What can i do if the machine is over-heating
The machine is over-heating causing black toner to clot
  • 430 Answers
Fuser assembly issue.Needs to be checked.
Thanks.
Posted on Apr 19, 2013
I have 5 machines Ricoh aficio 3235c showing a massage loading toner and then black toner is empty Althought the toner is full????
This is one possibility, but there are other solutions if this don't work.
The black toner is not set message is displayed. The black toner is not set message is displayed even though the black toner is set.
[Cause]
There is a problem with the BCU lift. The communication with the ID chip is faulty.
[Action]
Update the BCU software version to the latest version.
Apr 01, 2017 | Ricoh Aficio Office Equipment & Supplies
Black toner won't print event though cartridge is full on HP Photosmart 5255
Two options which you may want to try.
1) Use cleaner that you may be able to grab from one of the computer shops and try cleaning out the printhead with it.There is a possibility that the ink has clotted or the printhead itself needs replacing.
2) Try another black cartridge from a similar working printer
Jan 05, 2015 | HP Office Equipment & Supplies
Brothe HL2130 laser printer black triangles left margin
Check the drum unit. Rotate the optical cylinder slowly, looking for a scratch or clot of toner on the drum. You may need to clean it with compressed air or VERY gently with alcohol and a cotton ball. If the drum cylinder is clear of defects, check the fuser at the back of the machine for the same. A drum can be cleaned or replaced, a trashed fuser is not repairable. It may also be cheaper to replace the machine than to replace the drum of course.
May 11, 2014 | Brother HL 2140 Laser Printer
Toner marks
Your Drum Cylinder has a scratch or clot of toner stuck to it. Every time it rotates along the page (usually 4 rotations per A4) it leaves a copy of the defect on the page. If you take the toner cartidge out of the drum unit, you will be able to turn the drum cylinder until you find the fault. Either replace the drum unit or CAREFULLY clean it with alcohol on a cotton ball (meths or iso propoyl will do) in the case of a toner clot. If the fault recurs quickly after cleaning, then you have a damaged drum and it should be replaced.
Best of luck.
Mar 20, 2014 | Brother HL 2140 Laser Printer
Ricoh Aficio AP3800c Yellow Toner Problem: I have one of these machines complete with the scanner/copier top fitted. For the past three years the machine has given faultless service and only ever needed...
Hello there, i have the same problem here, but in the black
toner, i did the same as you and look that we have a clogged
pump or bad pump, the pump is located exactly where the dev.
unit is, but to remove it we need to take the laser unit from
the top cover where the printed pages stack, i'm going to work
in my printer, i let you now if i'm able to unclogg the pump.
I,m a electronic techniccian for Arcade machines(Namco) is the
first time that i work with a laser printer, the pump price is
$171.00, i let you know. Thanks
Miguel
Sep 02, 2010 | Ricoh Aficio AP3800C Laser Printer
Light streaks and gray streaks and little contrast.
Sounds like there are multiple problems on this machine. Dirty optics can cause light images, white streaks can be caused by dirty cortron wires(becareful when cleaning the wire or all the wires 3 usually, Q-tip can help) , not enough toner in the ink hopper, dirty cleaning blade in the drum modual. A bad heat roll can cause streaks also. Background with light images and black spots can be caused by competitive toner not working very good.
Oct 15, 2009 | Canon PC-920 Black and White Copier
We had a paper jam and I got the paper out but now the fax machine is printing out pages that are smeared with black toner
The fusing unit heat roller is damaged or worn out and it needs to be replaced.The roller has non-sticking teflon coating.When this coating is bad,toner start sticking to it and causing jams and bad copy quality.
Sep 30, 2009 | Brother IntelliFAX 2800 Laser Fax
Toner can be wiped off after copying - smudges
Hello sir; This problem caused by fuser roller and presure roller in heating unit, you have to take apart check it out, may be bushing broken.
Feb 18, 2009 | Ricoh Aficio 2022 Black and White Copier
Blank Streaks
streaks are caused either by the toner, drum, lamp or fuser.
If you make a copy and it does not show a streak then it was done by the person sending the fax. BUT, check this,
open door and take out toner cartridge. look for a thin glass that is on the bottom of the machine and wipe it. Toner spills will cause a black streak.
Nov 15, 2007 | Brother IntelliFAX 2800 Laser Fax
26 people viewed this question
jasbo
jasbo
