Question about Dell Dimension 4600 PC Desktop
Thermal event issue
My computer PC keeps shutting down and won't work and on;y works for a few minutes and shuts down what do I do or need to fix it?
  • Dell Master
  • 32,281 Answers
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Posted on Apr 19, 2013
  • 111 Answers
SOURCE: Dell 4700C - Thermal Alert
Check your Processor Fan. It might be too much dirty or loose.
Hope this helps.
Posted on Apr 30, 2008
  • 37 Answers
SOURCE: Fan Malfunction??
Sounds like a heat issue, pop the side of your case open and turn on the PC, are there fans not moving? Take a close look at your processor fan if there is one.
Posted on Jul 10, 2008
  • 37 Answers
SOURCE: Dell Dimension B110 PC Desktop
Double post?
http://www.fixya.com/support/t765871-fan_malfunction
billspeer
  • 180 Answers
SOURCE: Dell Dimension C521 power shuts off spontaneously
It sounds like your power supply fan may be overheating. The easiest way to determine this is to open the case and look at the fan while it is spinning- if it is indeed spinning at all. I find the best way to get an idea of the functionality of the fan is to shine a flashlight on it at an angle. If you can detect fluctuations in the rpm visually, you know where the problem is. Then it's a matter of changing out the power supply. If, however, the fan seems to keep the same rotation speed constantly, we'll need to look further. Let me know what you find out before we go deeper into the system.
Posted on Feb 23, 2009
  • 3940 Answers
SOURCE: Dell Dimension 9200 keeps shutting down and won't start up
the key issue on the uncommanded shutdown is the POWER LED. If upon shutdown, the power LED Flashes AMBER, then the power supply is suspect.
If no flashing amber indication, then the next think I check is the heatsink (Processor overheating) remove, clean and apply arctic Silver heat transfer paste, see if the issuje goes away
Last but not least if the system is failing to boot, and displays a 3 4 diag LED code, then you may have a RAM module that is bad or may just need reseating. Running diags off of the Rersoujrce CD is something to look at too
Posted on Mar 28, 2009
Acer aspire 4736g shut down unexpectedly
try using a cooler pad for your laptop for heating issue,
try changing the RAM also sometimes the faulty RAM also does this
Jan 17, 2013 | Computers & Internet
Thermal event won't ever allow computer to boot at all
"Computer unplugged from power, press the Power On button in, and hold it in. Hold it in for a count of 10 seconds. let go. Do this procedure two more times. (If the Power On LED lights up, do it again) What you are doing is clearing CMOS Error Codes. Check the Processor fan, check the Thermal Paste. Cheap as Thermal Paste is, and what it does for a job, best advice is to simply replace it. Need guidance post back in a Comment. Before beginning make sure the computer is unplugged from power, and you are FOLLOWING Anti-Static Precautions. Regards, joecoolvette"
Brian Packard;
"I cleared CMOS a few times (has jumper on board too) and even put new thermal grese on it....what finally did it was taking out the CMOS battery. As long as it's outl it works just fine, putting it back in causes an error again. Thank you all for your time however and I hope this post can help somebody else too."
Aug 20, 2012 | Gateway 507GR PC Desktop
My Maytag double stack gas dryer does not work, the screen is blank(not lighted)
Most clothes dryers have a thermal limiter or fuse, which is a heat-sensitive safety mechanism that shuts off heat to the drum or the power supply to the dryer if it overheats. Unfortunately, you can't replace a thermal limiter once it activates. The only choice you have is to replace it; your dryer won't operate properly until you do.
Although you can't reset a thermal limiter that has been blown, you can reset the dryer's two circuit breakers and restore heat to the drum and power to the dryer. However, after the breakers are reset, you'll still only have partial function of your dryer. For example, it might spin but not heat or it might initially turn on just to shut down after a few minutes. You must replace the defective thermal limiter to reinstate your dryer's full function.
Apr 16, 2012 | Dryers
My laptop's fan isn't working so my laptop shuts down on its own every nw and then which i guess is due to overheating.what should i do to repair this problem?
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Feb 19, 2012 | Acer Aspire 3680 Laptop
My tower will not power "on" I shut-down the
Remove the power cord.
Locate the 120V / 240 V ac selector switch. (within 4 inch from the power inlet)
Move it back and forth few time.
Make use it's set to the correct voltage selection.
Reconnect power cord and power up.
===== This AC selector switch can get shifted and set to different position.
Jul 28, 2011 | Acer Aspire™ T180 PC Desktop
Thermal Event
This is likely one of the following:
1) the thermal paste under the fan is dried up and needs to be redone
2) The case needs to be blown out of accumulated dust
3) the motherboard has an electrical problem (old capacitors failing etc.)
It could be all 3 issues.
If you are somewhat skilled the first 2 are easy.
The last one can be fixed in many cases
Aug 06, 2009 | Computers & Internet
Fan Malfunction??
Jul 10, 2008 | Dell Dimension B110 PC Desktop
Dell Dimension 4600 PC Desktop Logo
112 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
