I have a Defy Automaid 600 DAW322 I think with pressing the front buttons I have locked the machine somehow. The machine fills slightly with water then stops and nothing more happens. Does it sound
I see on the front of the machine under the two buttons there is a little lock sign thats why I am thinking I perhaps locked the machine.
ginko
  • 19396 Answers
SOURCE: Washing machine fills in the water but does not start the wash cycle
The fact that it does not fill completely can be related to a problem with the water-level switch, that regulates the water level.
See from Repairclinic:
"This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch."
However, when it is only the switch the mashine usually completes the cycle, but with less water than normal.
A possibilty is that either the timer is faulty or there is a problem with the water supply.
Check that water is coming from water supply with regular pressure, and that hoses back there are not obstructed.
More likely you will have to replace the timer.
See again from Repairclinic:
"When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water."
  • You can find parts at the following websites, you need to input your model number. If the part is not listed contact them.
    Repairclinic
    Partselect
    Don't forget to rate the solution.
    Many thanks.
    Posted on Sep 01, 2008
    buzzwood
    • 65 Answers
    SOURCE: INGLIS WASHING MACHINE - WATER STOP
    Either call the store where you purchased the machine or refer to your users manual, should have a trouble shooting guide in the back of the manual.
    Posted on Jan 05, 2009
    • 291 Answers
    SOURCE: defy automaid instruction manual how to use
    click the link below for defy automaid manuals and instructions guide:
    http://www.defy.co.za/images/Manuals/BEKO_BOOK.pdf
    thanks and plse do not forget to accept the solution.
    Posted on Apr 03, 2009
    • 713 Answers
    SOURCE: MW512AU Fisher and Paykel top load smart touch
    Hi Des, just read your posting.Now when you turn on the machine you say that some lights light up and it starts to beep.These lights will be in a row of 8 lights.Starting from left to right which lights are lit when the machine is beeping?Is it he 3rd and 5th or the 2nd and 7th ---etc---?Please reply with additional information on the question and I can help you rectify the fault.Looking forward to your reply.
    Posted on Aug 18, 2010
    SOURCE: My Defy Automaid 600 does not dain the water out,
    My defy automaid 600 does not drain the water. The pipes is not blocked.
    Posted on Mar 26, 2011
    Why would my Defy 600 Automaid drum stop spinning?
    The pressure sensor might be faulty. Something is telling the control that it is too full of water so the pump starts to empty it to avoid flooding. This is usually the water level or pressure switch.
    See manual for your unit at this site.
    Pre
    Sep 05, 2014 | Washing Machines
    My DEFY Automaid 600 does not heat the water
    It is possible that the thermostat may be causing a problem if it is faulty. It might be sending wrong signal to controller confusing it to think water temperature is already reached and shut off the heater.
    The thermostat may look like this part.
    http://www.macspares.co.za/laundry/thermostat-defy-automaid-std-models?cPath=1_195_175&
    Apr 25, 2014 | Washing Machines
    Hi, I own a Defy Automaid 600 and when I run a
    Hello
    Remove the detergent tray and look in to the top were the tray goes in there is a water dispenser there with a lot of hole check that non of those holes are not blocked, if so use a tooth brush to clean the holes.
    Thanks
    Jun 15, 2011 | General Washing Machines
    Our defy automaid 600 daw 322, will wash, but will not spin or rinse
    My Defy Automaid 600 spin and drain without washing but only drain and do not spin with washing in (i have put only 1 t-shirt in - and still don't spin)
    Jan 23, 2011 | Washing Machines
    Defy automaid instruction manual how to use
    Apr 03, 2009 | Washing Machines
    Washing Machines Logo
    Top Washing Machines Experts
