What is WAN used for often? - Computers & Internet
  • Norman Peterson May 08, 2013
    I have a complete Matrix X8-C chassis with 5. X-MB-01 2. X8-FM 1. X-CM-00 2. X-M2-00 That I baught at a auction and givin the market for these I have no idea where to sell? Any help would be nice it will all be CHEAP compared to what these cost..
  • 2,878 Answers
For most home users Wide Area Network is everything outside your local network (home). Think of it as the internet. You can't really manage it, only access to is managed.
Multiple LAN (Local Area Networks) connected can be defined as a WAN, but again the access to and from is managed. This type is used within companies with multiple sites like a bank and so on.
Posted on May 03, 2013
Running BGP on WS-C3750X-24T-S using IP Services IOS?
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/15-0_1_se/release/notes/OL25302.html
Apr 29, 2015 | Cisco Catalyst 3750X-24T-S Layer 3 Switch...
11/29/2008 02:19:49 **Smurf** 169.254.255.255->> 169.254.79.64,
The smurf attack, named after its exploit program, is a denial-of-service attack which uses spoofed broadcast ping messages to flood a target system.
en.wikipedia.org/wiki/Smurf_attack
Hope this helps...
May 03, 2011 | SMC Barricade SMC7404WBRA (SMC7404WBRA EU)...
I can get a computer on the LAN but not the WAN. All the other computers work fine but I just got a new one and am having this problem.
The WAN (Wide Area Network) port is used for access to the internet through the use of a DSL or Cable modem.
You can't connect a pc to the WAN port it must be connected to one of the LAN ports.
Jul 12, 2009 | Cyberguard SG530 (SG0064US) Firewall
Continues lost of connection using router
- Kindly make sure you already configure the required ports of emule to your router.
Mar 14, 2009 | SMC Barricade N Draft 11n Wirele Router
SonyVaio VGN-TZ398U/XC - Wireless WAN: Integrated Mobile Broadb?
You are not obligated to use Sprint. If you look at the first sentence it says "Optional Sprint....'
Yes you can use any carrier you want. Most new computers today come preload with AOL, Sprint, AT&T. In hopes you will choose one of them since it is already loaded, but not activated.
Feb 04, 2009 | Sony VAIO VGN-TZ398U/XC 11.1" Laptop
How to enable WAN IP in a DI-604 Router for 3 computers
"I wanna make the 2nd pc a server but it isn't accessible through the WAN ip. "
Well that explains everything. If you want to get to 192.168.0.102 from the internet, you need to tell the router where to send packets. You do this by going to the ADVANCED section and configuring Virtual Servers. For example: If you are setting up the computer at 102 as a ftp server, ftp uses port 21. The name would be FTP, private IP would be 192.168.0.102, Protocol is TCP, and the Private and Public ports would normally both be 21. Don't forget to Enable the rule.
What this does is tell the router that when ever a request comes in on port 21, it should forward it to 192.168.0.102. To access the external side of the router you need to go to 70.55.84.233 (according to the image you posted)
Jan 03, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
No wan light
If no wan light bypass the dlink router and check if ethernet cable connected to wan port is working. Once you are able to go online through modem connect cable to WAN if light does not go on log into oruter and clone mac address and save settings.If doesnt work powercycle router and turn modem on first then router next if doesnt work upload latest firmware.
Sep 05, 2008 | D-Link AirPlus DI-524 Wireless Router
Difrence of lan wan
The Lan limit on unshielded twisted pair cable (UTP) is 300 ft for a local area network (lan). The cable uses the 802.3 Of course if fiber is used in a LAN then this # can be extended substantially.
Now the main difference between the LAN and Wide Area Network (WAN) is that LANs typically have 1 brodacast domain and froward packets at data link (layer 2 of the OSI) level using MAC addresses.
The WAN operates at the network level (layer 3 of the OSI). WANs are and reads IP addresses. Routers can extend far distances (as you said 40-60km) and band with depends on distance. the further away, the more attenuation on the line.
I hope this helps.
A wide area network
Jul 10, 2008 | Computers & Internet
Using just the VOIP part of a Belkin all in one router??
You will probably need to set it up differently, I do not know the belking router, but normally the VOIP functions only work on the wan port of these routers so you should make the connections as follows:
INET ---> (wan) DLINK (lan) -----> (wan) BELKIN (voip) --> Phone
|--------> Wired Computers
|--- ) ) ) Wi Fi computers
On the DLINK enable DHCP and set a fixed IP for the Belkin router, either by setting the belkin in an IP outside the DHCP pool or setting it from the DHCP server.
This configuration workd well with a DLINK and a Motorola (vonage) router I have.
Apr 23, 2008 | Computers & Internet
Computers & Internet Logo
505 people viewed this question
David Payne
David Payne
