Ft error on logik lpv 14 hp aircon - Office Equipment & Supplies
My washing machine has a code e21 what do that mean
Please read description carefully about error code
Logik Washing Machine Error 21: "E21"
Error Code Definition: Washer has not drained in allotted / time washer not draining.
How To Clear Error Code:
-Check that filter is not blocked or kinked
-Check drain hose is clear of any blockage or kinked
-Check wires to drain pump
-Check drain pump is not faulty
-Check level sensor and switch
-Check wires to level sensor
here is link for more about your all error code which will may helpful in future, LOGIK Washing Machine Error Codes How To Clear
here is video which helpful regarding solve and understanding error.
Mar 16, 2017 | Washing Machines
What is the HP Rating for a 1965 Sears 14 foot V Bottom Boat?
Motors of that era where very big and heavy. mY current 15 ft aluminum jon boat says 25 hp. It probably would hold a 2 cycle 25 but not a new 4 cycle (too heavy)
Jun 25, 2015 | Boating
I am facing problem from Kohler RS14, It is working/starting fine on LPG but not working on Natural Gas, on NG it is not taking starting, showing CC1, then CC2, then CC3 then stopped. And in case if it...
Is this set up for multi fuel????? or are you switching the fuel sources?
If the generator is multi fuel it will have two input gas lines one for LP and one for NG. If you are just putting gas to the one inley pipe IE single fuel it won't work. In naturalg as there is approx 1000btus of energy cu/ft in LPV there is 2513 almost twice as much. As such if a generator is not truly duel fuel, when it is set up for LP a small orfice to restrict the LPV gas flow is installed in the fuel mixer / carb. If you try and run on NG it won't get enough fuel, this orfice can be taken out and it should run fine.
Sep 05, 2013 | Kohler Electrical Supplies
Logik portable a/c displays this error
Jun 11, 2013 | Heating & Cooling
Main bearing cap torque 6g74
Torque Specifications
air intake plenum 11-14 ft lbs.
camshaft bearing cap 14-15 ft lbs.
connecting rod nut 37-38 ft lbs.
camshaft sprocket bolt 66-67 ft lbs.
crankshaft pulley bolt 108-116 ft lbs.
cylinder head bolts 65-72 ft lbs. ( 3.0L) 76-83 ft lbs. (3.5L)
drive plate ( flywheel ) 53-55 ft lbs.
exhust manifold 11-16 ft lbs.
intake manifold 11-15 ft lbs.
main bearing cap 55-61 ft lbs.
rocker shaft 14-15 ft lbs.
valve cover 27-35 in. lbs.
throttle body bolt 84-108 in. lbs.
May 17, 2012 | 1996 Mitsubishi Montero Sport
Got a logik washing machine error code e4. what the problem thanks
My washing machine in a logik and is displaying a E4 error code any now what's wrong wiv it
Jan 13, 2012 | Washing Machines
What is the head bolt torque specs on a 1990 jeep 4.0
  1. Tighten all bolts in sequence (1 through 14) to 30 N·m (22 ft. lbs.) torque.
  2. Tighten all bolts in sequence (1 through 14) to 61 N·m (45 ft. lbs.) torque.
  3. Check all bolts to verify they are set to 61 N·m (45 ft. lbs.) torque.
    1. Tighten bolts in sequence:
    2. Bolts 1 through 10 to 149 N·m (110 ft. lbs.) torque.
    • Bolt 11 to 135 N·m (100 ft. lbs.) torque.
    • Bolts 12 through 14 to 149 N·m (110 ft. lbs.) torque
    Dec 16, 2010 | 1990 Jeep Cherokee Limited
    V6 T3000 need torque specs has throttle body injector
    3.0L and 3.5L V6
    Aug 15, 2010 | 1994 Mitsubishi Montero
    65 people viewed this question
    k24674
    jasbo
    jasbo
