Question about Home Security
How do you reset entry code to a "apple safe master YDB-AJ" ??
The door is already open
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Cannot lock properly once pin has been punched in
how do you reset entry code to a
Posted on Oct 15, 2017
  • 10 Answers
SOURCE: Keypad code will close the door but not open it.
check that both codes (in the remote & garage door opener) are the same. Press reset on the opener and reset enter the code.
Posted on Nov 05, 2008
  • 3197 Answers
SOURCE: trying to reset code for a Garage Master Security ...
If you are trying to reset the code for the keypad, locate the smart/learn button on the rear of the motor unit. Press and immediately release this button and then walk over to the keypad and key in any 4 digit code you like and press enter.
If you are trying to reset the code for the hand remotes, you can't.
Posted on May 23, 2010
  • 3197 Answers
SOURCE: My lift master security plus keyless entry pad for...
You can try programming it but first make sure the battery is good. Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to your keypad and key in any 4 digit code you like and press enter.
Posted on May 24, 2010
blanchettohd
  • 143 Answers
SOURCE: garage door remote entry code
This multi code device can be programmed. Make sure the battery is good. Linear.com has all the manuals and directions for coding in. make sure and get the model number of the opener and the keypad. Thanks BB
Posted on Sep 05, 2010
  • 3197 Answers
SOURCE: I have a lift Master
Without a model number no one can tell.
Try this:
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
Posted on Jan 07, 2011
Brinks Home Security Safes
i think with this kind of safe it comes with 2 keys, one which requires the code to be entered, and a master key that will unlock without requiring the code.
if you have the master key, just use that.
after you have opened the door you can reset the code by pressing the reset button (a pin / paperclip required to press)
on the back of the door.
Feb 15, 2017 | The Computers & Internet
Do i need to keep the door open when i reset my Apple Safe Master YDB-AJ?
You may not need to have the door open when changing a code (many safes do not require this) but it is a certifiable insanity not to keep the door open when reprogramming any safe - electronic or mechanical.
If something goes wrong in the code changing process and you wind up with an unknown or scrambled with the door locked....well, use your imagination....
If the door is open at least you can call a professional to default it at best, or access the contents and junk the safe or lock at worst.
With most mechanical safes the door must be open in order to access the change code procedure, but electronic locks may not have that safety built in.
Also, don't attempt it without the manual for that model. And look for any section that talks about defaulting the codes before you start. And operate the lock with the new code a few times with the door open and check it works, before closing the door and trusting you have got it right.
I may be overly suspicious, but either your boss has no clue that this could be a poisoned chalice job, or he knows full well, and doesn't want the egg on his face!
good luck
Jan 20, 2017 | Home Security
How do I change the combination on a door key safe
Once it is already OPEN there is probably something side the safe and on the back side of lock access that will allow you to change the combination. I do not know the model number but this is standard practice so that one must know the current combination to reset it to a new one. Specifically how would be in your manual. The key would allow the over ride to access this recombination. I have a digital door lock that works similarly and you can either enter the numbers or use a key to unlock it unlike a analog safe it has both a master code (which allow the ability to create new codes or delete old codes) and an access code.
Feb 01, 2015 | Home Security
I changed the batteries and now I can't open the safe- do I have to reset the code and if so how?
Assuming you've not changed the master code:
To Open the safe with the master code:
Enter the master code (pre-selected 123456) and press #. The LED will show -OPEN- and the door will open automatically and at the same time the LED will show "OPENED".
Jan 15, 2015 | Gary Laptop Computer Safe, Steel,...
Change the combination on a DHo74E
The SentrySafe electronic lock is shipped with a factory set master & manager code (777777).
You should set the lock to your own unique master & manager code immediately.
Please keep your codes in a secure location. You may also register your codes on our website at www.sentrysafe.com.
A single signal (LED flashes and beeps once) response from the lock indicates valid entry.
A double signal (LED flashes and beeps twice) response from the lock indicates an invalid entry.
• If three incorrect entries are entered in a row, the keypad will shut down for a period of five minutes. During this shut down period you will not get a response from the keypad.
Changing the Master Code
(Code length: 1 to 10 digit code) Always perform this operation with the door open.
1. Enter: # - Existing Master Code - #
2. The set light will stay orange for ten (10) seconds.
3. Enter: 1 - * - New Master Code - # - New Master Code - #, before the orange light disappears.
If a mistake is made during the change, wait thirty (30) seconds and repeat steps 1 thru 3.
Test the new code several times before closing the door: Enter: * - Code - #
• The lock will indicate a valid code change with a single signal.
• The lock will indicate an invalid code change with a double signal and the old code is still valid.
Changing the Manager Code
1. Enter: # - Master Code or Manager Code - #
3. Enter: 2 - * - New Manger Code - # - New Manager Code - #, before the orange light disappears.
Activate user codes
3. Enter: User ID Number (3-7) - * - New User Code - # - New User Code - #, before the orange light disappears.
If a mistake is made during the activation, wait thirty (30) seconds and repeat steps 1 thru 3.
• The lock will indicate a valid code entry with a single signal.
• The lock will indicate an invalid code entry with a double signal and the old code is still valid.
Example: # - Master Code or Manger Code - # - 5 - * - New User Code - # - New User Code - #. This will activate User Five (5).
Changing the user code
1. Enter: # - User Code - #
3. Enter: New User Code - # - New User Code - #, before the orange light disappears.
The Master and Manager can also change the user codes by following the "Activate user codes" section steps 1 thru 3.
Deleting user codesAlways perform this operation with the door open.
3. Enter: User ID Number (3-7) - * - # - #
Programming your lock codes
Dec 17, 2012 | Sentry Safe Dh-074e Solid Steel Depository...
I want to change the combonation
The SentrySafe electronic lock is shipped with a factory set master & manager code (777777). You should set the lock to your own unique master & manager code immediately.
Activate user codes
Factory reset la gard 3715 electronic safe
Welcome to FixYa.
How to reset or change your lock combination:
  • 1. Enter "zero" six times.
  • 2. Enter your existing six (6) digit combination one time. (or 123456, factory default if you haven't changed the combination yet.
  • 3. Enter your NEW six (6) digit combination two times.
  • 4. If a mistake is made wait thirty (30) seconds and repeat steps 1 - 3.
  • 5. Test lock operation several times before closing the door.
CAUTION: When selecting a combination do not use birthday or other predictable data that could give correlation between the user and combination.
• Valid Combination Entry - Double signal after valid six (6) digit combination is entered.
• Invalid Combination Entry - Triple signal indicates the old combination is still valid.
Thank you for using FixYa.
Have a great day.
Jas247
Aug 01, 2011 | Office Equipment & Supplies
My lift master security plus keyless entry pad for the garage door no longer will open the garage door when I key in the four digit code. Can I reprogram the entry pad and if sohow?thank you
May 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
No power to passenger doors or locks
Double press and hold the entry button to reset all doors to open. The key fob as set itself to driver door only by the sounds of it.
Take the battery out and leave a few minutes, then insert and pair. ( driver door open )
Jun 11, 2017 | 2000 Pontiac Bonneville
Nov 05, 2008 | Sears Craftsman LiftMaster Chamberlain...
Home Security Logo
290 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
