Question about Whirlpool Refrigerators
Whirlpool Refrigerator WBM46LS
When anyone opens the door of the fridge, it just starts beeping continually all the time. We were told to purchase a new Interface Board, but, this didn't work. What can I do, I am at my wit's end. This started a few weeks ago.
catriver
  • 878 Answers
SOURCE: door alarm keeps sounding even though doors aren't ajar
ginad, L&G missed the tolerance a little on the door switch. They do make a kit to correct the problem, I believe it's a little gasket that fits under the door switch. I use a plastic stick on, on the door itself, to solve the problem. As long as it's under warranty have the replair co. fix it. In the meantime just use a piece of tape to cover the door switch.....Catriver...post back
Posted on Jan 30, 2007
fridgetech
  • 473 Answers
SOURCE: refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
Posted on Nov 16, 2007
Amigaman
  • 248 Answers
SOURCE: Whirlpool refrigerator w/ top freeezer
It has a plugged defrost drain. You may need to defrost for 24 hours with unit unplugged and doors open. UNPLUG FIRST!! f still leaks, you need to remove floor of freezer, then the back wall of freezer. Remove ice. At center rear under coils is the drain hole that is plugged up. Use hair dryer to melt ice. Pour hot water in this area to uncover drain. With hot water in area, you can put a 1/4 diam. hose or copper pipe in drain and blow into it while pressing down. It will slowly go through ice, clearing drain.
Posted on Nov 18, 2007
SOURCE: E249T Fisher and Paykel Beeps when door opened
Disconnect the Fridge for 5 mins. After that, should be ok.
Posted on Apr 12, 2009
Mark335
The problem is the doorswitch of the freezer door. The door 'bump' which has to push in the swich doesn't push it in far enough. You can try and hold the switch an dpush it in with your finger and see if the sound continues. You can try to adjust the door, but easier is to glue or tape something to the door 'bump' so it pushes the switch further in. Hope this was the issue.
Posted on Feb 10, 2010
How do I fix the continuous beeping coming from my refrigerator?
LG Fridge Door Alarm ' Chris Inch
www.chrisinch.com/blog/articles/show/lg-fridge-door-alarm/
Aug 30, 2006 - It's just too bad I can't live with beeping noises going off every 30 seconds. .... took them a long time and they scratched the paint) the fridge beganbeeping ..... I opened the fridge door to let the alarm sound and then located the alarm..... I can't tell you how many times I've "snapped" since hearing this thing.
FIXED Frigidaire Professional Constant Beeping - ApplianceBlog
www.applianceblog.com/.../17546-Frigidaire-Professional-Constant-Bee...
Jan 15, 2010 - 10 posts - ‎3 authors
The refrigerator is not refrigerating and I don't here the fan go on or ... the water comes out from the water dispenser and so does the ice. ... Thank You so much! ... The unit is two years old from time of purchase. ... Then to install it you remove the #81 screws here: 11-Controls parts .... All times are GMT -6.
Fisher & Paykel fridge in alarm - Kitchen - Home - Whirlpool
forums.whirlpool.net.au > Home > Kitchen
WhirlpoolJan 24, 2010 - I push the selector button to mute the alarm and then it may not do it again ... I can determine the fault code through the number of beeps/flashes? ... myfridge started beeping every 6 hours abut a week ago. ... posted 2012-Aug-7, 3:17 pm.... If so, defrost the coils behind freezer, you can use a hair dryer to ...
Feb 03, 2016 | Refrigerators
What would cause a very faint intermittent beep on Whirlpool refrigerator? Not all of the time. Everything works great on it. It's brand new. Beep is bugging me though.
Hi,its not like the sound when you leave the door open on the fridge door,if you are not shore try leaving the door open for a fuw momments to see if it sounds the same.
Just a thought,I hope you get it fixed it would iritate me as well.
Jun 10, 2015 | Whirlpool Refrigerators
Beeping
Thunder storms can cause control boards to go erratic. Try unplugging the refrigerator for a minute or two and after plugging it back in hopefully the problem will go away.
Apr 12, 2014 | Whirlpool Refrigerators
I have a 6 y.o. whirlpool fridge wbm 46 model that's started to make a loud buzzing/whirring noise every 15 minutes or so ( only lasts a few seconds each time). It's started doing that noise in the last...
Hi
The sound from your refrigerator can be caused due to various reasons,please check this link bellow to troubleshoot your problem:-
http://www.repairclinic.com/Refrigerator-Troubleshooting?red=Refrigerator-Repair-Help#itsnoisy
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 02, 2011 | Whirlpool Refrigerators
My fridge does the open door beep and motor on/off just by opening the door. Ive searched through here and suggestion is to clean the door switch, but I cant find the door switch on freezer or fridge...
Depending on which two numbers after the ET1FHTXM may make a difference. For example ET1FHTXM00 the only thing that may cause a beep or cut the refrigerator (that I know of) on or off would be=> Circuit Board or Timer 2213473 This is a ADC adaptive defrost control and when they go bad strange things happen.Click Here=>
Whirlpool ET1FHTXMQ01 parts manual.pdf
You can also find a Tech Sheet wiring diagram=> Here
Thanks, Sea Breeze
Jan 26, 2011 | Whirlpool ET1FHTXM Top Freezer...
My whirlpool refrigerator beeps continuosly when i open the door, the light flashers also & the motor sounds like it stops & starts also. What is the problem?
Hello All.
I would like to add my findings.
My fridge WBM46LS of 11 years started behaving exactly as the OP described. I tried all the suggestions regarding holding buttons, power off etc to no avail.
I even found an online manual here
https://www.yumpu.com/en/document/view/18647891/whirlpool-uk-refrigerator-models-wbm35lw-wbm35ls-/5
But that did not address the problem at all.
So I went back to someones suggestion about the Potency Module.
I pulled the fridge out and unscrewed the cover at the bottom left to get access to the Potency module.(Red plastic box)
Without even pulling it open I could smell the burnt electronics.
I opened up the case and found a scorch mark next to the big capacitor on the circuit board.
So far, so good.
Given that a new fridge of the same size/style is about $1300 I pursued the spare part.
I then tracked down a supplier in Melbourne with a new board/module for $148.50. P# WPP326020913
Plugged in the new board in and fired up the fridge and its working just like new.
So I am happy now that a perfectly good fridge is up and working again.
Dec 01, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
The alarm beep which tells you to close refrigerator or freezer door now beeps even after either door has been closed. It beeps three times at approx twenty second intervals, then beeps continuously for...
Sounds like you have a bad door switch. Depending on the age of the fridge, it might still be under warranty. If it's not, then you might be able to access the door switch yourself and pull it out & replace it.
Good luck......
Aug 15, 2010 | Fisher and Paykel Active Smart® E522BR...
When fridge/freezer door is opened the fridge starts beeping and the light constantly turns on and off until the door is closed
WHEN i OPEN MY WHIRLPOOL FRIDGE THE LIGHT FLASHES ON AND OFF AND THE COMPRESSOR APPEARS TO CUT IN AND OUT AND THE FRIDGE BEEPS UNTIL DOOR IS CLOSED. cAN ANYONE HELP?
May 23, 2010 | Whirlpool Refrigerators
Whirlpool fridge alarm sounds when opening the door most times.
Speedysgarag, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Speedysgarag), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 15, 2017 | Whirlpool ARC4030 Stainless Steel Top...
Fridge turns on and off and beeps
You need a tech to check the problem, it seems to be some kind of electrical short or, if the fridge has an electronic control module, it may be the source of the proble.
Jul 20, 2008 | Whirlpool ET0WSRXML Top Freezer...
Refrigerators Logo
47 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
