Question about Russell Hobbs 13355 Cordless Electric Kettle
The on button would not stay down
The on button bounces back up, can this be repaired?
The L.E.D light is staying on the receiver, and I have had tried new batteries in both transmitter and receiver???
It could be that a button is stuck "down" on the remote control.
Push every button on the remote, one at a time, and see if they all bounce back. If you find one that is stuck down, use a tooth pick to help it back to a normal position. 'Hope this helps.
Feb 29, 2016 | Televison & Video
Whats wrong I had a picture blurry and bouncing but it powered done.
You need to replace the lamp. Instructional videos on how to do this are available online.
May 24, 2014 | Hitachi 50VS810 50" Rear Projection HDTV
The back end is lower than the front end, like the shocks are broken, maybe something about an air shock?
Looks like it.
Go to each corner of the car, press it down as much as you can and let go quickly. The corner should bounce up a little, down a little and then stay at the mid point - that is a 1.5 bounce. If the car is bouncing more 1.5 times or doesn't bounce at all, then the shock at that corner is bad and need to be replaced.
Shocks don't have a valve for the driver to fill with air. They need to be replaced with new ones.
Based on what you describes, the back corners will not press down and of coarse will not bounce - a definite shocks problem that need to be replaced.
Oct 23, 2013 | 2004 GMC Envoy
How will I know if I need new shocks and strutts for my 2005 sunfire
You can test them by pushing down at each corner of the vehicle, like trying to bounce it.
When you let it up do so quickly and it should spring back and stay still.
If it bounces once or twice then the shocks need looking at or testing.
Jun 28, 2011 | Pontiac Sunfire Cars & Trucks
Oil pressure is fine then bounces upand down then goes to zero then back to normal then up and down then back to zero where it will stay
Check the oil pressure sending unit it sounds like your getting false readings . But check the engine oil level and smell it if it smells burnt you need to start looking for other causes of this problem
Feb 13, 2011 | Jeep Grand Cherokee Cars & Trucks
The car has a surpention problem
If your car is not handling well then you could have a bad shock absorber.to test each corner just push up and down on each corner each corner should bounce 1 and a half times if it stays bouncing up and down then you got a bad shock
Dec 05, 2010 | 2002 Oldsmobile Alero
Memory card will not lock into down position. will just bounce back up
It seems that the CF reader mechanical assembly part is loose or it has out of place an internal part.
It may be caused by excessive force in pushing/pulling a CF memory card, or due to a manufacturing issueof the camera.
The solution is to open the camera, and check what is causing the problem and fix it.
If it's under warranty, I do recommend you to return it. If not, then you will need to pay for its repair, or do it yourself if you have experience, skills and patience in fixing electronic devices.
Such repair will require some philips screwdrivers, a soldering iron, soldering wire, and a st of tweezers.
There are in internet some guides to open and disassembly Canon XT 350D or Rebel 300d cameras. The disassembly process with the XTi 400D is very similar. You can Google fr such guidelines.
Best regards,
May 24, 2009 | Canon Digital Rebel XTi 10.1MP Digital SLR...
New phone garbled sound
its not that wrong push button man..,you'r fone was grounded... 1st man go check all the buttons.. if it bounce back all then your buttons work... ...but if you found either one does'nt bounce back... thats it... go to your nearest service center.... but if all working fine ... man your phone is grounded and service center only can fix that...
Jan 03, 2007 | Motorola Mobility RAZR V3
Russell Hobbs 13355 Cordless Electric Kettle Logo
101 people viewed this question
Top Russell Hobbs Kitchen Appliances - Others Experts
Jerry Greenberg
Jerry Greenberg
ashburton
Are you a Russell Hobbs Kitchen Appliances - Other Expert? Answer questions, earn points and help others
