Question about Harman Kardon HK 3380 Receiver
I have a hk 3380 receiver can my ipod be hooked up to it
Just wondering if I can play my ipod through this receiver
5 Suggested Answers
  • 308 Answers
SOURCE: my HK 3380 doesn`t turn on...
If the display does not turn on, then you have a power problem. The unit is not completely turning on. Since you opened up the unit, give it a sniff test to see if there is any burnt odor inside the unit. Check the fuses also. Have a look at the transformer board. It may have several fusible resistors sitting high on the board. If they burn open, there is no power to the display/cpu board.
Posted on Mar 22, 2010
  • 16 Answers
SOURCE: does the 3380 hk have an optical conecction?
No, it doesn't. But is a great stereo amplifier.
Kostiko
Posted on Oct 01, 2011
  • 16 Answers
SOURCE: I have a hk 3380
It looks more likely to have a problem with one of the relays or a 'cold' connection inside the unit.
Kostiko
  • 16 Answers
SOURCE: HK 3380 Receiver - Power turns ON, then within a
It seems that one (or both) of the power amps are defective. To have a quick check, take a meter, sett it on the DC voltage and measure the outputs, one by one (with no speaker attached and no signal) for the short time when the unit stays on. If you have high DC voltage on the outputs (one or both) this means that channel(s) needs repairs (most likely the power transistors are blown). If one of the paired transistors is gone you need to replace both of them anyway.
Good lock
Kostiko
Why does my hk3380 flash protect on the front then shuts down
You aparently have a short somewhere in the speaker wires,
Dec 25, 2016 | Harman Kardon HK 3380 Receiver
How To connect Bose speakers to hk3380 receiver with my sharp hd tv
Step 1:
plug bose speakers in the little holes on the receiver
Step 2:
then turn up the volume and ur done
Feb 23, 2013 | Harman Kardon HK 3380 Receiver
HK 3380 Receiver - Power turns ON, then within a few seconds displays a PROTECT mode and immediately shuts off. I have checked speaker leads for shorting, etc. This unit was operating perfectly and then...
Good lock
Kostiko
Sep 21, 2011 | Harman Kardon HK 3380 Receiver
Does the 3380 hk have an optical conecction?
Kostiko
Aug 31, 2011 | Harman Kardon HK 3380 Receiver
Where do i plug in my ipod in the HK AVR65
There is not a direct connection you can use on this receiver, so you option is to purchase an inexpensive adapter that hooks into the headphone jack of you iPod/iPhone/iPad and splits off into an audio/video cable with a red and white RCA connection. Then you may either chose to hook it into the front input or a specific rear input to send the output to the receiver and play music through your receiver. I don't know for sure, but if you are looking to be able to control it via a remote also and potentially gain video output I think there may be an accessory docking station you can connect to your receiver and doc it to. Check the manufacturers website to see if your model supports this accessory.
May 26, 2011 | Audio Players & Recorders
I have hk3385 receiver and Ipod Touch 4G. I have the cable to connect them. Where do I hook the cable on the receiver (or do I?) and which buttons will play the Ipod music. No video, just music
The manual suggests that you use "A / V 3" (audio / video input 3) for your iPad / iPod audio input. These are the RED and WHITE jacks on the front lower right hand side of the receiver. The YELLOW jack is for composite VIDEO, and need not be connected for "audio only" programs.
Turn the volume on the iPod / iPad to MINIMUM (assuming the receiver volume is at a "normal" setting for the radio, CD, etc.). Connect the cable between the iPod / iPad and the A / V 3 RED and WHITE audio jacks. Select A / V Input 3 on the receiver. Find a song you want to listen to and select PLAY in the iPod / iPad. Slowly adjust the volume on the iPod / iPad up to a comfortable level. If there is distorted sound, adjust he receiver and iPod / iPad volumes up and down as needed. Generally, neither should be set very low or very high.
You can download the owners manual here.
I hope this helps & good luck. Please rate my reply - thanks!
Jan 20, 2011 | Harman Multimedia HK 3385 2 Channels...
My HK 3380 doesn`t turn on...
Mar 22, 2010 | Harman Kardon HK 3380 Receiver
Harman Kardon HK 3380 Receiver Logo
19 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
