Question about Dmm KWC 10.501.134.127 Systema Single Handle Kitchen Faucet with Pull Down Pre
How to remove calcium buildup from kwc systema faucet
How to open the tip
Installed a new KWC Domo faucet and its leaking (alot) under the sink
Does if have a sprayer and is it still hooked up?
Aug 14, 2014 | Plumbing
New kwc domo leaking under (alot) sink
mixing chamber of the faucet may be cracked
Kwc kitchen faucet
Usually you need to use a hex key to unscrew.
Could you take a photo of the faucet and show us?
Feb 03, 2014 | Plumbing
Kwc faucet washers
lowes home improvment
Dec 11, 2017 | Plumbing
Removing a faucet with calcium buildup
I use slip-joint pliers to get a grip but you must work carefully if the nuts are plastic
Feb 10, 2013 | Plumbing
KWC faucet leaking around the main stream of water
Yes, go to HD or Lowe's and buy a new one.
Be sure to take the old one for comparison.
Nov 20, 2017 | Delta Model 470: Signature Kitchen...
Remove flow restrictor on KWC Faucet
We have a KWC 10.501.012.000 - Systema kitchen faucet and after installation the water pressure was much lower, even after adjusting the faucet's limiter screw to "minimum". We ultimately decided that the reduced flow was unusable and called back the plumber service. They sent out a different guy this time and he knew where to find and how to remove another of the faucet's built-in limiters (it has three, apparently).
I saved the removed water limiter parts. I hope this picture of them can you or anyone else with this same problem remove the limiter and get strong flowing water again...
Jul 02, 2012 | Dmm Plumbing
I have a KWC K24.41.61.000C06 and I live in a drought region. How can I limit the flow on the main faucet?
This faucet is designed to run full open and has no adjustments for lowering the flow. I would put something around the handle to keep the lever from opening completely maybe some pipe insulation or tape. Now you could get into the hose connection where the filter screen is and make a small washer type deal with a small hole in it to restrict the flow.
Feb 09, 2011 | Dmm KWC K.24.41.60.000C28 Gastro Kitchen...
Sticking of KWC DOMO model faucet.
Just received the new part for the domo. My model is older and is chrome with black. I have removed the top screw and need to know what is the next step in taking apart the rest of the faucet so I can replace the new part # k.32.60.00
Thank you, Stuart
May 11, 2010 | Delta Model 470: Signature Kitchen...
KWC Domo faucet sprayer won't switch between spray and stream
Having installed and fixed kwc domo faucets for years I'd probably take the spray head off of the hose, then look into the bottom of the spray head and see if the check valve is still there. It probably is. I used to use a thin screwdriver to pry the check valve out out.It will come out. You need to work at it a bit but these hold back a lot of water pressure and catch any crud coming down the water lines.
TL
Mar 17, 2010 | Plumbing
Dmm KWC 10.501.134.127 Systema Single Handle Kitchen Faucet with Pull Down Pre Logo
21 people viewed this question
Top Dmm Plumbing Experts
Tom Chichester
Paul Carew
Are you a Dmm Plumbing Expert? Answer questions, earn points and help others
