Question about Maytag Dryers
When dyer runs it makes a squealling noise like abad bearing>
When dyer runs it makes a squealling noise like a bad bearing?
  • 1 more comment
  • tjoyave Mar 11, 2009
    model is a queiet seres 200 10 cycles MDE3706AYW makes a real sort of high pitch sqeual intermeneitly
  • steve
    steve May 11, 2010
    Model number please.
  • Anonymous Mar 20, 2014
    making a squealing noise
  • Maytag Master
  • 3,361 Answers
Could be felt pads and nylon glides on the front drum support are deteriorated.
Could be a sticky build up on the rear drum rollers.
Could be a worn belt tension roller.
Unplug the dryer.
Remove the front panel.
Remove the front drum support.
Remove the belt and drum
Inspect the items listed above.
Replace as needed.
Posted on Mar 11, 2009
The dyer still works but it makes a loud noise and doesnt produce the same amount of heat as before
LOUD CLUNKING NOISE WHEN THE DRUM TURNS? IF SO, YOUR ROLLER BEARING IS BAD. AS FOR THE LESS HEAT, YOU NEED TO CHECK YOUR VENT, MAKE SURE IT'S CLEARED. IF SO, YOU HAVE BAD COILS
TIMOTHY DO 714-334-1998
Aug 04, 2010 | Frigidaire Dryers
I have a LG dlg5988w drying that just started making a banging sound. Are there rollers that need replaced?
yes the belt has a tensioner with a bearing and a roller surrounding the bearing
the bearing can be locked up which will put flat spots in the roller m,aking the banging noise
Sound horrifying at times doesn't it?
Mar 07, 2010 | LG DLG5988 Gas Dryer
When the dryer runs even with nothing in it it , makes a thumping
check the inside of the drumm make sure none of the fins are loose,
but sounds more like the wheel rollers are bad, sometimes is loud when it starts then seems to go away a little after the dyer get hotter, is the heat that makes the metal bearings make less noise. u can replace the wheels,the belt an tensioner at the same time is cheaper to pruchase the kit an have it all done the first time! bad wheels put more stress on belt an eventually will break apart so just order the entire kit
Feb 02, 2010 | Maytag SDE3606A Electric Dryer
Dewalt dc759 drill squealling noise coming from
yes,the most coomon defect for poer tools are carbon brushes.But,git attention also to the gears,bushings, and bearings if there are loosen parts.Also you get rid to a debris or any small dirt particles that maybe sunctioned by the fan and has been entered in the body of the drill thats why you can hear an squealling noise..Just open and clean it.
Dec 05, 2009 | Dewalt DC759CA Factory Reconditioned 18V...
MAV408DAWK Maytag top load washer is squealling
The noise could be coming from the wornout drum bearings. It needs replacement.
Oct 13, 2009 | Washing Machines
My dryer is making a really loud noise when the clothes are spinning in the dryer. There is a loud rumble and squealling noise.
The squealing noise coming from your dryer is caused by the front glides located on the top bearing, they act like a pad against the drum and when gone, will make an awful squealing. part number for the 4 glides that may be needed is WE3X87 this is a common problem as it is a wearable part. if you don`t replace these in time it will grind all the way through your top bearing and start to deteriorate your drum. if its been like this for a while you may also need a GE drum bearing they come in short and long sizes. and are relatively cheap to replace.hope this helps
Thanks
Oct 11, 2009 | GE DBSR453EBWW Electric Dryer
Squealling noise while curving left
This is a symptom of a bad CV joint.
Jul 30, 2009 | 1996 Toyota Tercel
Washer spinning
Hi jmm119
Its hard to say what it is but it could be one of 2 things, either the belt ore the main bearing is gone. but my first guesss would be the belt.
brent
Sep 28, 2008 | Maytag Neptune MAH5500B Front Load Washer
There is a squealling noise
THE SUPPORT AND SPIN BEARING IS BAD . WHEN THIS GOES BAD IT DESTROYS THE LOWER SEAL. MAJOR REPAIR . CHECK WARRANTY IT MAY BE COVERED. OTHER WISE REPLACE MACHINE.
FXIT
Dec 06, 2007 | Admiral AW22 Top Load Washer
Dryers Logo
240 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
