Power voice 2 ver. 1.1 - Audio Players & Recorders
Ms-6541 ver 2.1 mobo pin connector
Hello this should be the homepage:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=97106&prodTypeId=12454&prodSeriesId=96284&swLang=13&taskId=135&swEnvOID=1093
The front panel looks like this:
d450e023-b94a-4bba-87c8-871096a37704.gifF_P1 PinOut
17 15 13 11 9 7 5 3 1
18 16 null 12 10 8 6 4 2
SHORT:
HDD led op 1/3
Power led op 2/4
Power Sw op 6/8
Reset Sw op 5/7
Here is also the manual:
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&locale=en_US&docIndexId=179911&taskId=101&prodTypeId=12454&prodSeriesId=316609
The usb connector looks like this:
e3c82873-b0a1-49b3-91f4-548ca5550428.jpgIts basicly just to insert the black connector in it.
Best of luck
Jul 16, 2013 | Computers & Internet
How do you wire a AW1000V to 1 amplifier?
The easiest way to wire this would be to make sure you have a 2 ohm amp, wire both voice coils in parallel to the amp. This means to connect both + terminals on the speaker to the + speaker output on the amp, then wire both - terminals on the speaker to the - speaker terminal on the amp. With the voice coils in parallel like this it makes it into a 2 ohm load at the amplifier. If you are running for example a 1000 watt amp at 2 ohms into this speaker it would give each voice coil the equivalent of 500 watts of power at 4 ohms. The other way would be to run the voice coils in series (voice coil 1 - terminal to - speaker terminal on the amp, voice coil 1 + terminal to the voice coil 2- terminal, voice coil 2 + terminal to the +speaker terminal on the amp.) The series wiring would give you a 8ohm speaker load to your amp so you would need a 8 ohm amp.
Mar 07, 2011 | AudioBahn AW1000V 10" Dual 4-ohm Voice...
How do i install my L5 solo barics to a 2 channel amp if there is only one connection on the enclosure next to the vent? If I bridge the amp to 1x1000W will the power distribute evenly between both...
Option 1 (parallel) = 2 ohm load
Speakers wired in parallel
Recommended Amplifier: Stable at 2 or 1 ohm mono 2_4ohm_svc_2ohm.gif
Option 2 (series) = 8 ohm load
Speakers wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_svc_8ohm.gif
Option 1 (parallel/parallel) = 1 ohm load
Voice coils wired in parallel, speakers wired in parallel
Recommended Amplifier: Stable at 1 ohm mono 2_4ohm_dvc_1ohm.gif
Option 2 (series/parallel) = 4 ohm load
Voice coils wired in series, speakers wired in parallel
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_dvc_4ohm.gif Option 1 (parallel/parallel) = 0.5 ohm load
Recommended Amplifier: Stable at 1/2 ohm mono 2_2ohm_dvc_05ohm.gif
Option 2 (series/parallel) = 2 ohm load
Recommended Amplifier: Stable at 2 or 1 ohm mono 2_2ohm_dvc_2ohm.gif
Option 3 (series) = 8 ohm load
All voice coils wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_2ohm_dvc_8ohm.gif
Apr 09, 2010 | Kicker Solo-Baric L5 Car Subwoofer
Bridging amp/sub
wire speakers in series google it to find diagrams
Jun 30, 2009 | Car Audio & Video
How do i wire two 15 inch subs to 2 ohms
Hello familia_gome,
Those MOFO-15's have dual 1ω voice coils. So the only way you can get 2 of them to present a 2ω load is to use 1 voice coil on each one with the two of them wired in series. Using both voice coils, you can get a 1/4ω load by wiring the voice coils in parallel and then wiring the subs themselves in parallel. You'll get a 1ω load with the voice coils in series and then parallel the subs. Or you'll get a 4ω load with both the voice coils and the subs in series.
Here's a link to Power Acoustik's PDF for the MOFO's. I recommend that you check out the wiring diagrams on page 3.
http://www.poweracoustik.com/SUPPORT/MANUALS/PA-MOFOWoofer.pdf
Hope this helps.
Apr 05, 2009 | Power Acoustik MOFO-15 Car Subwoofer
Do you still have the panasonic voice editing software ver 2.0
Find it on minimova or any other site for panasonic voice editing software
Aug 27, 2008 | Panasonic RR-US360 Digital Voice Recorder
Using ICD-P210 and BP-150, use same software?
I borrowed Sony Voice Editor 3 (version 3.0) from a colleague and can now download and play both the P-210 and BP-150 with one program.
Apr 23, 2008 | Sony ICD-P210 Digital Voice Recorder
Powered on MSI K7T Master Ver:1 motherboard and it beeps very frequently
Hi, it sounds like your RAM chips are not installed properly or are faulty, if you have 2 seperate sticks of RAM, remove them and install one at a time to test which one is at fault. make sure you use DIMM 1 for each RAM stick.
Regards mistyman
Nov 26, 2007 | MSI K7T Master-S Motherboard
26 people viewed this question
 Grubhead
Grubhead
