Question about Dell 3100cn Laser Printer
I have fading on the right hand side. Printer Dell 3100CN
Called Dell to try to fix problem, they said it was drum. I changed drum, twice, still have fading. Called Dell again, they said it was the power source, not enough power, so we gave it it's own outlet. Still had fading. Then they said it could be something blocking the laser. I said it didn't look like anything was wrong there either. They said buy a new printer. I researched online for possible solutions. Plenty of people have the same problem but no answer. It has nothing to do with colors printing and black not, or blue streaks..it has nothing to do with streaking at all. On every sheet it prints an inch is missing on the right hand side. How do I fix the fading?
  • cbbjr May 02, 2009
    I have the same problem but it only occurs with color printing not black and white
    Genius:
  • 1,139 Answers
Hello buyerfs,
Well I got good news and bad news for you. The good news first, this problem is common and is fixable. It has to do with aligning the page sensors and the DRUM. Now for the bad news, remember what you said DELL told you? "They said buy a new printer" guess what, they were not kidding, the work involved with adjusting the sensors and the DRUM, will cost you the price of the printer alone in labor. It is a tedious job and requires adjusting three systems in unison. I hate to tell you this but, DELL was correct, but if you don't think so, try to shop around for a repair shop to work on the problem, but first get an estimate.
I hope this helps.
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Mar 20, 2009
Dell 1355cn error 007-371. what is it and how to fix it.
the error is related to the PHD , photoconductor unit is a component of a laser printer that includes a photosensitive print drum. Digitized data is sent via an electrostatic charge to the photoconductor or photosensitive drum, also called the PC kit, which then distributes the ink to the paper. try removing it and ensure their is no packaging stuck around it if it's new, it could also be faulty if you can try another from another Dell 1355CN, if it the error occurs again i would suspect their is a fault with the printer and recommend returning the unit
Nov 29, 2016 | Dell 1355CN Multifunction Printer - Color...
1815dn printing is faded
IF this is a high use printer, there are some other things that might be in need of attention. There is a corona wire, drum and drum wiper that are consumables too.
Mar 31, 2014 | Dell 1815dn All-In-One Laser Printer
Dell 1110 faded print left side
If you have trid a different toner cartridge, then I would first try a new drum (not sure if toner & drum are in same cartridge, some are so you will have to check that) If not that, then I would suggest the transfer roller bar would be my next suspect if the printer has a lot of copies done on it.
Jan 13, 2013 | Dell 1110 Laser Printer
Dell 2135 fading left side when printing
It's possible that this could also be down to a toner cartridge inside the printer. I would recommend running off a copy of the colour laser test page found here.
The colour bars towards the bottom of the page separate cyan, magenta, yellow and black. Hopefully you will be able to notice that one colour is affected more than the others and replacing that colour may help.
Apologies if you have tried anything similar previously.
Oct 31, 2012 | Dell Office Equipment & Supplies
Copies Still Faded After Changing Toner
can be the wiper blade, worn out drum, is there a black faint line down the side of the page as well?
May 30, 2012 | Ricoh Aficio Mp 4000...
I have replaced the Drum twice in the past 6 months on my Dell 1320c, it is 4 years old and now the printing is faded to the left hand side, any suggestions other than its knackered. Its very creaky and...
Does the toner also smear where it is faded? If so it means that your fuser is dying, and in which case might be just a cheap to get a new printer than fix that one. The fuser is the part of the machine that helps bond the toner to the paper.
Sep 09, 2011 | Dell 1320c Laser Printer
Why does my toner fade on the right side of a copy
It is possible that your printer just needs to be cleaned. The following url provides instructions on how to clean your printer.
http://support.dell.com/support/edocs/systems/3100cn/en/ug/section22.html#1088799
Sep 15, 2010 | Dell 3100cn Laser Printer
Left side of page prints lighter than rest of page
You should contact Dell about returning these for a replacement, it sounds to me like a manufacturer's error.
Jan 27, 2010 | Dell 1320c Laser Printer
Our Dell 3100CN printer blocks out a 1/2" wide line (all colors) print area on the right side. We replaced the printer drum unit and that didn't fix the problem. It was printing fine until we replaced the...
Try the cleaning rod. visit: http://support.dell.com/support/edocs/systems/3100cn/en/ug/section22.html
for images (under replacing the "cleaning rod pad") for where to find the cleaning rod. You likely don't need to replace the pad, just use the rod (pull out and push in 10X) and try to print again.
Cheers
Oct 22, 2009 | Dell 3100cn Laser Printer
Dell 3100cn Laser Printer Logo
535 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
