Question about JVC XL-MV303 CD Player
Xl-e3 CD player drawer will not open - JVC XL-MV303 CD Player
Denon CD Player Drawer won't open
This problem can be due to a defect in the player mechanism or binding in the drawer travel path. You may be able to find and correct the binding problem.
Jan 29, 2015 | Denon Audio Players & Recorders
The CD drawer on a JVC EL-E3 CD Player fails to open/close. The CD fails to play when I physically close the drawer. The drawer does not close completely and needs an extra push to close it.
Sounds like the alignment is off. By physically pushing the drawer.
There is a motor on the side of the drawer that should control the drawer by pushing a piece of plastic back and forth. This piece can shift if pressed to hard. In the back of the drawer are the rods that control the top to drop. These need to be aligned with the side motor.
Jan 07, 2015 | JVC Audio Players & Recorders
How to open the cd drawer when the open/close button won't
Remove the lid, you will probably have to remove the whole cd mech and turn the gear underneath with your finger
May 22, 2014 | Marantz SA8260 CD Player
Why won't the CD drawer and Cassette door open on my Panasonic SA-PM17 CD Stereo System?
This does happen with CD trays, it's quite common. I can't remember the exact mot common cause, but it's some worn out part, such as a small (plastic) cog wheel. Search on "cd tray won't open" on the internet to find a multitude of reasons, most to do with computer CD trays, but I guess the mechanism is essentially the same. These may also describe ways round the problem.
Some CD players have a small hole on the front near the tray into which poking a straightened out paperclip should enable you to open the tray by a few mm, enough to be able to pull it open in an emergency - but it's awkward to do on a frequent basis.
5.May.2014
May 05, 2014 | JVC XL-F254BK 5-Disc CD Changer
The playback drawer will not open, continues to flash "reading" until I press "play" and the it reads "clos ".
There should be a small hole on the playback drawer to allow a manual opening of the drawer. The player does not have to be on and preferably should be off when doing the manual eject. Take a paper clip, straighten out one leg, then push it into the hole about 1/4 inch until you hear a click and the drawer should open.
Feb 04, 2011 | Teac RW-D200 / RW-D250 Dual-Deck CD Player...
CD door will not open. Does not respond to the open close button. Cd is incside player. Was put in correctly. How do I open cd drawer without breakin it.
the cd drive should have a tiny hole under the drawer. push a small screwdriver into the hole and it will release the drawer.
Mar 16, 2009 | Aiwa Audio Players & Recorders
Player doesn't recognize most CDs - 'no disc' message appears.
Your player lens needs to be cleaned by a lens cleaner...
Feb 24, 2009 | Teac CD-P1260 CD Player
On my JVC TH-60 disk drawer will not open?
hello the problem you have is that the tray is not in time so the security switch dont let to open this try to get ifo how put on time or align the mark on main spindle against the small one hope you undrstood saludos
Jan 08, 2009 | JVC XL-F154BK 5-Disc CD Changer
Disc drawer will not open
Try to hear a sound of of a running motor inside the unit. If you can hear it, the there's a broken or misplaced rubber belt. The belt drives the drawer open.
Nov 25, 2008 | JVC XL-F254BK 5-Disc CD Changer
Cdr20 drawer is jammed ERROR message
Try taking the unit apart it mostlikly jamed or jumped track try re ajusting it that would prob work, another thing is to try messing with the gears that could aslo work
Oct 18, 2008 | Harman Kardon CDR20 CD Player
JVC XL-MV303 CD Player Logo
37 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
