Question about ASUS VivoBook X202E-CT033H Touch Laptop, 1 Yr Int. Warranty Black
My screen does not turn on
I got this pxe error message as i turn on my laptop. i read several forums and accessed the bios settings and disabled the pxe. now the screen does not turn on at all.
  • ASUS Master
  • 3,799 Answers
The pxe error message is not important if you are not using the system. It is just telling you that the PXE isn't in operation.
Posted on Apr 19, 2013
3 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: How to resolve the A disk error occurred message?
http://www.ubuntu.com/download
Ubuntu 10.10 Latest Version
which can repair what windows has ruined and is unable to fix fix the problem
either burn it to a disk as an iso and install
you might have burn it to an iso first then boot from the cd rom to install ubuntu or you might just try to install ubuntu directly from the download if it does not install you might save it to a folder then burn it as an iso http://download.cnet.com/active-iso-burner/3000-2646_4-10602452.html
once your computer has corrected and installed ubuntu you will be able to reinstall windows
or keep ubuntu and install windows next door to it
you can have a dual boot computer with both windows and ubuntu linux you will need to partition your hard drive to do this
is a free partition program
http://download.cnet.com/minitool-partition-wizard-home/3000-2094_4-10962200.html
hope this helps
Posted on Jul 30, 2012
If you starts it, there is black screen with the message: media test failure
Go into the BIOS settings at boot up. Disable the option to boot from network, that must solve it :)
May 27, 2014 | Acer Aspire 5100 Notebook
It was working good all of sudden screen became black and the PXE E61
It seems to have lost communication with the hard drive. Check physically (pop out and then back in) and in BIOS. Make sure its the 1st boot option.
Also disable PXE boot in BIOS or remove from 1st boot option. This is a LAN (network) boot option.
Sep 30, 2012 | Acer Computers & Internet
When I turn on my laptop it goes to a black screen that tells me... Intel UNDI, PXE-2.0 (build 083) Copyright (C) 1997-2000 Intel Corporation For Atheros PCIE Ethernet Controller...
based the message that you encounter, it may pertain to boot priority or to BIOS configuration.
My recommendation is for you to access and reset the BIOS settings on your computer.
May 10, 2011 | Acer Computers & Internet
When turn on computer NO WINDOWS XP .On the screen was PXE-E53 : No boot file name received PXE-MOF: Existing Broadcom PXE ROM Operating System not found
That means your computer trying to boot from LAN port. Go bios and change the settings of PXE boot to disable and make Hard disk as first boot device. Save the settings and restart your pc. It will work
Mar 31, 2011 | Acer TravelMate 4101WLMi Notebook
Error Message: PXE-E61 Media Test Failure Check Cable
Try resetting the BIOS to the default settings and reboot
Nov 28, 2009 | Compaq Armada E500 Notebook
My tosiba a70-kl1 starts up with a black screen and error messages stating "PXE-E61: Media tes failure, check cable" and "PXE-M0F: Eiting PXE rom"
You haved enabled the capability for your computer to "boot" itself by reading from a boot-server connected to your network-cable.
But, the network-cable is unplugged, resulting in the "check cable" message.
What this _could_ mean is that the computer primarily tried, and failed, to boot from your disk-drive, and secondarily tried, and failed, to boot from your CD-ROM, and so it made a tertiary triy, which failed, to boot from the "network", i.e., that your hard-drive is not functioning.
Reboot, and enter "BIOS setup", and disable the "boot from network" option, to get rid of those error-messages. But, it's still possible that your disk-drive is malfunctioning.
Sep 14, 2009 | Toshiba Satellite A70 Notebook
Receiving PXE-E61 media test failure/PXE-M0F exiting intel PXE RO
If you get this error in a black screen before windows xp can boot up....
CLIENT MAC ADDR: xxxxxxx GUID: xxxxxxxxxx
PXE-E53: no boot filename recived
PXE-MOF: exiting intel PXE Rom
Your network card's settings in bios have somehow been changed. PXE means Pre-Execution Enviroment. In other words, it allows your network card to connect to a network server to pull operating system images off the network and other files without having an operating system installed.
The Fix,
Go into BIOS press F2 or F12 whatever your PC's screen at bootup says. In Bios, reset your bios settings to the default bios settings, or original settings. This fixed my problem with the above error. Nothing else fixed it. Windows Recovery cd will not fix it, because you cannot boot windows if this error is still occuring, Your network card will keep prompting DHCP to search for a network.
Its a bios function not a windows function.
Jan 21, 2009 | Toshiba Satellite A135-S2276 Notebook
Cant get to home page
Your laptop doesn't recognised hdd.
You should go to bios to see if your hdd is there.
if you don't see your hdd in the bios, most of the time is harddrive problem (dead).
In this case, you can replace your hdd.
but if you see your hdd and you get PXE-E61 error message, your OS might be corrupted.
Oct 16, 2008 | Acer Aspire 5630 Notebook
Broadcom UNDI PXE-2.1 v10.0.9
The Broadcom PXE looks for a boot device/files from a network source if the network cable is't plugged in then you get the PXE-E61: Media test failure check cable, you can turn this off in the bios, when this doesn't find any boot information it moves onto the next boot device which is defined in the bios, usally the dvd drive then the HD. If this is a Altos server you have bought they are not supplied with an OS so it wont boot from the HD to begin with, if you already had a OS installed and it wont boot then there is something wrong with with the HD or the connectors or posibly the boot sectors are corrupted, if the device is making th tak tak noise the it is having trouble reading te device.
Jan 08, 2008 | Acer Aspire 5315 Notebook
ASUS VivoBook X202E-CT033H Touch Laptop, 1 Yr Int. Warranty Black Logo
232 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
