Question about Kenmore Washing Machines
What type of washer is this? Gas or Electric? Mod#110.26912691, serial # CJ 2125579
Need to buy another one, Just don't know if I need a gas or electric. My stove is gas heat and I have to plug it in an outlet. Washer had to be plugged in also.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 20 Answers
Hi Carolyn,
I've never heard of a gas washing machine, so I'd say it's electric.
Posted on Jun 02, 2013
catriver
  • 878 Answers
SOURCE: Maytag LSG7806A stackable washer/dryer - dryer not working
Deb, as long as the ignitor is glowing, it's probably your coils on the valve. Look at number 13 and 14 on the attachment. Part number for the booster coil is 306106 and 306105 for the secondary coil. Not a hard job, the coils slide right off after removing a screw and then replace the harness. Catriver...post back.
Posted on Oct 15, 2006
catriver
  • 878 Answers
SOURCE: does the Maytag LSE7806ACE require a 220 plug?
P-You are going to need 220, Catriver
Posted on Dec 19, 2007
TheMobilian
  • 8220 Answers
SOURCE: washer won't drain or spin.
Kenmore top loader blues direct%20drive%20cabinet%20removal.jpg Use a screwdriver to remove the screws holding down the control panel,then swing it upwards. Pop the s clips in the rear and remove the lid switch disconnect. Tip the case forward and remove it.You will now be able to repair the washer! The lid must be closed for spin. The lid has a striker in it that pushes against the lidswitch arm. This switch allows for spin IF the lid is closed. The switch may have failed. Mechanically the striker may be broken or the actuator arm may be broken. ls2.jpg here is a broken lid switch You can test the switch. If you have a meter. If not you can simply bypass this switch. In my left hand here is the lid switch male plug which I have removed from the lid switch harness. If I wanted to i could simply place a jumper between the 2 outside wires and the washer would spin. a%20lid-switch-unplug.jpg Do not leave it bypassed if you have small children or braindead brother in laws. a%20coupling.jpg A 3 piece drive coupling
hidden%20screw%20on%20dd%20washer.jpg NOTE: newer models have the screw hidden
dd%20washer1.jpg Here is a view of the washer with the case removed.
To get to the broken coupling
remove the pump first then
the motor,both are held
together with quick clips. a%20broken%20coupling.jpg pictured here is a broken drive coupling.
Line up the new part and replace
the motor, pump, and
case in reverse order. NOTE: This looks hard but if you take your time it is easy enough to save you big bucks! My friend RM made a 44 second movie on this subject. Click here to see it
Posted on Dec 23, 2008
  • 1122 Answers
SOURCE: kenmore stacked washer wont drain
you have to remove the front and take the water pump off and get all that clogged up stuff out of it-mike
Posted on Mar 16, 2009
  • 127 Answers
SOURCE: I have a Whirlpool washer, Serial #CL1510429, mOD
3949247 - LID SWITCH *** is probably bad. these units only look for that lid switch circuit to be closed at the end of the wash cycle and end of the rinse cycle, prior to spin/pump out. its a safety switch so the unit shuts off when you open the top.
you can go to several sites and find parts blow ups so you can find how to access that switch thats below the top.. hint: the top, front, and both sides come off as a unit to gain access to the components below, leaving the chassis sitting upon the floor.
best of luck,
ttfn
Posted on Oct 24, 2009
Canadiana (older model). Who makes it and does it use mix gas?
Most of the old tillers were 4 cycle engines not requiring oil in fuel . check at canadian tire for a filter but take your old one along to compare them
Apr 11, 2013 | Garden
It has refrigerant leak,any sugestions where mod#gr6gdx42k096x
If its a small leak, know techs that use super seal, and seems to work good
Sep 07, 2012 | Gibson Nordyne GR6GD-X42K072C 3.5 Ton 13...
What is the price and types of the pressure washers and where can i buy it?
Hi mary
About the price i think Mr JERRY is true
About the types there are many types like : -
- 2000 PSI Electric
- Gentron 2200 PSI Gas Pressure Washer
- Gentron 3000 PSI Gas Pressure Washer
- Gentron 4200 PSI
- 1600 PSI Electric Pressure Washer
- 2000 PSI Electric Pressure Washer
- 2200 PSI Gas Pressure Washer
And about the place you can buy these products, you can find many depots online like : -
http://www.generatordepot.us/pressure-washers.aspx
Thanks
Oct 30, 2011 | Garden
Clock,timer.& oven don't work. No electric on top panel All burners are fine
Hello, welcome to FixYa.
It sounds like the hi-limit safety thermostat may be tripped, the scenario you described is exactly how this would manifest
"clock,timer.& oven don't work. No electric on top panel All burners are fine"
...that is the component that typically trips/activates during a self clean on many ranges. You shouldn't need to open the front control panel, but access is through the back. (this can also occur during power surges)
You'll need to slide the range/oven outfrom the cabinet. If you slide the unit away from the wall and unplug it you can check the hi-limit.
It will either be a non-reset type hi-limit or push to reset. If non-reset it needs to be replaced, if push to reset type, simply pushing in the red button will get you back up and cooking in no time.
**Unplug the range from the wall first of course...safety first**
Once you remove the panel you will need to look for a switch/thermostat which looks like either of these...
NON-RESET
PUSH TO RESET
The replacement if necessary are available at "searspartsdirect.com" or "repairclinic.com" to name a couple.
Let me know how you make out. Good luck. I'll watch for your reply and if you need anything further I'll be glad to help in any manner I can.
Regards,
Macmarkus :)
Oct 15, 2011 | Kitchen Ranges
I would like to know the electrical requirements.( voltage and amperage) Does it plug in or is it hard wired? If the power goes out is the hot water also out? thankyou
Are you asking about tankless gas or tankless electric?
You posted under Tankless gas water heater: gas type tankless plugs into standard 120Volt household outlet to power circuit board. You need larger gas line than used for tank-type gas water heater.
If you are asking about volt and amp draw of Tankless electric, then that depends on specific model number.
For example, if each tankless element draws 3500Watts, and unit has 3 elements, you will need 3 additional 20 amp 240Volt circuit breakers. Volts x amps = watts. 3500 watts divided by 240Volts = 14.58 amps. At full blast, this unit would draw 43.75 amps and will cost more to operate yearly than tank-type electric water heater. If unit has 4500 watts elements, then it will draw 56 amps at full blast, and use a good percentage of household power.
Tankless water heaters have no hot water in power outage. This is true for gas and electric models.
Additional resources:
http://waterheatertimer.org/images/Compare-water-heater-parts-650.jpg
http://waterheatertimer.org/pro-n-con.html
http://waterheatertimer.org/pdf/Bradford-White-on-demand-tankless-service-manual.pdf
Aug 04, 2011 | Bosch 1600H-NG Natural Gas AquaStar...
Mod. MDE9700AZW good mor. dryer runs ,but no heat. no manuel, thinking it's the heating element or fuse. like to know there on the washer it's locations. thanks!
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 29, 2011 | Maytag Dryers
I am getting ready to buy baseboard heat for a 800-900 squarefoor open area, old GArage, And I am looking at 3 8' 2500W sections of base board. is this enough. And How much better is the units you have...
First, those of us on FixYa don't sell any products or appliances. Just information.
But to answer your question about electric baseboard heating ... It's the most inefficient and costly heating source you could use. With that said, a lot depends on the cubic footage of the area, as well as how well that area is insulated. This applies for electric, gas or oil heating. You rae not just heating square footage, you're wanting to heat cubic footage (i.e. Width x Length x Height = Cubic Footage). Assuming you have an 8 ft ceiling, the Cubic Footage would be (assuming a 9 ft ceiling) 7200 Cubic Feet. Based on that and if it was my home, I'd be installing a 20,000 - 25,000 Btu Vent-free (Flue-Less) Gas Heater, with built-in thermostat control. It could either be as a Free Standing, Vent-free Gas Fireplace System or simply a Wall Mounted Heater. One is decorative, as well as efficient and the other is simple and efficient. Plus, gas heat is a warm, moist heat that you feel very quickly and it's more comfortable than electric or oil heat. As a matter of fact, Vent-free Gas Heating Appliances are 99.9% efficient. And will work without electricity. Which is great during a Winter power outage. If you currently don't have Natural Gas at your home, then LPG (Liquid Propane Gas) is readily available.
So, by now, you figured out that my preference is gas. I have three Vent-free gas heating appliances in my 3000 square foot home (2-Vent-free Remote Controlled Gas Log Sets in existing wood burning fireplaces & a Vent-free heater in my 2-car garage). Our primary heat source is an electric heat pump. Which doesn't work well, when the temperature reach 32 degrees F or lower. We use the gas heaters only as a supplement heat source or as primary source, if the power goes out.
I hope you'll take a little time to research this, because in the long run, it can save you $$$. Below, is a link to Empire Comfort Systems. They have excellent supplemental and primary heating products in all looks, shapes and sizes. This will give you an idea of what's out there.
http://www.empirecomfort.com/corporate/
I hope all of this helped you. Please let me know. Thanks.
Jun 13, 2011 | Fahrenheat F25426 Electric Baseboard...
Can you convert gas to electric dryer
I need to convert my electric Maytag dryer to Gas
The sales person at Home Depot said we could that's why we got this one
anyone know anything about this?Help
Nov 14, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Old GE drier - Is it gas dryer or electric
it's a gas and you need a new gas or a 220 volt dryer.
Jun 24, 2009 | GE DCSR483EA Electric Dryer
Washing Machines Logo
29 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
