Question about Gucci Watches
I've just bought a Gucci 126.4men's watch and can't open the clasp - how does it work?
Can't open clasp to wear new watch
SOURCE: Watch clasp on Tag Heuer
http://www.worldofwatches.com/cust/sizingwatch.asp?d=0
Posted on Dec 26, 2008
SOURCE: I cant open my brand new watch ...HELPPPPPPPPPPPPPPP!
I just recieved a Moldavo Men's Junior Sport (Model # 0605105 with certificate of authenticity) as an award -- but the instructions didn't bother explaining how to put the watch on!
For any hidden clasp band, see this web page (excerpt below):
Refer to the "Hidden Clasp" diagram and follow the instructions under the diagram:
cad9c3e.jpg To open this clasp, reach under the bracelet band and lift upwards. The band extends to allow for easy removal.
Posted on Jun 02, 2009
SOURCE: How do I open my gucci watch to change batteries?
Get a #0 1.6mm precision Phillps screwdriver (these are brittle) or similarly strong, thin piece of steel.
Hold the watch upside-down across your index finger while gripping the straps tightly between your index finger and thumb on one side, and index finger and middle finger on the other (ie. squeeze the strap around your index finger).
On the underside of the watch, stick the tip of the screwdriver under a square slot where the watchband is connected at an angle perpendicular to the strap. Firmly pry upwards on the cover on one side, then the other, until the cover pops off.
The battery is a Renata 379.
To put the cover back on, align the square slots precisely with the ends of the straps (keep these out straight), then firmly push the cover straight down until it "snaps" shut.
Posted on Jul 25, 2009
  • 65 Answers
SOURCE: How to Open a Gucci watch
Most watches are either screwed on and typically have a series of small notches around the circumference of the case back. A special tool is generally called for. Otherwise they are "snap back" . These are simply pressed on. To remove you can carefully use a regular knife in the absence of a "case knife". There is usually a small gap/groove/notch area to insert the balde and lift the back off.
  • 12 Answers
SOURCE: how to unlock clasp of the invicta square angel chronograph watch
http://www.bluedial.com/clasps.htm
Posted on Jul 15, 2010
HOW DO YOU REMOVE A GUCCI WATCH FROM YOUR WRIST?
This is so called ''snap-on'' butterfly clasp. There is no release mechanism and simple pull is needed to open it. Use your strength on do not worry - it won't brake.
Aug 26, 2014 | Paolo Gucci PG501TW Wrist Watch
The clasp on my steel watchband pulls away from the band creating a large gap. it looks bad and catches on things. what do i do?
You need to make sure that if you had the watch band adjusted they did not adjust it at the clasp. When you adjust the watchband links should be removed if you adjust it at the clasp the band keeps pulling open. When you open the clasp fully make sure the pins are on the end holes. If the pins are in the end holes then, the clasp is probably sprung somehow and you will need a new one or have a jeweler or watch repairman fix it! You may also be able to order a new clasp from manufacturer! Hope this helps!!
Sep 21, 2011 | Watches
Gucci watch 19 years old had battery changed and glass now full of condensation when I wear - clears up when not worn?
Thank you for contacting FixYa.
After a battery is replaced, some watches require new gaskets, or O rings, etc to keep the watch water resistant. Prob the case with your watch. I would check with a qualified local watch repair or try Gucci at following link:
http://www.gucci.com/us/assistance/assistance
Best regards. Jewel
Oct 04, 2010 | Watches
Defective watch band clasp for Skagen #M228BB
some of these clasps are a pain. but keep trying it will clasp, slide it back and forth slightly while applying some pressure you will feel a little difference then snap it into place. there are only certain spots on the band where you can clasp it. where you are trying may just not have an indention.
Aug 25, 2009 | Skagen 355LGSC Wrist Watch
Can't fugure out how to open the clasp on my new watch
I did it
The clasp separates very close to the M on the middle of the band....just press gently and the clasp separates at that point!!
Just be gentle and it works every time!!
Apr 05, 2009 | Movado Kardelo 0605479 Wrist Watch
Larger clasp
Unfortunately, I do not think this is going to be an easy fix. You may want to take it to a local independent watchmaker. Gucci may sell larger clasps but they may be difficult to find even from them directly. I have looked at the watch you have. It it was solid gold a Jeweler could just make it a touch larger.
Looking at the clasps the options i see is
Have the bangle removed and wear it on a leather strap,
Possibly remove the clasp where it says gucci and have the pins laser welded so that the clasp stays in a fixed position similar to a bangle.
mike --consumerwatchguide.com
Jan 02, 2009 | Gucci 1500 YA015512 Watch
How to open Baume & Mercier Hampton Milleis ladies stainless band
Looking at your watch it looks like the clasp on the SS model is just a double deployant preasure fit. If it is brand new sometimes these style of deployants are vary tight.
It is Stainless Steel it is vary difficult to break it looking at the construction of the bracelet.
Basically you just Pull, there is no button it is just pressure fit.
mike -- consumerwatchguide.com
Jan 01, 2009 | Baume Et Mercier Hampton Milleis MOAO8242...
Jan 09, 2008 | Movado Kardelo 0605479 Wrist Watch
Citizen Eco-Drive mens watch
Hi if it is anything like the other eco watches ---------
just under the clasp that lifts up you will find a little button, it is about 2mm long and there is one on either side, push these in with your thumb and index finger and it should release the clasp.
When you close it up,you will feel it `pop` back home again.
Dec 26, 2007 | Citizen Eco-Drive BL006056H Wrist Watch
Watches Logo
311 people viewed this question
Top Gucci Watches Experts
Lawrence Oravetz
John mullen
Are you a Gucci Watch Expert? Answer questions, earn points and help others
