Question about NRS Hoveround Technique Used Electric Wheelchair
Need a hoveround teknique wiring diagram for the junction box
3 Suggested Answers
HoverTech
  • 232 Answers
SOURCE: Chair will power up, however
The number of bars that are blinking will also help to indicate what the problem is. Fault codes are located in the back of the owner's manual.Try doing the brake reset as previously suggested or the lock out sequence noted in the manual; call it in if neither of those steps help.
Posted on Sep 30, 2010
carsandcomps
  • 722 Answers
SOURCE: I have a hoveround teknique the light on the key
Below is a website that should prove useful to you; I also included a phone number for which you can call and possibly get a more direct answer for this, as they will be able to tell you what the "7 blinks" indicate, as well as why the brakes are locked up.
http://www.scooterdomain.com/Hoveround_Teknique_HD_XHD_s/277.htm
Please let me know if you need further assistance.
carsandcomp,
Guru, Premium Expert, Phone Support, Live Chat @ Fixya.com
Posted on Jun 26, 2011
Wiring diagram how to replace old style GPO telephone junction box ?
This is the GPO junction using both BT (left) and old GPO (right). How far back are you going ? This setup assumes you have the British Telecom wiring at some point. Hope this helps...
Oct 03, 2016 | Cars & Trucks
Hoveround Teknique XHD had a flat changed inner tube put back on now the motor spins but the tire stays still
The shaft is turning and not the wheel, that means the key is missing off the shaft. or the freewheel lever needs to be flipped into drive mode.
Oct 04, 2015 | Hoveround Teknique XHD Power Chair - Used...
Manual brake switch
Chair motors sometimes do not have brake switches. It relies on the gear ratio keeping the chair from moving while not under power. The freewheel lever disconnects the gear box from the motor.
Feb 16, 2014 | Hoveround Teknique XHD Power Chair - Used...
I have a hoveround teknique wheelchair brakes are locked up the key symbol light blinks 7 times what should i do
Regarding your Hoveround Teknique?..You should contact Hoveround directly. They made the chair. They will probably service it for you, and you might get it serviced for free--maybe. Go their website (http://www.hoveround.com) and see the Contact Us page.
Jun 26, 2011 | Health & Beauty
On hoveround teknique fwd chair, showing 8-bar trouble code with all functions locked out. i need to a) raise the seat so it can be removed and b) restore function to the chair. any suggestions apart from...
An 8 Bar Flash on the controller of a Teknique FWB indicates: Possible Control System Trip
A control system trip is indicated. Make sure that all connections are secure. This means that one of the wires attached to the junction box, or the umbillical, may have come disconnected.
Is your power chair equipped with an optional power seat lift? If not, raising or lowering the seat will not restore function to the power chair. Have you tried doing a brake reset just to see if that will help? The manual brake levers are under the bottom front of the chair base; turn off the controller, pull the levers down then push them back up until the pop into place. This reset will clear many issues.
If you are able to check the wiring for the junction box and wish to remove the seat, you can do so, but the Teknique series is terribly difficult for the average end-user to work on and is recommended that a Hoveround Technician do it. Hoveround will not even ship batteries for self-installation to owners of any of the Teknique power chairs because they are such a pain to work on. The seat must be fully removed to gain access to the batteries under the motor cover and most power chair owners do not posses the kind of strength and dexterity needed to do it.
The seat post can be removed by removing a bolt underneath the seat, you will also need to unclip the black umbilical cord leading from the controller to the motor cover so that you do not yank it out when you remove the seat. The motor/battery cover can then be unbolted to allow you access to the batteries and junction box. I cannot give you details on how to do this, because as a Hoveround Tech Support Rep, we are instructed to dispatch a technician for the customer's safety and I have never done it myself or even seen it done.
If your Hoveround was purchased via your Insurance, they will most likely pay for the repair, but it may take time to schedule the appointment if the Insurance requires documentation or verification before allow the repair to take place. If you are in need of additional assistance, please contact Hoveround Tech Support at 800-964-6837 on Wednesdays or Thursdays when the call volume is lower. It's worth a shot.
Dec 23, 2010 | Health & Beauty
Have a Hooveround Teknique FWD wheelchair,
Five flashing lights indicate Right Motor Wiring Trip- The right motor has a short circuit to a battery. Check all the connections and leads between the right motor and the battery.
May 15, 2010 | NRS Hoveround MPV 4 - Hovaround Used...
Have a Hooveround Teknique FWD wheelchair, replaced circuit board in joystick, checked all wiring, but 5 lights rapidly flashing. Any ideas please
5 bars indicate a short circuit from the right motor to the battery. Check all the connections and leads between the right motor and the battery.
Mar 27, 2010 | NRS Hoveround MPV 4 - Hovaround Used...
Hoveround mpv4 does not work led flash when turned on. 3 red 4 yellow and 1 green leds. the brakes, motors and wires have all been tested and work. Any Ideas?
This 8-light code is a joystick controller problem. It is an internal problem with the circuit board located inside the joystick. The entire joystick assembly would need to be replaced in this situation. If you are in need of a joystick, I have several for sale.
Jun 21, 2009 | NRS Hoveround MPV 4 - Hovaround Used...
NRS Hoveround Technique Used Electric Wheelchair Logo
147 people viewed this question
Top NRS Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Are you a NRS Health and Beauty Expert? Answer questions, earn points and help others
