Question about Canon iR 5075 AllInOne Printer
My IR 5075 comes to Reservation copies can be made only and when I copy comes to Copy suspended. Plse help
Cant print anything only display Suspended. If any door is opened cant detect close until swithced off and on.
Ir 8070 copier. How do I correct a print suspended error?
please perform a main controller clear from service mode
May 23, 2015 | Canon IR 8070
Canon ir 2016j display scanning without printing
frist remove the Ram & then reinstall it if the problem presist then cross check the i.p board
Jan 03, 2013 | Canon iR 2016i Black and White Copier
I'm trying to photocopy a book on a canon imagerunner 5075 without copying one page at a time and flipping the book around. Is there a way where the copier scans the right page and then scans the left page...
Hi Kim,
there are a couple of easy ways to tackle this problem. you have a book that when the spline is opened exposes 2 pages to the glass for the possibility of copying. What YOU need to determine is whether or not you want page 1 to ouput seperately from page 2, or , would you like page one to be on one side and page 2 to be on the second side. In other words auto duplex. That decision determines which feature you will use. I will walk you thru both. I realize you want the copier to scan the first page and then scan the second without you having to move the book around. I'm thinking you would be happy if the copier did that very thing and you wound up with a 2 sided copy with page 1 on the front and page 2 on the back. Here we go. Fom the main copy display locate the 2 sided button and select it. Select "book 2 sided" and follow the prompts. You could actually copy the entire book this way and when you are thru press "done" and here comes the avalanche!
If you want the images 1 sided on seperate sheets (not sure why) you can select "special features" from the display in the lower right corner and select "2 page seperation". same drill.
Apr 25, 2011 | Canon imageRUNNER 5000 Copier
Hi, if you can help me regarding our Canon IR 8500, it stop working, when you start to turn it on, it is not going to ready position, it is only reservation copy can be made, when you press the start, it...
Check to see if paper is jammed in the connectors for unit 1. Slide out unit one use a small mirror to look at the back side of the connectors for unit one. Black in color rear of unit one left side. Then also use a flashlight to check the machine side receptical for those same connectors. Paper sometimes gets wedged in there after paper jam removal.
Aug 13, 2010 | Canon Office Equipment & Supplies
Canon ir 1600 my copier print copy image is very poor
iR1600 are special machine that needs a little bit more care.
First, clean the laser unit and optics ( beneath copy glass too ). Then use some polisher and polish the developing cylinder and clean/replace developer cylinder blade.
Use GENUINE CANON DRUM UNIT and GENUINE TONER.
Jul 02, 2010 | Canon Office Equipment & Supplies
Lexmark 5075 - vertical line on copies or scans only
Clean all glass with 70% isopropal alcohol on the scanner. If the line is perfectly straight and crisp. There a spec on the glass probally causing the line.
Feb 21, 2010 | Lexmark X9575 InkJet Printer
Which one is better to buy IR 5075 or IR 5065
The all above models are same with minor change for speed
You need model as your daily output requirement
All models are heavy duty.
you can select any one for upto 10,000 print or copy per day or for 20,000 & up print/copy select ir 5075
Jun 15, 2009 | Canon imageRUNNER 5000 Copier
Image runner 5020 will not print or copy
Hello Ernest T,
If the main thermistor which monitors the temperature of the fusing unit (that hot as hell area) is out of postion this problem can occur. The thermistor determines when the fusing area is hot enough to allow the copier to display"READY". If it is backed away from the fuser roller it cannot reliably read the temperature and it may cause the copier to display suspended because it reacting as if because of a long copy run it could not keep up the temp and so it "suspends" as it tries to ramp the temperature back up. Make sure the thermistor is touching the fuser roller.
Apr 16, 2008 | Canon imageRUNNER 5020 Copier
Canon iR 5075 AllInOne Printer Logo
308 people viewed this question
old marine
old marine
