Question about Power Acoustik PTID-8300NR Car Video Player
28 pin power plug - Power Acoustik PTID-8300NR Car Video Player
2 WIRES FOR 12V SUPPLY. PIN NOs 2 WIRES for Signal PIN Nos. ??
How PC Fans Work - PCB Heaven
pcbheaven.com/wikipages/How_PC_Fans_Work/
Mar 29, 2010 - The connector of a 2-wire fan has a red and a black cable. ... The firsttwo wires are the power supply of the fan. ... This fan is designed to be controlled with a PWM signal and .... I have a four-wire (red black yellow blue) 12v fan out of an old .... My case has a number of 2 pin outputs for multiple case fans, ...
Motherboard Power Connectors ' PC Repair and ... - InformIT
www.informit.com > Articles > Hardware
InformITFeb 28, 2003 - Table 3.3 ATX Main Power Supply Connector Pinout (Wire Side View) .... The auxiliary connector has no +12v leads at all, so that is no help. Pulling up to ...Pin. Signal. Color. Yellow. +12V. 3. 1. Gnd. Black. Yellow. +12V. 4. 2.
ATX 24 pin power supply connector pinout diagram ...
pinouts.ru/Power/atx_v2_pinout.shtml
Rating: 52/60 - ‎60 votes
Jan 28, 2014 - Pinout of ATX (ATX12V) 24 pin power supply connector and layout of ... and later (ATX12V 2) is common ATX standard, 24 pin connector. ... Power Ok is a status signal generated by the power supply to notify ... 10, 12V, Yellow, +12 VDC ... 18 AWG is recommended for all wires except pin 11, which should ...
ATX power supply connector pinout diagram @ pino
Dec 16, 2015 | Cars & Trucks
Can't get the trailer running lights to work on my 2006 F350 Diesel 4X4. Tried the trailer on another vehicle with the same plug and they worked perfectly. All other lights work with the trailer when the...
Check fuse 28 in the fuse block under the left side of the dash. There is also a relay for the trailer park lamps in that same fuse block. The fuse and relay are the trailer parking lamps and run independantly of the vehicles parking lights. You can also try backprobing the other trailer plug (you should have one 7 pin and one 4 pin) to see if there is power at the park light pin. If there is power at the other trailer plug than the fuse and relay are bad and you may have a bad/corroded plug or bad wring to the plug that doesn't work.
Nov 04, 2010 | 2006 Ford F 350 Super Duty
Green light continues to blink. TV does not power up for Mitsubihi model WS 55513 TV
Howdy,
Try these ;
1. LED does not stop blinking after plug in. Verify the standby supplies, 12-volts at connector KA pin 17, 6-volts at KA pin 18 and the 28-volts at KA pin 19, if the supplies are present suspect the DM PCB part # 934C067001.
2. LED does not stop blinking after plug in. Check C9B01, C9B02, C9B10, and C9B11 (1000 UFD 16) on the DM PCB, if they are bad replace them with part # 181P734030 (680 UFD 16 V).
The board is on the left hand side of TV from the back. It is standing up, in a silver box.
Good Luck, BIG IRISH.
Jan 04, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Was working perfectly about two weeks ago--now the green timer light will not stop blinking and the unit will not turn on--I have unplugged the unit for reboot and tried the system reset to no...
Here are few items to check:
1. Check for 12 volts DC (AC-off detect) at pin 3 of PC9A21, if missing replace PC9A21 part # 268P058020 on the Power PCB.
2. LED does not blink at plug in. Check for 5-volts DC at connector RF pin 3 (system reset) if low or missing suspect the reset switch S7L20 part # 432P089010 on the Control PCB.
3.LED does not stop blinking after plug in. Check for 12 volts at connect or PF pin 10 and 28 volts at connector PF pin 11, if the supplies are correct suspect a problem in the DM Assembly (part # 955C230001)
4. LED does not stop blinking after plug in. Check C9B01, C9B02, C9B03, C9B13, C9B14, C9B17 and C9B18 (1000 UFD, 16V, 105C) on the DM Power PCB located within the DM Assembly. If they are bad, replace them with part # 181P734030 (680 uFD, 16V, 105C). See service tip VS-76
5. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature; this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds
6. LED stops blinking after 70 seconds of plug in but will not power on. Check for 4.7 volts DC at connector RF pin 4 and 5 on the Signal PCB if low suspect problems with the switches/buttons on the Control PCB part # 935D587001
7. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector RF pin 4 and 5 check good suspect the E2P PCB part # 935C978001
More then likely it is NUMBER 4, replace all caps if they look/check good or not.
Good Luck, Big Irish.
Nov 22, 2009 | Mitsubishi WS-55859 55" Rear Projection...
2002 jetta tdi died while shifting into 4th gear
Sorry, not a solution to this car but your other vw 1989 jetta...only way I could get hold of you.
here is your diagram
The following information covers electrical connections and plugs to the rear of the fuse/relay panel. It completes and supplements the information in the appropriate Service or Repair Manual for the fuse/relay panel section and should be used in conjunction with the wiring diagram for the vehicle or system in question. Volkswagen part numbers shown here may or may not match those on your panel, however, if you panel visually matches the diagram, it is correct for your application.
Fuse/Relay Panel - Rear Connections (Volkswagen Part Number 171 941 821 D) clear.gif
Connections and plugs on rear of fuse/relay panel:
A Blue 28 pin Instrument cluster wiring harness B Red 28 pin Instrument cluster wiring harness (position 5 open) C Yellow 22 pin Engine compartment/engine management, left side (position 10 open) D White 29 pin Engine compartment/wiper motor wiring harness, right side (position 6. 10, 14, 18, 27, 28 open) E Black 18 pin Rear wiring harness (position 17 open) G n/a 1 pin 10 individual circuits H Brown 6 pin Air conditioning/coolant fan relay wiring harness K Neutral 5 pin Seat belt warning system/coolant level wiring harness L Grey 4 pin Horn wiring harness L Black 4 pin Headlight/dimmer switch wiring harness M Black 2 pin Steering column switch wiring harness M Black 2 pin Headlight/dimmer switch wiring harness N Red 1 pin Separately fused circuits (glow plug wiring harness) P Red 7 pin 7 single point connectors for terminal 30 circuit R Green 2 pin Open/ECM power supply relay
Note: Terminal and harness assignments for individual connectors will vary depending on vehicle equipment level, model, and market. Always consult appropriate wiring diagram for specific terminal assignments.
hope this has resolved your problem
Thankyou
Aug 15, 2009 | 2003 Volkswagen Jetta TDI
We had thunder storms my tv 65613 has a green blinking light wont star
Good Day,mikeybecerra; TV wont come on mb try these 6 items, please pay attention to the blinking light (it's a code) : 1. Check for no 8.4 volts DC at pin 3 of PC9A10 on the Power PCB, if low or missing replace PC9A10 part # 268P058020. 2. LED does not blink at plug in. Check for 3.3-volts DC at connector RF pin 3 (system reset) if low or missing suspect the reset switch S7L20 part # 432P109010 on the Control PCB. 3. LED does not stop blinking after plug in. Verify the standby supplies, 12-volts at connector KA pin 17, 6-volts at KA pin 18 and the 28-volts at KA pin 19, if the supplies are present suspect the DM PCB part # 934C067001 4. LED does not stop blinking after plug in. Check C9B01, C9B02, C9B10, and C9B11 (1000 UFD 16) on the DM PCB, if they are bad replace them with part # 181P734030 (680 UFD 16 V). LED stops blinking after 70 seconds of plug in but will not power on. 5. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector RF pin 4 and 5 on the Signal PCB if low suspect problems with the switches/buttons on the Control PCB part # 935D736001 6. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector RF pin 4 and 5 check good suspect the E2P PCB part # 934C061001. Good Luck, big IRISH.
Jun 30, 2008 | Mitsubishi WS-65613 65" Rear Projection...
Mitsu wd-52628 green flashing timer/power light
steady blinking is the DM failing to complete the boot sequence. Your more than likely needing the DM repair kit.
Jun 18, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Green light keeps blinking? Any clues
The constant blinking green light means that the TV is not booting up. This is a common problem on this set.You need to remove the shield from the DM board (standing upright on the left where the DTV RF connector is)and inside you will see the four leaky capacitors (1000 MFD 16 VOLT)replace them,plug the TV in and wait 70 seconds for the blinking light to stop,then turn on the TV.The hard part will be removing the board from the TV(lots of screws and connectors,takes time)
Sep 23, 2007 | Mitsubishi WS-65613 65" Rear Projection...
73" rear projection Mitsubishi TV
1. Check for no 8.4 volts DC at pin 3 of PC9A10 on the Power PCB, if low or missing replace PC9A10 part # 268P058020. 2. LED does not blink at plug in. Check for 3.3-volts DC at connector RF pin 3 (system reset) if low or missing suspect the reset switch S7L20 part # 432P109010 on the Control PCB. 3. LED does not stop blinking after plug in. Verify the standby supplies, 12-volts at connector KA pin 17, 6-volts at KA pin 18 and the 28-volts at KA pin 19, if the supplies are present suspect the DM PCB part # 934C067002 4. LED does not stop blinking after plug in. Check C9B01, C9B02, C9B10, and C9B11 (1000 UFD 16) on the DM PCB, if they are bad replace them with part # 181P734030 (680 UFD 16 V). 5. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature; this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 6. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector RF pin 4 and 5 on the Signal PCB if low suspect problems with the switches/buttons on the Control PCB part # 935D736001 7. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector RF pin 4 and 5 check good suspect the E2P PCB part # 934C061001
Sep 05, 2007 | Mitsubishi WS-73713 73" Rear Projection...
My TV won't turn on. The Green light just keeps on flashing
Jan 30, 2007 | Mitsubishi WS-73713 73" Rear Projection...
Power Acoustik PTID-8300NR Car Video Player Logo
35 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
