Question about Water Heaters
Sime format 30 bf not lighting - Water Heaters
I have a sime ecomfort boiler.. And no hot water.nit is showing code AL01. We have tried to reset a number of times and error code is still showing. Can anyone suggest any fixes?
The Sime documentation says for AL01 you need to "Request assistance from qualified technical personnel." Not really helpful.
Nov 01, 2014 | Water Heaters
Sime boiler
The ignition switch is usually next to the thermostat in the outside
area most times colored (red or black) . If not you might just have to
use a regular match to get the pilot started without the igniter switch.
Apr 07, 2014 | Water Heaters
Sime boiler pilot light
Sounds like an old boiler. It is not on timer and has to be lit manually. Push in the gas button and hold and push the sprung ingnition button to greate spark. Continue to hold in gas button 1-2 mins and release. The pilot light should then stay on. The flame will have heated the sensor in the combustion chamber and the boiler thinks that there is a flame and will allow the main gas jets to light when demanded . If the flame does not stay on clean the sensor prongs with emery cloth but do wait until they are cooled. You have open up the combustion chamber for access
The 1-2 mins above varies
New sime e comfort 25HE boiler problems
It not wired in right that why its coming on when it is off The boiler is over riding the programmer when it is off .
The boiler should call for heat if programme is on it sounds like boiler is wired into the 24hr mode or over ride mode that why it is coming on . google wiring for y plan heating system. this will help you fault find on this . changing vales and thermostats will not help you . Hope this helps .
Mar 05, 2017 | Water Heaters
SIME ECOMFORT 25 HE BOILER - Dripping water ???
If it's from the condenser, it's ok
Should really be piped away but a container under is also ok
Dec 20, 2009 | Water Heaters
I dont know how to use my friendly sormat sime 80e heating
best to apply to any local merchant for a manual will get you one sent through the post best of luck
Jul 05, 2009 | Water Heaters
I have a Sime Super 90 Combi Boiler. How do I start the pilot light? Thanks
does it have a little red button on the right hand side of the gas valve? if so you must put the gas valve button in the pilot positon and push it down and hold it, then click the red button {push it down} it will click and look at it keep clicking while holding down the button on the gas valve eventually when the gas gets thru it will light could take several clicks of the ignitor
May 18, 2009 | Water Heaters
Sime 80E friendly format boiler
Sounds like a control board or wiring to the unit has shorted out.
Apr 08, 2009 | Water Heaters
Sime Domestic Boiler
could it mean circulation alert!!!
Mar 22, 2009 | Water Heaters
Water Heaters Logo
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
