Question about Nikon D40x Digital Camera
Nikon d40 built in flash not firing but it popped up
My nikon d40 built in flash is not working suddenly. the camera didn't fall. my son took some pictures with it then suddenly the flash stopped firing. everything is ok except the built in flash.the flash lever keeps on clicking everytime i make a shot but the flash is not firing.
    Problem Solver:
  • 8 Answers
There is a sensor in there that tells the camera the flash is up you need to take it to a repair shop its not a at home thing
Posted on Mar 20, 2009
My Nikon D40's Flash wont pop up, and when it shoots it just smokes? I tried following a video but still nothing :/
maybe the flash is stuck, try pulling it out. sure if it is smokes coz flash delivers heat when it's fire.
Sep 18, 2011 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon d40 flash won't fire
If it clicks when the flash is already open, it seems there would be a problem with the flash open sensor. The camera thinks the flash is closed, so it tries to open it again and it refuses to fire, because firing in the closed position would blow the bulb.
The D40 flash is a bit different, but if you open it (just unscrew the two little screws in front) you'll recognize the sensor clips. Open and close the flash and see if the make contact when open.
(And DON'T fire the flash when open, or at the very least don't touch anything in there when firing or you'll get zapped.
Goodluck..
May 16, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Auto flash wont work
did it pop up automatically or did you pop it manually? if it popped up by itself then the flash unfortunately is probably dead, since on automatic, it won't pop unless it's going to fire. If you popped it manually then - the camera doesn't think that the flash is necessary for the conditions that you're shooting in.
Oct 21, 2009 | Nikon Cameras
Nikon D40 flash firing when down
Turn off the flash manually (top left button on the side of the camera body above the lens) or use the 'No Flash' Program Dial option - one click back from the green AUTO selector on your dial - the one with the lightning bolt inside a circle.
Jun 30, 2009 | Nikon D40 Digital Camera
Nikon D40 built-in flash...
Hi and thanks for coming to FixYa.
You can set the parameters for the manual flash in the Custom Settings Menu. Select Full to set the manual flash adjustments.
Hope this helps. Let me know if you have any questions in a comment.
Rob
Feb 27, 2009 | Nikon D40 Digital Camera
D70 internal flash not firing
Check if something is preventing the flash to pop up 'fully'. Check for some dust or other particles trapped between the flash and the body. Does the screen say 'Subject is too dark'? If so, the flash has not popped up fully.
Nov 10, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
If lightning bolt icon is blinking in viewfinder, flash is not ready. Either flash isnt popped up all the way or flash strobe tube is bad.
May 02, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Flash won't fire
Here's a <a href='http://photo.net/bboard/uploaded-file?bboard_upload_id=42254384'>photo of the sensor in a D70</a>. The D40 flash is a bit different, but if you open it (just unscrew the two little screws in front) you'll recognize the sensor clips. Open and close the flash and see if the make contact when open.
Apr 02, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
My Nikon d40 build in flash not working after fall
I have also had the problem of flash not working on my Nikon D40. I found out the problem and I made a quick video to help those who are having this problem. Here's the link to the video: Hope this helps !
Nikon Flash Fix
Oct 04, 2007 | Nikon D40x Digital Camera
Nikon D40x Digital Camera Logo
659 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
