Question about Toys
Manual for tidel 3100 atm - Toys
What are the buttons for on a fossil atm 5
Google (fossil)(atm 5)(manual) without parens to find out.
Jul 16, 2017 | Fossil Watches
How to open a tidel tacc IIa safe
Can't open the safe door I have the key but can open the safe door
Mar 25, 2014 | Home Security
Dell dimension 3100 desktop
I have met the same problems, just visit Mannualbirds.com to refer to the DELL 3100 manual, your problem will be well solved! View Dell 3100 PDF User Manual Online
Jan 10, 2013 | Dell Dimension 3100 PC Desktop
Start over with money
Here is a link to the PDF Instruction Manual. I have also copied the instructions for resting the amount to zero:
To Reset Account To Zero:
Turn on the ATM Safe by inserting your ATM card into the slot and entering your PIN code.
• Press and hold the 1, 2, and 3 keys (Fig 8).
• The display will read, "Reset to zero?"
• Release the 1, 2, and 3 keys and then press the "e" key.
If the electronic functions of ATM Safe stops working, open the battery door
(see instructions "To Install Batteries") and locate the RESET button above the batteries.
Press once to reset. Note: Account balance will not reset to zero.
Jan 25, 2011 | Wild Planet Room Gear Atm Safe Bank
I have a problem in my ATM machine.. it shows the error on screen ( communication down) i check my telefone lines its ok ..... and there is no problem in brain net connection ..... plz some one help me...
Different ATM Machines have different error codes. If your ATM machine is experiencing a communication failure it could be a bad modem board, or just a simple phone line problem.
I suggest starting with replacing the phone line. First, plug a regular phone into the wall phone jack, make sure you have dial tone. If you do, get a brand new phone cord and run that into the top of your ATM. Disconnect your ATM phone line inside the head of the ATM and plug that new cord in there. Try and clear the communicaiton error. If that works, try a transaction. If that works, replace old line with this new one.
If that doesn\'t work, make sure you didn\'t lose master keys, and that your ATM is actually online with your processor.
If you are not getting good service, and your ATM has been down for days, you should look into changing your ATM processing.
Google ATM Processing or call 888-501-5246
Dec 05, 2010 | Computers & Internet
Where do I get Goldlok ATM toy manual
Open the door of the ATM
press the star * button and then enter the new code.
Close the door
The code has been changed
Sep 05, 2009 | Toys
Resetting Pin on Blue Hat ATM machine
Hi abbeybath,
We have the same atm/bank for our son. Here's the fix:
1 - push the reset button on the back of the ATM near the battery compartment.
2 - insert the ATM card and press the BALANCE button to change the user name (need to do this before getting to the pin)
3 - enter your childs name and push enter when complete. Cancel will delete an incorrect letter.
4- enter the default pin (1234) - this will bring up the DEPOSIT, WITHDRAWL, BALANCE screen.
5 - Press ENTER and it will show the current/default pin. Input the new pin number you desire and press ENTER again.
All set. Hope this helps!!
Jan 17, 2009 | Blue Microphones Blue Hat Little Shots...
Behringer ex 3100 manual
manual can search in a web site ,,just type GOOGLE when you are in googles type behringer ex 3100 manual
Jun 18, 2008 | Audio Players & Recorders
Toys Logo
156 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
