Question about Toshiba Computers & Internet
When i turn my laptop on i get the message "toshiba common modules did not work. Toshiba mobile extension service failed to start"
I have been using this laptop for some time now, and I have only just started to get this message. I tried restoring it to an earlier date, but that didn't fix it.
shbuckler
  • 126 Answers
SOURCE: vista sp1 incompatible with toshiba satellite u305 series
dont be silly. You need tech support
Posted on Dec 25, 2008
ChipcircuiT
  • 157 Answers
SOURCE: Toshiba common module not working
check the bios settings first...or try to make default settings in the bios
Posted on Jan 04, 2009
freddygon66
  • 93 Answers
SOURCE: A105-S4054 Model Number fot changed automatically & common module terminated problem
Hi, according to what you indicate in 2 occasions utilizastes the DVDs given for toshiba and they operated correctly and already not, it is possible that your equipment has gone to guarantee and they have replaced the card mother and they forgot to do the DMI to him in order that it recognizes the discs of recovery, they can do alone it in an ASP, for what I recommend you go to the nearby.
Posted on Jan 10, 2009
  • 12 Answers
SOURCE: what is Toshiba Common Modules.Where can i get
It is a set of additional drivers needed for some main drivers/programs for Toshiba laptops. I believe the one you need is this one:
http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=857328xml&sliceId=&dialogID=90506386&stateId=1%200%2090504709
If it's not the one (if it fails for some reason) simply go to Toshiba web site and type the "tecra m2v common modules" in the search string. You get plenty of links. Here is the link to search at technical support:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/outFrm.jsp?ofId=AskIris&searchString=tecra+m2c&x=0&y=0
Posted on Sep 06, 2009
SOURCE: Problems booting windows vista on toshiba
You may need to re-install the operating system all over again as you had tried to restore your computer using Restore Disc but failed. In these cases, you will have to try to wipe all your data and install OS once again.
Posted on Mar 13, 2010
How to get Drivers Updates after Windows 8 Upgrade for Toshiba C660D Laptop Please
This is a common problem with a new OS upgrade. Try to use Win 7 drivers. Modtify the drivers to be compatible with Win 8. Most times this will work, not always. Try here for Win 7 32 or 64 bit drivers: http://uk.computers.toshiba-europe.com/innovation/download_drivers_bios.jsp?service=UK&mode=allMachines&action=search&teddProduct=6017&selShortMod=1041
Dec 03, 2012 | Toshiba Computers & Internet
I just plugged a monitor into my laptop and now have two screens. The problem is, I do not know how the separate the two to work independantly of each other. My laptop is a Toshiba Satellite A665D-5061S.
Try this:
his issue can be resolved by removing the check mark next to "Display Change Service", or by changing the "Display Output" settings in the settings for Toshiba Mobile Extensions using the following procedure:
  1. Click on the Windows Start Menu> Control Panel > Toshiba Mobile Extensions> Display Change Device.
  2. Remove the check mark in the box labeled Display Change Device", or select the correct "Display output".
  3. Click on "OK" to close.
Oct 04, 2011 | Toshiba Computers & Internet
I replace the ram from my laptop toshiba satellite pro-300 but when i start the computer by recovery disk it freze after loading files
If you have more than one memory stick installed, test the system with a single memory module at a time:
Take out both modules, install a single module and turn on the system. Try to restore
If it fails, turn it off, disconnect battery and adapter. Take out the same memory module and install it in another memory slot
Turn it on again
Repeat the same steps with another module
Sep 19, 2011 | Toshiba Satellite Pro L300 Notebook
My laptop problem has start my laptop and trun of laptop?
Here's how to fix a non booting toshiba or hp laptop. This is a rather common problem with many Toshiba and HP models, where the Maxim power driver chip fails and needs resoldering. It's a tiny 48-pin chip, so if you dont have extensive resoldering experience, you'll need the repair manual. This Toshiba m35 laptop repair manual comes with 3 resoldering scenarios, so you can pick the one that suits your skills.
All in all, the repair process lasts for about an hour and using the repair guide you should have no problems fixing your dead laptop.
Jun 05, 2011 | Toshiba Satellite M35X-S109 Notebook
After using recovery disks for toshiba laptop satellite l305d i get error message 10-fa12-045d, please help??
Toshiba recovery error seem likely to be due to a failing/failed HDD. If your laptop is in warranty then visit Toshiba service center. Otherwise try this--------> I would like you to try checking the HDD with an error checking program from floppy or CD or with the drive removed from the laptop and tried in a USB external enclosure in another PC.
If the HDD itself is made by Toshiba (which seems likely) you would need a generic testing program since Toshiba don't provide their own HDD checking program.
HDTune can be used from another PC.
Have a nice Day
Oct 06, 2010 | ErrorExpert
What is Toshiba Common Modules.Where can i get it.please. I tried installing the Toshiba tecra m2v Bios update and its said, Toshiba Common Modules not installed.Please help me
Sep 06, 2009 | Toshiba Tecra M2V-S330 Notebook
No hotkeys on my G25-AV513
Usually on Toshiba notebooks, they have a memory resident program on their call fkeys. If it isn't installed on your computer, you can download a new one from Toshibas support website.
Jul 20, 2008 | Toshiba Qosmio G25-AV513 Notebook
Jul 16, 2008 | Toshiba Tecra A5-S416 Notebook
Toshiba S2450 PS245E Laptop Heating Problem
toshiba 2450
1 clean the cpu radiator 2 make sure the fan works, 3 install toshiba common modules and toshiba chipset drivers. 4 go into bios and set devices managed by the os.
Dec 24, 2007 | GPS
FN key not working in Toshiba Satellite
Hey,
Try to install these utilies:
Toshiba Hotkey Utilities
Toshiba Touch Pad ON/Off Utilitiy
Toshiba Utilities.
... in the same order and reboot between them.
One guy posted it on some Forum.All credits to him :)
Hope it helps.
Dec 03, 2007 | Computers & Internet
Computers & Internet Logo
37 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
