand with an empty cartridge. Either fit a fresh one, or seal the print head unit in a plastic bag with a few drops of water for humidity.
  • If the print head has become clogged and the printer's head-cleaning cycle won't help (run it 10 times if you have to) you could try these things:
    • Soak the print head in hot water then leave it overnight, then try it again
    • If you have access to an ultrasonic cleaner that will take the printhead, use that. (These are used by jewellers and other people which have to clean small, intricate parts)
    • Buy some Isopropyl Alcohol and soak the printhead in that overnight. (You can get it from the chemist)
    • Use a Mr Cuppacino (or your Espresso machine). It's a small kitchen appliance which creates a jet of steam for frothing milk for making a cappuccino. You can use the jet of steam to blast the print head. But be careful that you don't melt things -- short, sharp jets only.
    • Each time you try a cleaning method, use a damp paper towel to gently wipe and dry the print head area.
    • Put a teaspoon of water in the bottom of the empty cartridge and try the cleaning cycle a few times.
Aug 03, 2009 | HP Deskjet 6940 InkJet Printer
Low Toner Warning
Turn the unit off. Remove the cartridge and shake it back and forth. Ten place it and turn the unit back on. Also you can reset the counter on the cartridge, go to UNI KIT and look under Brother TN 110 refill support. These people sell refills. The ink you get with he printer is minimal. Also turning the printer off and back on will help with resetting. I found that there is plenty of toner left when the warning comes on.
Feb 28, 2009 | Brother MFC-9840CDW Laser Printer
How do i print edge to edge using the G85 Office Jet all in one?
The G85 does not support edge to edge printing, it requires a top margin of 0.08:, a bottom margin of 0.46" and side margins of 0.25".
Regards,
Bob Headrick, MS MVP Printing/Imaging
Sep 03, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Epson 1800- trouble printing cds
Try to print on a sample or spare CD, before that Click Print Position Confirmation Pattern in the Print Confirmation Pattern section.Click Print to print the confirmation pattern on the disc and remove disc..
--Using a metric ruler, measure the distance from the hole to the cross marks labeled A and B. On print cd application click file and click print and select adjust print position, click enter values then select the distance for A into the height (top) box and distance for B in the width (right) box then click on ok
Mar 14, 2008 | Epson Stylus Photo R1800 InkJet Printer
Recordex Studiojet 50 Cd/dvd Auto Printer Logo
37 people viewed this question
Top Recordex Computers & Internet Experts
David Payne
David Payne
Are you a Recordex Computer and Internet Expert? Answer questions, earn points and help others
