Question about Whirlpool Duet GHW9150P Front Load Washer
Desconnecting electrical from water inlet valve
I am replacing the water inlet valve of my Whirlpool Duet Washer. I am having a hard time disconnecting the black and white capped electrical lines from the valve. I'm afraid if I pull on them, I'll ruin the electrical. Is there a secret? THANK YOU SO MUCH FOR YOUR ADVICE.
  • tperetz Mar 12, 2009
    Thank you!
    President:
  • Whirlpool Master
  • 2,651 Answers
No secret grab em withthe pliers and pull, Ive yet to break those fitings
Posted on Mar 12, 2009
My Whirlpool Duet washer is making a loud squealing noise when filling with cold water, and/or the water is reduced to barely a trickle. It does not make the noise/reduce cold water flow every time.
Hi.
Try to remove the sand filter(s) from the inlet hose. Both on the valve and on the water crane(tap) end. Common problem.
Usually this is the problem, but not always.
/ Geir
Technical Engineer
Sep 27, 2014 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
My whirlpool steam duet washer won't pour water in the wash cycle
There is no output from the control panel to switch on the inlet valve, so check the inlet valve at this time of the cycle. Also check the water level pressure sensor switch.
Choose another program to confirm if not the controller seems to be suspect.
Jan 24, 2013 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Our front load whirlpool washer gradually fills over the course of the day it is like there is a slow leak into the washer
water inlet valve in the machine is either sticky or faulty. get it replaced. till the time, after wash, keep your water valve (which supplies water to the machine) closed
Mar 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Replacing water inlet valve for Whirlpool Duet
Thats a two man job that you are trying to do yourself. The top of the washer has to be removed to replace the valve. Get some help to remove the dryer from the top.
Mar 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Thw washer fills with water when off
The inlet valve is faulty and you have to replace it. It is located on the right side of the machine viewed from the rear where the fill hoses are attached to.Turn-off the water supply, unplug the machine and do the following:
  1. Remove the three screws holding the top panel in place.
  2. Disconnect the hoses and electrical connections to the water inlet valve.
  3. Remove the mounting screws holding the water inlet valve.
  4. Reinstall the replacement valve.
  5. Reinstall the hoses and the electrical connections.
Replacement valve part number for Whirlpool Duet GHW9150P front load washer is 906483.
Jan 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water filling to washing level when washer is not being used.
sounds as if you have a bad inlet water vavle, it doenst complety shut off after use, and waer will trickle in( adding up to quite a bit in a day) youll need to replace the water inlet valve(directly behind themachine where the hoses hook into). in the meantime turn off water inbetween uses
Mar 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Fills on its own door open or closed
I would bet the water inlet valve is weeping. It may not seal shut every time. It could have a piece of rest stuck in it also. It's cheap and easy to replace. The part # AP3128776.
Feb 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washer fills with water by itself
sounds like a faulty water inlet valve, not seating properly after closing the valve.replacing the valve is the only solution to this problem, in the meantime you can turn off your water supply in between doing loads.
not a bad habit to get into!!!!
Mar 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
78 people viewed this question
Dan Webster
Dan Webster
Sal De
