Question about Compaq Presario CQ40 Series Laptop Charger (1300679LMD0015542)
My keyboard and touch pad compaq presario cq40 not working i try to reinstall keyboard and touch pad but it still not working ,and then i remove to put new keyboard but it still not working at all..... so please help me....thank before na!!!
  • Compaq Master
  • 7,627 Answers
You tried to reinstall the keyboard and touchpad hardware parts? Have you had ANY damage? Spill? OS upgrade? If you replaced the hardware is the ribbon cables connect properly?
Posted on Apr 27, 2013
3 Suggested Answers
  • 38 Answers
SOURCE: touchpad of my laptop compaq presario cq40
If you have searched for the driver and it is still not working then it is most likely a hardware failure and will need to be replaced. I recommend contacting compaq.
Posted on Mar 06, 2011
  • 2567 Answers
SOURCE: I haveMy compaq presario CQ40
This is usually a sign of either a bad LCD screen cable, a bad LCD screen, or a bad display adapter.
If you connect an external monitor & you get a picture without these red horizontal lines, then your display adapter is OK.
Diagnosing a bad LCD screen cable or a bad LCD screen requires that you disassemble the LCD screen panel, & swap them one at a time with a matching part. This way you can identify which part is causing the problem & replace it.
Posted on Sep 02, 2011
Mouse pad not working on Compaq CQ45
Go to Start
Click in box and type Device Manager
Click on Device Manager in the list
Click on Mice and other pointing devices
RIGHT click on PS/2 Compatible Mouse
Click on update drivers
Click on Search automatically for updated driver software
Mar 31, 2013 | HQRP keyboard compatible with Compaq...
Compaq presario CQ40 is overheating within 30 minutes. Although cooling fan is working (fan sound is coming)
Laptop needs cleaning! Only experienced technician should open laptop, clean cooler and change thermal paste. This will solve the problem and save laptop from serious damage.
Jan 13, 2012 | Compaq Presario Notebook
Laptop: Compaq Presario CQ40 108tu Problem: My laptops touchpad is working fine the problem is with the sroller. It's not funtioning at all. I have already re-installed the drivers, but the problem...
PLease turn off your touchpad for a while, then run it again to see how your scroller work. If still the same, your touch pad is malfunction and need to repair at dealer. Otherwise, instead of using touchpad , just use an external mouse to work on your laptop.
Regards,
May 07, 2011 | Compaq Presario 700 470024-192 Notebook
MY COMPAQ PRESARIO CQ40 TOUCHPAD IS NOT WORKING
there is a button at the top of your touchpad. . It is for locking and unlocking touchpad. . . try pressing it once. .
Sep 09, 2010 | Compaq (153515-001) Touch Pad
HP Compaq Presario CQ60-249US PC Notebook, my trackpad and mouse buttons have stopped responding. I am trying to check the cable connections and possible install a new one. Anyone tell me how to remove...
To access the mouse cable remove the battery - remove the screws securing the keyboard - carefully lift the keyboard out and check the security of the cable BUT in your instance look at the small on / off button in front of the mouse pad and ensure it is turned on ( blue light ) for on yellow off -- if it is blue go to Started - all programs - recovery manager - activate recovery manager - select advanced options - select reinstall a selected driver - select the touch pad driver - reinstall - reboot if that fails go to http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=2093&lc=en&cc=us&dlc=en&sw_lang=&product=3872064#N1238 & download & install the latest touch pad driver. If still no go your up for a new top cover assy
498410-001 Chassis top cover assembly - With touchpad (Presario)
Also it maybe the on / off cct board assy that failed
502907-001 Touchpad on/off circuit board
Jul 06, 2010 | HP Compaq Presario CQ60-249US Notebook
Entire Keyboard and Touchpad don't work! Compaq Presario CQ60
Fantastic, thank you for posting above that removing the battery sorted the problem. I had exactly the same problem as you with being able to sign in with my password but neither the keyboard or touch pad worked past this point. It's weird that the keyboard worked for signing in with the password but then didn't work anywhere else. Wonder what causes the problem coz I can't think of a logical explanation. Anyway I didn't have to hold the on/off button down for 2 mins. Just removing the battery and then replacing it cured it. I can't thank you enough for helping me to solve this.
Nov 09, 2009 | Compaq Computers & Internet
Keyboard does'nt work
Step1:Check whether the Keyboard and Touch pad BUS Cable connected to the Motherboard.
Step2:Clean and Re fix the BUS Cable.
Step3:If Still it is not working Circuit Board need to be replaced.
Pharthiphan
Nov 06, 2009 | Compaq Presario 700 470024-192 Notebook
My compaq presario cq40 laptop's logon screen didn't open. and key board, touch pad didn,t work. pls tell me a solution
my screen laptop not functional as well..seem like the power supply not connect to the screen..it because there are blink-blink light signal at the keyboard
Sep 21, 2009 | Computers & Internet
Compaq 2100 Laptop Monitor KBD & Mousepad (Not working)
The monitor is defective and should be repalced. Keyboard and mouse pad problem could be a driver problem. Try to reinstall their drivers.
Dec 02, 2008 | Compaq Presario 2100T Notebook
Compaq Presario CQ40 Series Laptop Charger (1300679LMD0015542) Logo
108 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
