Write a pseudocode for the cashregister program, that will enable cashier to input price, then the program must calculate sum and of all items, and also program must calculate for vat, vat is calculated as the sum *0.25. total is calculated as sum + vat. then the program must output sum, vat, total.
SOURCE: Changing the % tax setting on my Casio calculator
step 1 pess the AC button step 2 press and hold for two seconds the % button step 3 press the tax+ button step 4 input 17­.5 step 5 press the % button that should be the tax set you can check it is set correctly by pressing the AC button and then the tax+ and 17.5 should be displayed
Posted on Apr 12, 2007
SOURCE: Percentage button!!
The Casio MS-80TV requires you to input percentage calculations differently than other calculators. To calculate percentage change addition for this example, you must input "12000X20%+", for subtraction, you must input "12000x20%-".
Posted on Sep 27, 2007
  • 3 Answers
SOURCE: Canon F-502 statistycal scientific calculator
As I added on to the previous solution on the other problem.
"Okay, I did what the best solution did and worked with it.
"1. press 2nd F (left top corner)
2. ENG/FIX (the button next to 2nd F)
3. press 0 (if you don't want calculator to round off any decimals)"
In order to get your exact value of pi, in step #3, instead of 0, press the decimal [ . ]
This should give you no decimals when entering a number and give you 3.141592654... when you input pi.
Hope that works/helps."
Posted on Nov 09, 2007
SOURCE: how do I change the
How do I program tax rate into my calculator? Non-printing models (also applies to HR-8TE printing calculator):
1. Press [AC]
2. Hold [SET/%] key for about 2 seconds
3. Press [TAX+]
4. Input the tax rate
5. Press [SET/%]
Posted on Dec 10, 2008
SOURCE: How do I set the GST/VAT tax rate on a Casio WM220T calculator
This works on several different casio calculators
Press AC butoon
Press AND HOLD % /Rate Set button for 2 to 3 seconds - This is important
Press Tax+ button
Input the tax rate you want eg: 12½% = 12.5
Press the % /Rate set button again
Voila
Posted on Sep 01, 2009
All my register will is beep
If the beep is happening every second or so with out you touching it, the printer has a fault. If it happens when you press buttons, try this: If you press clear (CL) and press some of the numeric buttons, you should see numbers appear on the display. If not, probably a keyboard fault. If you can get numbers but just a beep when you press a department (item button) then you are not logged in. Enter your secret PIN number and press the CASH# (cashier number) button in the top corner (on most models in this series) to log on. If you need to program new secret PIN numbers, one of the users has the programming manual here:
https://the-checkout-tech.com/manuals/cashregisters/Sharp7.php
Apr 16, 2016 | Sharp ER-A320 Cash Register
Program a cashier onto a Casio TK 7000
It should be the 05 file on that machine so you just add the cashier number in front of the file number (105 for cashier 1, 205 for cashier 2 etc). So go to program 2 then use the 05 code as I've said to edit the text. The text entry procedure is shown in the manual so just run through that to familiarise yourself.If you don't have the text entry information in your manual, then you have the wrong one. You need this one:
http://the-checkout-tech.com/manuals/cashregisters/Casio_TK-6000_TK-6500_TK-7000_TK-7500_TK-T500_CE-6000_etc_dealer_manual.html
Dec 07, 2012 | Casio Parts Cash Register PC Desktop
I HAVE A SHARP ER-A440 CASH REGISTER, AND AM PROGRAMMING THE CASHIERS, IT ACCEPTED THE FIRST 4, BUT WILL NOT GO ANY FURTHER, AND IT IS SUPPOSE TO GO TO 99.
4 Cashiers are standard. Your dealer should have set extra extra cashiers in memory if you needed them. If you want to open more memory, you will need a service key and the memory codes from the dealer manual. If you don't have the dealer programming manual, C-tech collective have it here:
European version: http://the-checkout-tech.com/manuals/cashregisters/Sharp_ER-A440_and_ER-A450_programming_manual.html
America/Canada version: http://the-checkout-tech.com/manuals/cashregisters/Sharp_ER-A440_programming_U_and_A_ver_manual.html
Aug 06, 2011 | Casio Parts Cash Register PC Desktop
Create javascript code whose function is to compute the sum of two inputs?
The following code will dynamically calculate the some of the first two fields:
Enter first number:
Enter second number:
Their sum is:
Best Regards, Ben
Jun 29, 2011 | Computers & Internet
HOW DO I CALCULATE STANDARD DEVIATION FOR CALCULATOR T1-30XA
Hi dear friend,
I am providing it with an example.
- I am sorry that the instructions from the maker of the calculator on how to calculate a standard deviation fell short of your expectations. All you have to do is follow them key stroke for key stoke, but enter your own data. If a number is repeated 3 times like the number 55, you can enter it 3 times or use the shortcut in the exemple
55 [2nd][FREQ]3 [Sigma+].
If you make a mistake and enter the wrong number, use the [Sigma-] key to remove it. That is similar to what a cashier does when an item is entered twice: it is entered a third time but with minus sign.
Every time an item is entered, the display shows the total number of items so far. When it is finished the cashier press the key that sums up the prices to get the total. This is the role of the [2nd][Sigma X] key combination.
The average number of the data is obtained by the [2nd][x bar] combination. The last two key combinations display the two type of deviations.
I hope this will help you. Please vote for me.
Thanks in advance.
Jan 30, 2010 | Texas Instruments TI-30XA Calculator
How do I find the standard deviation?
Here is a detailed exemple. Hope it helps.
Some comments on the various variables (should the information be needed. If not need, please skip it.)
1.All you have to do is follow the instructions key stroke for key stoke, but enter your own data.
2. If a number is repeated 3 times like the number 55, you can enter it 3 times or use the shortcut in the exemple
3.If you make a mistake and enter the wrong number, use the [Sigma-] key to remove it. That is similar to what a cashier does when an item is entered twice: it is entered a third time but with minus sign.
4. Every time an item is entered, the display shows the total number of items so far. When it is finished the cashier press the key that sums up the prices to get the total. This is the role of the [2nd][Sigma X] key combination.
5. The average number of the data is obtained by the [2nd][x bar] combination. The last two key combinations display the two type of deviations.
Check the theory you have been taught and try again. If that is not the type of statistics you were supposed to do, then give more information.
Oct 28, 2009 | Texas Instruments TI-30XA Calculator
On our rpe system there are some tables that will not closeout and are showing active for several days the same item(s) ring up at different prices
Sounds like two different problems. The tables not closing out are probably one of two things. The invoice got put on hold or the cashier trying to close the table didn't open the table or doesn't have correct permissions to close table. Worse case scenario is a corrupt entry in database.
Different prices on same item could be someone playing with the special pricing on the item or if you have time based menus setup, they are actually pointing to different items that display the same.
I program rpe menus remotely and could give you a hand. Contact me at sysadmin@ccybernet.com or call 814-226-9612.
Oct 07, 2009 | Pc America Restaurant Pro Express
How do I program the calculator tax+ Tax- buttons?
1. How to set/ change "Tax Rate"
(1) If "Rate set" is printed above [%] key with your calculator,
1. Press [AC] and hold [%] for about two seconds.
2. Input Tax Rate and then [%].
* You can check Tax rate by pressing [AC] and then inputting [TAX+]
(2) If "Set" is printed above [%] key with your calculator,
2. Input [TAX+].
3. Input Tax Rate and then [%].
2. How to calculate Price-plus-Tax and Price-less-Tax.
(1) How much is Price-plus-Tax of 100?
Press [AC], and input 100 and then press [TAX+].
Calculator will display 105 if tax rate is 5%
If you press [Tax+] again, it will show the tax amount..
(2) How much is the Price-less-Tax of 105?
Press [AC], and input 105 and the press [TAX-].
Calculator will display 100 if tax rate is 5%
If you press [Tax-] again, it will show the tax amount..
Jul 29, 2009 | Canon LS-100TS Calculator
Sharp er-a330 cash register
That's a programming option -- whether you have to sign in for each sale, or can just keep going until you do a Cashier Z reading. But this on is not in your Owner Manual. Most Sharpregisters have a deeper level of programming, called SRV mode. It's not marked on your mode switch, but it's one click past PGM. You need a SRV key to access it and a Service Manual to know what's there. Sharp doesn't supply the SRV key or instructions, because it allows you to change Grand Totals and other things that would allow an employee to steal without detection.
Any servicing Sharp register dealer should have the SRV key, and this change is simple enough that they might do it for free if you bring the register to them along with these instructions and ask nicely.
Turn to SRV mode.
910 . @/FOR CA/AT
Turn to REG mode.
Sign in and try running consecutive sales or No Sales without signing in between them.
You can still change Cashier numbers between sales by signing in with a different number.
If you touch the CASH # button without putting a number in first, it will sing out you current cashier, and you'll need to sign someone in again.
If you are in X/Z mode, and you touch the CASH # button, it will print a Cashier Z reading and automatically sign out all cashiers. Sign in before your next sale.
Good luck,
Eric
Sep 02, 2008 | Monroe 2020Plus Calculator
60 people viewed this question
jasbo
jasbo
