Question about Car Audio & Video
Pioneer a 307R speaker capacity - Car Audio & Video
POWER CAPACITY SIZE
The problem post of yours' has no sufficiant details to place a solution. Provide more details please. google.com/+GopakumarGopalan
Nov 02, 2013 | Pioneer SLX70C elite flat panl center...
Right outputs are not working
The right side output transisters are probally fried, End if you hook up both speakers to the left A&B channel you will do worse damage to it buy over loading it, Over it,s (OHM) Capacity, That mostly causes them to over heat end go up in smoke,
Dec 06, 2012 | Pioneer VSX-D606S Receiver
Is it totaly ok to just connect one pair of JBL Control 1 speakers to this receiver? Here are some of the specs. Frequency Response: 120 Hz to 20 kHz Power Capacity: 150 W Sensitivity 87 dB SPL Nominal...
The only relevant speaker spec is the impedance. As you probably realize the Pioneer SX-255R recommends 8 - 16 ohm speakers.
Four ohms is on the hairy edge of too low. You could certainly try it but if any strain or excessive volume is used you could see something go poof!
The low end of 120Hz says don't push the bass to them.
Jul 14, 2011 | Pioneer SX-255R Receiver
Dear expert I am the Israeli distributor for Paradigm, MartinLogan, Anthem and more. I have a customer who has the Pioneer VSX-D606S that the subout is not working. He does not have the manual and even...
I can't find a free manual to quote.
There are three parts to this scenario and only one named.
First, you need to set the receiver up with speaker definitions and capacities, subwoofer presence, bass management and Test Tones to verify it CAN make each speaker work.
The DVD player has a piece of this, too. It probably has a menu for speaker configuration that needs to be set up. And its digital output prbably has a setting like DTS/Dolby Digital/PCM. Look in the manual. Look in the manual.
Then there's the sub itself. Is IT working? Jack it into any other pre-out as a test.
Mar 23, 2011 | Pioneer VSX-D606S Receiver
Amp comes on running 2 12" 450 watt pioneer subs, volume only seems to be about half output, with speakers bridged
This could be the reason. If you look at the specs for this amp you will see that the continuous power out is rated for 380W bridged. The speakers rated at 450W should be able to handle close to 315W continuous. Now if you split these numbers being you have bridged these speakers, you drive each one up to about 190W continuous. The speakers are being driven approximately by 60% of the rated capability. I personally like to keep it right where you got it, not exceeding 80% of the speakers rated capacity.
Here are the specs for the AMP:
  • Specifications
  • Peak Music Power 760 Watts
  • Number of Channels 2
  • Load Impedance Capability 2~8 Ohm (Stereo), 4~8 Ohm (Bridged)
  • Continuous Power (4 ohm) 125W x 2
  • Continuous Power (2 ohm) 190W x 2
  • Continuous Power Bridged (4 ohm) 380W x 1
  • Frequency Response 10Hz ~ 50kHz
  • Total Harmonic Distortion 0.008%
  • Signal-to-Noise Ratio 100dB
  • Dimensions 12" x 2-3/8" x 12-3/4"
  • Features
  • Bridgeable
  • Channel # Capability 1/2/3
  • PWM Regulated MOSFET Power Supply
  • Screw-Type Speaker Terminals
  • Balanced Isolator Input Circuit
  • RCA Inputs 2 Channel
  • Input Level Control Hi-Volt (200mV ~ 6.5v)
  • Built-in Crossover Selectable LPF (80Hz, -12dB/Oct.)
  • Aug 06, 2010 | Pioneer GM-5000T Car Audio Amplifier
    Pioneer TS-W31C car speakers
    i would recommend 12awg speaker wire
    Jul 12, 2009 | Pioneer TS-W31C Car Speaker
    Need the speaker wiring diagram for Pioneer KEH-1080
    Yellow = +12V constant; Red = +12V switched; Black = ground; Blue-white = remote on; White/White-black = FL speaker; Grey/Grey-black = FR speaker; Green/Green-black = RL speaker; Violet/Violet-black = RR speaker.
    --- hope that helps ya
    May 20, 2009 | Pioneer Car Audio & Video
    Pioneer cs-g404
    My experience with them is that they would work as they don't change much from model to model year. You may call the customer support and they will most likely help you
    try CS @ 800-421-1404 or try the parts hotline to investigate
    (800) 228-7221
    Mar 15, 2009 | Pioneer CS-G204 Speaker
    Speakers
    400 watts delivered to 300 watt speakers the only way to do this would be to wire two subwoofers in series so that the power needed to drive them will be 600 watts to max, however this will increase your impedance on the speaker (8 ohms) load so what you can do to compensate is get an 8 ohm 600 watt resistor and put it in parallel with the speakers you will then have 4 ohms of impedance at a total capacity of 600 watts of power In other words the amplifier won't blow these out now.
    Oct 08, 2007 | Pioneer GM-X722 Car Audio Amplifier
    Car Audio & Video Logo
    15 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
