Question about Sewing Machines
Tajima TMFX II NOT TRIMMING IN BETWEEN THE LETTERS
I bought this used machine and felt like it was a great machine. I am a new company with tons to learn about settings on the control panel. I was wondering if I could change settings for it to trim properly? Thanks in advance.
2 Suggested Answers
SOURCE: my Juki 8700-7 top thread
hi there
please check timing cam for thread trimmer, need to re adjust again - check tension disk is open during trim or still close ( if closed always please check some parts missing from tension ) - check wire between tension and solenoid trimmer correct or no movement.
best regards
ASHRAF ABOZID
CAIRO - EGYPT
Posted on Apr 24, 2011
How do you correct/fix a 316 error/main shaft motor error on a Tajima 2 head embroidery machine
I hope this link will help.
http://www.digitsmith.com/tajima-tmfd-g1220-type-2-error-316-a-31639.html
Sep 28, 2017 | Sewing Machines
Just new to embroidery and baby lock. Practiced embroidery and one block letter is shorter in height than the others
well without knowing what machine your using 4 your letters ?? , now if your trying this manually and freehand , the best help I can give is to lightly pencil boundary lines to fabric, this helps greatly in getting your letters the same height , now if your using an automatic machine for your letters , theres a few things to look at b4 allowing the machine to do its thing , first make sure you have placed the presser foot down at least the same thread count from presser foot edge each time u do it !! second if machine doesn't seem to be gripping fabric properly , use a test piece of same fabric until you get your tensions where they need to be , if your automatic machine uses a holding /stretching framework instead of a presser foot , make sure the fabric is the same thread count in from the edge ( one edge to start with) this will give you the best possible chance of getting letters in the same place twice
I know it might seem strange for a ole diesel driver to know so much about monograms but I did repair machines in a handkerchief factory for ten years .prior too !!
Dec 20, 2016 | Sewing Machines
Tajima Tmex C-1201 won't light up ?
I went google and typed in --workshop manual for tajima tmex c-1201 sewing machine -- and found many pages with pdf downloads for repair manuals and workshop manuals
do that and find the right site for you and down load the workshop manual and that may be a way of fixing your machine
Sep 30, 2015 | Sewing Machines
How do I fix error code BC1 on Tajima Embroidery Machine when there are designs on the flashdrive that did work yesterday
The format of your program may have different formats that will work for Brother but not Tajima. The extension of the program is the key to the one to use. You will notice a program name that is the very same but the extension is different. Your program can't be found if you use the wrong extension. Use other design extension or you may need to register the program.
Nov 18, 2014 | Sewing Machines
Tajima embroidery machine
Hello, Error 225 Travel outside the set embroidery area
( When the software frame limit is set, or
on cap machines) Here is website for all the errors:
May 17, 2014 | Sewing Machines
Hi. I have a commercial one head tajima embroidery machine. I was sewing and realized I had no thread on one bobbin so I stopped the machine. Instead of continuing on, I decided to start all over with a...
Your new embroidery program has to be loaded first. The 2b7 is referring to needing instructions or in other words the embroidery program has to be loaded. Shut the machine down and turn the machine back on and load just as before.
Jul 06, 2017 | Sewing Machines
Tajima embroidery machine troubleshooting
We are having a similar problem with one of our single head Tajima TMEX-C1201 machines. In our case the design runs part of the way, then the head jumps and continues running and ruins the work. Any feedback on this would also be appreciated. Thanks.
Jul 15, 2013 | Sewing Machines
FY100
From all the info I can get it is the same chassis as a brother PE100. It used custom eeaprom cards and read .PEC or .PES files.
It could also be like the Bernette Deco 500 or 600 series. I have also seen a modification of this chassis called the EM10 by Husqvarna and it is USB direct connect and comes with software that outputs .HUS files.
Jan 29, 2008 | Sewing Machines
Sewing Machines Logo
63 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
