I turn on my desktop the skreen lights up then after just a few seconds it goes into sleep mode then i have to turn it of at the mains
Http://www.nextofwindows.com/what-is-hiberfilsys-and-how-to-delete-in-windows-7-free-up-hard-drive-space/
ken if you mean hibirfil.sys READ ALL ABOUT IT HERE.THIS IS FOR WINDOWS 7.OTHER PAGES FOR XP.SEEK ON INTERNET.
but you got to have a desktop.try to load wmp and a playlist.if time.
let me no if it works.
The computer is not going into sleep mode. it is a problem though. Your computer is not giving a video signal to the monitor and it is the monitor going into "Sleep mode".This could be any number of things -but an easy fix is to check your RAM and that your connections are all good. (not necessarily in that order).
SOURCE: Monitor goes into sleep mode after a few seconds
Click on Programs --> Setting --> Control Panel
Choose the "Power Options"
in the "power schemes" Choose the Turnoff Montior, turnoff HDD, system standby
and system hibernate as "Never" in each combo box and clikc on apply.
repeat the above process for every power scheme options
Let me know if your problem is solved and rate me as FIXYA!
This is normaly cause by incorrect power management settings.
check power management setting in both windows and your computers bios
you will not need to worry about the power management settings of the bios when an operating system such as windows is loaded.
Loch Hiam
Az.
SOURCE: turn off sleep mode, It causes prob. turning on programs to use computer
I have a hp desktop, each time I push the sleep button, the computer goes to sleep, however about 10 seconds ofter entering sleep mode it starts up again.How can I make the computer stay in sleep mode. thanks
SOURCE: Monitor keep going into "sleep" mode
try to reseat the memory modules and restart the computer and computer boots to normal mode/then go to power options in control panel and disable the sleep mode option for the hard disk
SOURCE: Computer goes to sleep before it even starts up
Hi there, it appears as though the Power Options are set too short a time and the PC is going into sleep mode. Go to Start menu/Control Panel and look for Power options. Set them all to "never" This will prevent her PC from going into sleep mode. Good Luck.
