Question about Electronics - Others
What to jump start want to know the positive and negative
  • 122 Answers
If not sure never bolt any thing. use cables ground case touch or tap the terminal if it spins ok if it sparks could be grounded
Posted on Apr 19, 2013
Had to jump car cuz battery was and dead and tmsp is all lines how do i reset it
to jump start a car the following procedure applies
place the positive lead from the jump battery onto the positive terminal of the car battery (clip on)
place the negative lead of the jump battery onto the engine ( clip on) not the car battery terminal
this prevents power surges through the ECM
remove the jump battery is the reverse procedure
to reset an ECM use a scan tool
there are jumper leads now on the market which have surge protection in a lead so in that case positive to positive and negative to negative
Sep 04, 2015 | Cars & Trucks
How do you give a jump start to someone using a 2007 Dodge Charger?
The underhood connections can work by themselves...POS to POS, and NEG to NEG...sometimes dirty/weak connections do not allow the power to transfer fully from the underhood connections...if this is the case then you need to connect directly to the battery in trunk for full power charge...again POS to POS, and NEG to NEG...hope this helps
Jun 09, 2015 | 2007 Dodge Charger SE
What battery pack do I need to jump start my x5
Any fully charged 12 volt car battery will do the job.
The battery leads from the jump start battery to you car battery needs to be connected the following way.
The positive lead to be connected on both the positive terminals on the both batteries and
the negative lead to be connected on both the negative terminals on the both batteries before your start the engine,
May 13, 2012 | BMW X Series & X5 1997 >2006
Jump start yamaha xmax 250?
its posiyive. ground negative to frame
Mar 20, 2012 | 2010 Yamaha XMax 250
Can i jump start my friends focus with my mercedes c230 2006? thank you
You can jump start any car provided the jump start cables have a surge protecter.
Aug 08, 2011 | 2006 Mercedes-Benz CL-Class
Can I jump start the CLS500 from the 12-V lighter plug
Don't do that, if you don't know how the jump start Mercedes Benz be careful it's so dangerous, if you do one simple wrong thing when you jump start it can damage your all electronic management system if in case you did the wrong thing you may have to spend $ xxxxxxx, if you don't know how to do that get help from someone who know how to do it, keep in mind don't mix up negative and positive cable when you jump the battey at least jest for a 000.1 second, that's enough for get damage, battery jump start point in engine compartment have a good look, has covered by read cap, open cap and you can see copper point in it fix the read battery cable (+ positive cable) on it then connect other end of same cable to the + terminal of battery again I would like to remind don't mix up, after connect + terminal please double check did the right, then connect - cable on to the Body ground connection near by positive point you can see another probe for ground it's located near the shockabsober top mount, after that connect other end of negative cable to the negative terminal of battery before connect it once again check other 3 connection are in right order
+ battery......................................................... + car
- battery.......................................................... - car
__________________________________________________________
you can also jump the battery to battery
+ battery jumper................................+ battery in the car
- battery jumper................................- battery in the car,
is this information helped you?
Oct 26, 2010 | 2006 Mercedes-Benz Mercedes Benz CLS500
How do I jump start my 1996 C220 Mercedes
Hook positives to positives on each battery, then hook negative to your battery and other negative to frame of other car.
May 10, 2010 | 1996 Mercedes-Benz C-Class
How do you jump start the battery on a 2004 porsche cayenne ?
it should have one its only covered with plastic cover on it and the proper way to jump it is positive to positive then negative to source and just connect to a good ground the other vehicle..
Dec 23, 2008 | 2005 Porsche Cayenne
Where is negative connection for battery on 2006 dodge charger srt8
Also, to add to some mild confusion, the terminals under the hood on the charger are just there for a jump, thus there is only a positive terminal. The battery is actually stored in the trunk next to the spare.
Oct 13, 2008 | 2007 Dodge Charger SRT8 Sedan
Can I jump start my car from the negative side only?
hey
no you need both cables as the earth is the ground on a car and the positive is the live!!
Damien
Aug 22, 2008 | 2006 Dodge Stratus
Open Questions:
Electronics - Others Logo
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
