Hey I just brought a safe from 2nd hand store, the safe is a "apple safemaster YDB-AJ, the door is already open, not sure how to reset code though. can you help?
Door is already open,
ekoo
SOURCE: need to reset the electronic code to open the safe.
are you the manager user of the safe?if yes,you can reset a new code by yourself.
Posted on Apr 09, 2009
  • 25 Answers
SOURCE: i need a manual
sir,
http://support.apple.com/manuals
at the above mentioned site you can find your required manual.
Posted on May 28, 2009
  • 188 Answers
SOURCE: it has been a while since ive opened my safe
No. Visit Sentry Website.
Posted on Jul 23, 2009
SOURCE: gordon item#45891 digital safe, lost code the door is open
there is red button on the inside of the door (hinge side) press this , then key in a new code
Posted on Oct 10, 2009
SOURCE: kingavon safe 28 door locked open, how do i
electronics not working can t find key need one but don t have any addresses or telephone numbers can anyone help
Posted on Oct 25, 2009
Do i need to keep the door open when i reset my Apple Safe Master YDB-AJ?
You may not need to have the door open when changing a code (many safes do not require this) but it is a certifiable insanity not to keep the door open when reprogramming any safe - electronic or mechanical.
If something goes wrong in the code changing process and you wind up with an unknown or scrambled with the door locked....well, use your imagination....
If the door is open at least you can call a professional to default it at best, or access the contents and junk the safe or lock at worst.
With most mechanical safes the door must be open in order to access the change code procedure, but electronic locks may not have that safety built in.
Also, don't attempt it without the manual for that model. And look for any section that talks about defaulting the codes before you start. And operate the lock with the new code a few times with the door open and check it works, before closing the door and trusting you have got it right.
I may be overly suspicious, but either your boss has no clue that this could be a poisoned chalice job, or he knows full well, and doesn't want the egg on his face!
good luck
Jan 20, 2017 | Home Security
How do i re set electronic safe after changing batteries
open the safe door on the panel beside the hinges there should be a reset button, Press the button once the safe beeps, input your new code and press A or B when finished code is now reset. Make sure you check your new code with the door open. Just turn the lock, input the code press your A or B which ever you chose, the lock dial should open.
Feb 16, 2015 | Locks & Locksmithing
How to change the pin on Zebra Electric Push Code Safe from Justice.
1. Door has to be opened using previous code or the default "0000".
2. With door open hold the * button down. Both green and red lights will flash.
3. Within 15 seconds, enter your new 4 digit passcode while holding the * button. Press # when finished to store new code. Both lights will stop flashing.
4. Release the * button.
Jul 28, 2014 | Home Security
Where the black button in the safe so i can reset code
Inside the safe...open the safe you will see a button on the inside of the door.this is the re-set button..make sure the code you put in is working before closing the door.
Jun 08, 2014 | Mesa Safe MFL2014E Depository Safe
2006 pt cruiser. check engine light comes on, automatic transmission will not shift out of 2nd gear. does not do it all the time though. Computer Problem?
The check engine light means there is a trouble code has occured.Even if the problem clears itself,the code is still stored as a history code.if you want to know what that code is,you can buy a cheap code scanner for about 50 bucks.I bought one out of the Harbor Freight catalog made buy Cen-Tech.It comes with a code book that only gives you engine trouble codes,but the scanner will also read transmission codes(I have to do a Google search on these to know what they are).Hey,it was cheap! This thing has paid for itself 10 times already!
Aug 08, 2012 | 2006 Chrysler PT Cruiser
Iphone wont wake from sleep
If the Apple store has already tried to fix it and it's still having problems then you should take it back. Tell them the restore didn't fix the problem, they should swap it for a new one.
Dec 31, 2009 | Apple iPhone 3G
''The protector'' gun safe I need a user manual
If it is "The Protector" from Costco, open the door and put your hand back by the top of the rear of the door in the seam. There you should feel a little button, push and hold til it beeps then enter your 4 digit code, hit "A" and release. Lock the wheel with door open and make sure your new code works.
Apr 01, 2009 | House Brand Sport & Outdoor - Others
Someone dropped it and now it won't turn on.
Hey hey matt,
I would try resetting the camera to the factory default setting. To reset the camera remove the batteries for at least 15 seconds without the ac adapter connected and then reinsert the batteries. If this doesn't work I would have the camera looked at by an authorized service technician such as bringing it to a Geek Squad® precinct in a Best Buy™ store. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 01, 2008 | Sony Cyber-Shot DSC-T5 Digital Camera
Wharfdale 21
From searching the net pressing the "pp" button 3 times will open a hidden menu.
Apr 15, 2008 | Wharfedale Moviestar 60+ System
Deleting all memory at once
Ipod manuals http://www.apple.com/support/manuals/ipod/ Not sure if you have 1st or 2nd gen 1st: http://manuals.info.apple.com/en/iPod_nano_Features_Guide.pdf 2nd: http://manuals.info.apple.com/en/iPod_nano_2nd_Gen_Features_Guide.pdf These manuals suggest that when you connect to itunes, it automatically deletes all songs not in your library. Otherwise i don't see a format option unless the drive shows up in my computer and you can format it there (right click). It basically suggests that you have to use one of the manual methods on the pod or computer to delete songs. Have fun!
Aug 28, 2007 | Apple iPod nano
 Grubhead
Grubhead
