Question about GE PTS22LCS Top Freezer Refrigerator
Intermittent failure The freezer, set for 0 degrees F, will intermittently stop cooling and warm up melting the contents. This happens without ryme or reason.
    Guru:
  • 462 Answers
Sounds like you have a defrost safety thermostat not opening when the temp comes up on defrost. These can be solid state or the standard kind have a bi-metal switch. and if its solid state there is a check out procedure for it. Id need to review my manuel not many GE's around here.
Posted on Mar 11, 2009
Freezer stays cool but bottom stays warm.
I agree with your analysis, and recommend that you replace that fan between the two sections.
May 20, 2008 | Kenmore Refrigerators
Fridge and freezer not cold. Ice melting.
Need to replace circulation fan in freezer,
Remove plastic bump out in the back of the freezer, to access fan...
Mar 02, 2015 | Kenmore Refrigerators
Freezer and refrigerator stop getting cold
Most likely it has a coolant leak or the compressor is bad. I would call GE as there may be a recall to repair this no matter if you are the original purchaser or not. Although with the amount of computerization in home appliances, it could be a main circuit board going bad.
Feb 12, 2014 | GE PSC23SGPSS Side by Side Refrigerator
We are suffering intermittent failure to cool. The refrigerator will cool fine for long periods, and then for no apparent reason stop cooling. Then it will "magically" start working again. There doesn't...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
The defrost system has a defrost thermostat Which is clamped to the evaporator coils behind the rear cover inside the freezer. When the defrost heater is on the temp rises and when it reaches around 32 degrees at the defrost thermostat it cuts the heater off to prevent excess heating. Yours may be defective and not cutting off. Sometimes you can tell it's bad by the swollen appearance. You can test it with an ohm meter. It should show open when warm and closed when below 32 degrees.
Aug 22, 2009 | Refrigerators
Frigidaire Freezer Buzzing
thats not a valid model number open the fridge door and look up at the top by the light bulb on a white sticker and ill try to help ok
Apr 02, 2008 | Refrigerators
GE PTS22LCS Top Freezer Refrigerator Logo
192 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
