Question about Plumbing
Diaphragm pump won't pump
My 12v DC pump got clogged by what appeared to be hair. I clean the inside of the poump,I check the motor, its working, the eccentric rotor is free to rotate. But it now does not pump. I didn't remove the diaphragm because I didn't want to damage it. The inlet is clear. The outlet can not be seem.
What's wrong and how would you fix it?
  • charles46902 Mar 17, 2009
    This pump is SHURflo 8000-543-236 with a 12v DC motor capable of 1.8 gpm
  • Greg Bernett
    Greg Bernett May 11, 2010
    Sounds like it is mucked up on the inside. For one thing....do not over pressurize it, you'll blow the diaphragm in it. Researching this....what make and model of pump?
Check the valves to ensure they are functioning... I'm not sure what kind of pump you have but wilden diaphragm pumps ball valves... you could have hair in this area not allowing the balls to sit on their seats. this would cause your pump to not work.
Posted on Mar 16, 2009
2001 LS. Why has washer wiper function stopped working?
rules.
1; does the pump make its normal sound, buzzzzz
it is a timing electric dc brush motor, that all make sound turning and pumping
2: the pump is on the bottom or fed from the bottom of the wish shield washer tank, lost that, missing,damaged, OIL inside from jiphphboobs? hacklube centers, or?
kids playing there?
so fuses are first, always, its electrical and all have fuses.
or circuit breakers. this has fuses.
so find tank (engine bay)
open lid?
is it full of blue fluid? (mines orange, rainx)
person2 turns it on, hear the pump now??????
yes. good the lines or nozzles are clogged (means clean them)
no.? bad news. you do know, isuzu is dead company here right
go to there usa, web page, see allthose missing parts and zero drawing (DOA they are)like suzuki now. and Daewoo before.
there all 1step away from YUGO zoned, (my lil joke)
now facts from a real fsm no lies like you got
truth
no relays
no warning stuff
1 fuse,CB 17 ,20 amps. CB = cab box
1 switch
1 motor (pump)
below the real deal
check for 12vdc to motor, turned on,ok
then check motor ground pin, if 12v ground is bad
if 0v ground is good (turned on ) then pump is dead
or just packed solid in ice or dead bugs,means clean it)
Jan 28, 2016 | 2001 Isuzu Rodeo
Not spraying water and solution
Tanks may be empty or not properly seated.
-Fill up the bladder with hot water and the solution tank with proper cleaning liquid.
-Remove and reseat both tanks
Pump may dry, needed to prime.
-Turn "off" power wait for about minute turn "on" power and depress spray trigger.
Check and clean filter on the deck (under the clean water tank, a red slotted plastic screw)
If nothing works you have to open the deck cover and go into details: check the pump, its a 12V DC motor, the solenoid, its a valve which operates with 120V, the hoses for broken or pinched part, the diode bridge (creates about 12V DC for the pump if the vacuum motor is turned "on" and the secret fuse (3,15A under the heat-shrink series to the diode bridge, if this one goes, no power to the pump!)
Mar 09, 2014 | Bissell ProHeat Pet Upright Deep Cleaner,...
Front washer motor not engaging, rear washer works
washers.
hits electric and water hydraulics, so 2 technologies merge.
1: fuses blown?
2: does pump motor spin when asked, (2 men or kit and you)
yes, good
no, ? bad, pull hose, spin now,
yes, line clogged
no? pump dead, or clogged clean pump or replace, your call.
if pump seems dead i check for 12vdc at pump on demand.
kid turns switch and 12vdc lands on motor pins.
got 12v, good.
so pump spins, and no squirt.
A: the line is long, very long. and can clog easy due to that fact
or the jet on the end is clogged.
so why no remove the hose. does the hose squirt on demand.? at rear of car>?
yes, nozzle clogged.
no,,, line clogged. big work finding long hose line.
some lines near front of car (hoses) have check valves.
they too love to clog.
there you go, washer 101.
Dec 16, 2013 | 2007 Toyota Highlander
Washer fluid motor not working
it can only be these things. (is just a dc, motor)
does it spin? does it make noise, ( we know it dont pump liquid)
but???
Ill pretend motor is silent.
1: bad fuse #6
2: bad pump, bad motor. (same unit) pump can in fact jam with junk and be silent. clean it.
3: bad wires connectors to same or bad washer switch
NOT SILENT.?
motor tries to pump, (ear by sides, and cleaned inside by you)
A: clogged line,or any check valves seen in line, on most cars. clogged.
B: kinked line.
C: clogged jets.
Dec 03, 2013 | 2007 Honda Fit Sport Hatchback
Holding water
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 02, 2013 | Washing Machines
Washer won't spin
Good Day,
Avanti washer repair
Good Day,
Nov 01, 2013 | Washing Machines
My Zanussi WJD 1257 washer/dryer's drying cycle has started finishing early. No error codes. The wash cycle works fine but the drying cycle is simply stopping prematurely. You can set it to dry for 45...
Good Day,
Nov 01, 2013 | Zanussi Washing Machines
My marine macerator pump stopped working altogether. What checks need to be performed?
first check if the pump get power. I presume your pump is 12V DC. If you have a dc tong tester that is one way.Or disconnect the motor and reconnect directly to a battery. Then a more crude way to test is to take one lead off and touch it together again. If your pump is stuck but the motor is still o.k. you will get a reasonable spark. No spark: your motor brushes are worn out or your motor is toast. You have a spark your pump is stuck with debris. Try to run it reverse(reverse the power leads) and or clean it out. You can see the cutter knifes from the intake end and should be able to turn them with a screw driver. New pumps on ebay: I paid $125
Jul 29, 2010 | Saniflo SaniGrind Macerator Pump Tank
Whirlpool washing machine won`t spin or pump out
if youre handy with tools , check out the DRAIN MOTOR PUMP , usually located at the bottom on a side of the washer , it could be clogged with lint or debris , need to open washer , remove the DRAIN MOTOR , inspect inside to remove and clean it , be ready with rags , theres a lot of water that will come out once you remove it . good luck AJ
Jun 08, 2009 | Washing Machines
Plumbing Logo
579 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
