Pairing manual for Craig CMA3532BT
Can't find any manual on how to pair this speaker
thesoundman
  • 41 Answers
SOURCE: aftermarket 6 x 9's
What type of car is it? You can purchase speaker harnesses at any car audio shop that will allow you to snap into the factory plugs. Also, beware if your system was designed for 8 ohm speakers - using 4ohm speakers instead could cause some problems. Most aftermarket stereos are designed for 4ohm speakers, but some factory stereos designed for 8ohms could be damaged if you give them a smaller ohm load.
Posted on Sep 21, 2007
SOURCE: S-Sir Sub Unit won't pair
I almost went out and bought a Sony HDMI cable but I tried something first and it worked me. I wrapped tightly the transceiver on the back of the main unit with aluminum foil and what do you know it fixed the problem. I guess since I was using a cheap HDMI cable the foil helped to shield out the interference. Sony HDMI cable $70.00 or aluminum foil 5 cents.  Let me know if this works for you as well.
Brent mevioradio.com
Posted on Apr 26, 2009
fleshgear
  • 541 Answers
SOURCE: need passkey for the pairing for bluetooth with
The passkey in the Phone prompts up only when you are trying to pair your device to another device,
So, you can provide 1234 as the password and another user who is pairing with you should also provide the same,
Incase if it is not working under Generic key or if you are facing any other problem related to Bluetooth pairing, Please contact your Service Providor and check..
Posted on Nov 06, 2009
  • 128 Answers
SOURCE: purchased 2 used sonance sonamp 260 for homewide
I am assuming you are using the standard sonamp 260 not a 260x3
and that when you say you are getting sound on only 1 pair that means only on 1 side (left or right channel only?)
Are using a speaker selector box? you must to regulate the resistance (ohms)
if so first unhook all but on pair of speakers and see if both channels are working.
if they do your problem is in the speaker selector not the amp if no then check to see what the amp level is set to. These are the two small holes on the front right of amp make sure they are set about equal at around half way up.
If that doesn't work flip the RCA cables coming to the amp perhaps you have a bad cable if that doesn't work make sure your receiver (source) is outputing a stereo signal to begin with.
lastly 8 sets of speakers off 1 amp? that's pushing it.even with a high quality Niles or speakercraft selector that controls the resistance going to an amp I wouldn't go past 5 sets.
The right way to do it would be to use 260x3 or a sonance or speakercraft 12 channel amp.
Posted on Jan 15, 2010
  • 6 Answers
SOURCE: I have a pair of Mission 732 speakers one speaker is damaged
i have a couple pair one with a damaged cabinet so i might be willing to make a deal for whatever driver/ part you are looking for...
pUL 646.249.6299
Posted on Aug 14, 2010
When I am trying to pair my smart phone with my ISBW2113 speakers I am getting an error: Unable to pair with ISBW2113. Incorrect PIN or password?
default is usually 4 zeros
yep it is. You must only have one entry on your phone for them. Manual is listed, details on page 2.
Pairing the Speakers (This process should be done FIRST before pairing a Bluetooth device. This should only need to be done upon first use.) 1. Power on the speakers by sliding the power switch to the ON position on both units (first make sure both speakers are fully charged). The Bluetooth Indicator and Speaker Connection Indicator will flash slowly in unison. If the Speaker Connection Indicator is not flashing, but is solid white both speakers your speakers are already paired. You can skip to the Pairing a Bluetooth Device section. 2. Press the Connect Speakers button on both speakers simultaneously. The Speaker Connection Indicators will flash quickly. Wait until both Speaker Connection 3. Indicators are solid white, this means the speakers have been successfully paired. Please note that this process can take up to 1 minute. Note : For all future uses please turn on both speakers and wait for them to connect (it may take up to 1 minute for them to pair automatically even after initial use). There should be no need to press Connect Speaker button again. If any pairing issues should occur, please follow the above steps again. Pairing a Bluetooth Device 1. Make sure you have first followed the instructions for Pairing the Speakers
When pairing, the device should remain within 3 feet of the speakers. 2. Press the Pair button on ONLY one of the speakers. The pair indicator will begin flash quickly. Using the native controls on your Bluetooth device, select the "ISBW2113" in your Bluetooth settings to pair. If your device requests a password, enter the default password " 0 0 0 0 ". Refer to the user's manual for your specific device for instructions on pairing and connecting Bluetooth devices. 3. When successfully paired, the pairing indicator will stop flashing and will remain solid. After initial pairing, the unit will stay paired unless unpaired manually by the user or erased due to a reset of the device. If your device should become unpaired, follow the above steps again. If any pairing issues should occur, un-pair the unit on your Bluetooth device and follow the above steps again. Note : If two speakers with the ISBW2113 name appear on the pairing list of your device, please erase one of ISBW2113 listed in your Bluetooth device and repeat the above steps again. Para descargar este Manual del Usuario en ingl?s, espa?ol y franc?s, o para obtener respuestas a preguntas frecuentes, visite la secci?n de apoyo en www.iLiveElectronics. com Playing Audio Wirelessly 1. Follow the instructions for Pairing a Bluetooth Device. 2. Use the native controls on the connected Bluetooth Device to select a track. 3. To play, pause or skip the selected track, use the native controls on the connected Bluetooth Device. 4. Any audio played through the connected Bluetooth device will now be heard through the speakers. Pour t?l?charger ce guide de l'utilisateur en anglais, espagnol ou fran?ais, ou pour obtenir des r?ponses ? des questions fr?quemment pos?es, consultez la rubrique d'assistance sur www.iLiveElectronics.com Customer Service: 1-888-999-4215
ILive ISBW2113B User Manual Page 2
Jul 04, 2016 | iLive ISBW2113B BLACK WIRELESS BLUTOOTH...
How do I connect my tablet (on which I'm watching Netflix) to the CHT912 soundbar for listening?
You will need to place the sound bar's Bluetooth feature is "discovery" or "pairing" mode and then follow the tablet's usual method of connecting it to a new Bluetooth device. Once paired you can redirect the tablet's audio to the sound bar. You may also be able to use a 3.5mm to RCA plug cable (usually used to connect PC sound cards to amplifiers or powered speakers) to connect the tablet's headphone jack to the sound bar's A/V audio inputs.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Dec 31, 2014 | Craig Electronics CHT912 Bluetooth TV...
How to pair ny mini bluetooth craig speaker to my
Turn on the bluetooth of your phone first: Go to settings>Wireless and Networks>Enable Bluetooth and disable discovery limit in bluetooth settings. After that make sure the bluetooth in your speaker is on and let your phone search the speaker and let it pair with it after that go into your phone's music player and look for its play options and if you see via bluetooth click it. Just let me know if you need further instructions or you could watch this video showing how he pairs his bluetooth speaker from his phone DBEST London Bluetooth Mini Speaker Review
Oct 16, 2014 | Cell Phones
How to pair the speaker
That model is wired only and just plugs in.
Feb 28, 2014 | Craig Portable MP3 Speaker - CMA3016 White
To Pair:
1. Turn on your Bluetooth speaker (slide switch to BT)
2. Light on bottom should turn on Blue. If not, plug speaker into USB connector and bottom will turn Red to indicate it's charging.
3. Make sure Bluetooth is turned on your PC or Phone. Select device name: CMA3532BT.
4. Enter pairing code (passcode): 0000 or you can try: 1234
Apr 19, 2013 | Audio Players & Recorders
How to pair craig cma3532bt
To Pair:
1. Turn on your Bluetooth speaker/headphones (slide switch to BT)
2. Light should turn on Blue. If not, plug speaker into USB connector and light will turn Red to indicate it's charging.
Jan 03, 2013 | Radio Communications
Making my craig bluetooth speaker discoverable
Through basic hacking, the code 0000 worked for me....
I wish it came to me sooner!
Craig Electronics CMA3532BT is the model number -
A tiny cylinder speaker - sounds pretty good for the tiny $$$ too.
MikeFilosa
Dec 02, 2012 | Craig Portable MP3 Speaker - CMA3016 White
Why I can't bluetooth pair with veho VSS-006-360
Hope it helps.
Power off your N8.
Remove battery from your N8 and reinsert again and then power it back on.
Activate Bluetooth settings and program it to become discoverable
Power off your bluetooth speaker
Remove battery from your Bluetooth speaker and reinsert.
Power it on again
Allow the pairing to proceed for both devices. Check and confirm/test whether operational
Oct 17, 2017 | Veho Audio Players & Recorders
Hello- I just dropped my H710 Motorola headset. When I turn it on I hear the 4 tone chime, but now I also hear a ping after the chime. The headset will not connect to my Palm Centro and I'm unable to pair...
Try to pair again. Make sure you erase the profile from your phone. Then pair again. If you keep hearing pink. there is damage to the speaker on your headset.
Jan 15, 2010 | Motorola Mobility H710 Bluetooth Headset
184 people viewed this question
 Grubhead
Grubhead
