Question about Sony VAIO Computers & Internet
How do I Power off restart
Is there a power off Restart function?
  • Sony Master
  • 7,627 Answers
For What? Make and Model of Laptop.
Posted on Apr 19, 2013
Error code E000002
That is the error code for a power supply failure or the printer not receiving enough power to heat the fusilier to print. This can be due to an power outage or not enough electricity flowing into the machine.
If the machine is receiving full power, you'll need to get rid this error through entering service mode.
1. Hit "additional functions" key on the printer's keypad.
2. Press and hold 2 & 8 at the same time for one second.
3. Hit additional functions key again.
NOTE: from this point forward you'll be in service mode which has a 60 operational second window. After 60 seconds it will exit out of this mode and you'll have to start over.
4. You've entered service mode. Now hit "copier"
5. "Function" key
6. "Clear"
7. "Err" . There should be an error or the error code in this section select this part.
8. Hit "ok"
9. Restart the printer by switching off the physical black power switch on the side and switching it back on.
The printer should restart and be working normally.
Feb 21, 2016 | Office Equipment & Supplies
Want to turn off Auto-restart function of haier split ac
I do not know anything about this but from a manual I have seen its tied in with Timer and Sleep functions there are a lot of instruction manuals ou on the web but you description is to generic you need a model number of which there are a lot.
HSU-09LEK13/R2(DB)
HSU-12LEK13/R2(DB)
HSU-18LEK13/R2(DB)
HSU-24LEK13/R2(DB)
HSU-09LEK03/R2(DB)
HSU-12LEK03/R2(DB)
HSU-12CKAS(R2DB)
HSU-18CKAS(R2DB)
HSU-12HKAG(R2DB)
HSU-18HKAG(R2DB)
Just a sample look for a number on the device which may be under a cover.
As its software controlled they do need to reset themselves as to how long this takes varies from machine to machine.
Hope this helps
Apr 05, 2012 | Heating & Cooling
How restart laptop using f bottons
You don't restart a laptop using the Function Keys (F1 thru F12). You restart the laptop by hitting the power button. The function keys will allow you to boot the laptop in SAFE MODE if you repeatedly hit the F8 key until you see the Safe Mode option after you hit the power button. Function keys will also allow you to change the boot order, go into the BIOS or Setup to change things also. You need to state your problem as to what is going on with your laptop.
Mar 19, 2012 | Computers & Internet
Help have onix split system air con and remote not working and it s the only way to turn it on have tried every where to get one model no is TEM-84CHSBE heat unbearable in summer nth qld aust.
Auto-restart Presetting:
The appliance is preset as no auto-restart function by manufacture. If Auto-restart function is needed, follow the
step below to activate this function:
1) Make sure the Air-con's power is off:
2) Press down and hold the Emergency button (ON/OFF )on the indoor unit then electrify.
3) Keep pressing the Emergency button for over 10 seconds until three short beeps are heard.
The Auto-restart function is then activated. To cancel the Auto-restart function, repeat above procedure until four
Remarks: When remote controller is out of work, open the panel and you can see emergency button there, see the
The emergency button for 50, 70, 90 series is at the top right, see " ON/OFF " button there.
Auto-restart set:
the appliance is preset as no auto-restart function by manufacturer. If Auto-restart function is needed, follow the
below step to activate this function:
1) Make sure the Air-con's power is off .
2) Press down and hold the Emergency button (ON/OFF )on the indoor unit then electrify .
3) Keep pressing the Emergency button for over 10 seconds until three short beeps are heard, then Auto-restart
function is activated. To cancel the Auto-restart function, repeat above procedure until four short beeps are heard.
Oct 31, 2011 | Heating & Cooling
Our requaired is without any in puts(remote start and Manula Start) AC staret after power restart,please gaide to me.
first you need to check if your A/C has Auto Restart function. How?- turn power On from the circuit breaker, if the A/C unit start working at your last-time program you have the Auto Restart function. In that case you never shut it down by the cutting off the current, forever turn it on/off by the remote controller.
Feb 23, 2011 | LG Heating & Cooling
Canon ir 3300 ,this has E000019-0000 problem ,how to solve it
canon ir3300 error code E000019-0000, hOW CAN I SOLVE IT ???
NO KEY IS FUNCTIONING NOW.................
mail at chandaxerox@gmail.com
Feb 19, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
The power snapped off for a few seconds and now my computer will not restart it trys to then goes to the screen that tells you windows couldnt restart and asks how you want to try again i have tried to...
Try this first
http://www.fixya.com/support/r4501608-when_windows_xp_start_primary_fix
if that doesn't work, try this:
http://www.fixya.com/support/r4501848-when_windows_xp_start_secondary_fix
Finally, do this:
http://www.fixya.com/support/r5438565-when_windows_xp_start_final_fix
var fctb_tool=null; function FCTB_Init_a7d37541795e492ebe25472cdafbc42a(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_2a443faf710c4d7d9d373ab98411f540(t) { fctb_tool=t; start(fctb_tool); }
Dec 21, 2010 | E-Machines eMachines Desktop PC
I need to know how to reset my printer, I 've cleaned the pads, but nothing... Thank you in advance...
Power down the Canon Pixma IP4300. Once it has shut down, leave it off for a few moments.
Hold down both the "Resume" button and the "Power Button." When the printer begins to restart, release the "Resume" button but continue pressing "Power."
Push in the "Resume" button twice, then let go of both the buttons. In a moment, a green light flashes a few times.
Press the "Resume" button four times once the green flashing has finished.
Push the "Power" button again until the printer shuts down. Wait a few seconds, then press the power button again to restart the device. The Canon Pixma IP4300 will now function properly. for more information http://www.fixyourownprinter.com/forums/printer/67824 hope this helps you.
Aug 18, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Apple G4 15" has been charging all night - will not power on? Ideas?
If you are plugged into the AC adapter, it should power on even with the battery removed.
Turn off the computer. Remove the AC adapter plug and remove the battery.
Reset the power manager by simultaneously pressing and then releasing Shift-Control-Option-power button. Do not press the fn (Function) key while using this combination of keystrokes.
Wait 5 seconds.
Press the power button to restart the computer. If it still will not restart, you may need to contact a local serviceperson.
Jul 01, 2010 | Apple PowerBook G4 Mac Notebook
Computers & Internet Logo
21 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
