Question about Craftsman Garden
Where can I buy a bendix for Sears Craftsman LT1000 Briggs & Stratton TWIN 21 hp riding tractor mower starter
The black plastic gear (possibly called the bendix) is worn out and as a result the tractor won't start. I am looking for a place where I can buy it.
kevin000
  • 1847 Answers
SOURCE: Briggs and Stratton 17HP Intek Governer Overspeeds
Can you Regulate the Engine Speed Using the Governor Arm? If Yes, then Reset the Governor. **To Reset the Governor; Loosen the Governor Arm Bolt and Turn the Governor Shaft Clockwise Until it Stops. Using the Governor Arm Hold the Carburetor to Full Throttle. Now with the Shaft Full Clockwise and the Governor Arm and Carburetor Held at Full Throttle, Tighten the Governor Arm Bolt. If the Engine Still Runs Full Throttle, then Reverse the Rotation of the Governor Shaft, but Still Hold the Carburetor at Full Throttle with the Governor Arm. If it Still Runs at Full Throttle, then Check the Internal Governor.** If you Can Not Regulate the Engine Speed Using the Governor Control Arm, then Check the Carburetor Throttle Valve. If the Throttle Control Valve (sometimes called a Flap or Plate) Mounting Screws Came Out of the Control Valve, then you will have No Control Over the Engine Speed. Send me the Model and Type or Spec Numbers Off the Engine, Please. With these I can Locate the Proper Manual and Better Assist you. **The Throttle Cable Attaches to the Throttle Control Bracket. The Cable Moves a Slide that Moves a Pivot. The Pivot has the Spring Attached to it and to the Governor Arm. The Solid Link Connects to the Governor Arm and goes to the Throttle Shaft on the Carburetor. When the Throttle Cable is Moved it Moves the Pivot and the Pivot Pulls the Spring. The Spring Pulls the Governor Arm and the Governor Arm Moves the Throttle Shaft. Usually the Spring is in the Lower Hole in the Governor Arm and the Solid Link is in the Top Hole of the Governor Arm.** If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens
Posted on Sep 24, 2008
  • 49 Answers
SOURCE: Removing tire from SEARS CRAFTSMAN LT1000 TRACTOR.
You need to remove the black rubber cap from the center of the wheel. Remove the "C" clip from the axle and the wheel should come off. The rear tires will have a square key in it. Do not loose the key.
Posted on Jan 29, 2009
  • 3 Answers
SOURCE: Huskee 25 hp lawn tractor with briggs & stratton motor wont start
Most all manufacturers have the Users Manuel available on line you will need the Make and Model to pick the correct one. Have you replaced the battery. It can show the correct voltage but have no cranking amps. I believe if the solenoid is trying to engage the Dead Man switches are closed. With the starter disconnected from all power sources do the teeth on the starter turn or are they locked up? If they refuse to move do you have an Auto Zone around or another parts store or electrical engine repair store that can test the starter. Make sure the mowing deck is not engaged while you are trying to start the engine. I hope these rudimentary suggestions help.
Posted on Jul 18, 2009
  • 257 Answers
SOURCE: Mower cutting off when the engine heats up (Sears Craftsman)
sounds like you have magneto getting hot,,, next time it do it,, let it cool off for about 2 hours see if crank and run again till shut off,, if if does replace magneto,, hope this help,, good luck
Posted on Aug 15, 2009
jdlipscomb41
  • 157 Answers
SOURCE: MTD Riding Mower with 21 hp OHV 1/C
the valves need adjusting
Posted on Sep 18, 2009
Did a Tune-up, now the Starter just Free Spins, Bendix not engaging, How to Fix, without Replacing Starter?
Try the starter off the mower to see if the bendix works. See if there is any adjustment at the starter mount, play in the mounting holes.
Aug 29, 2015 | Craftsman Garden
What briggs valve gap lt1000?
Briggs opposed twin cylinders don't have valve gap. Single Cylinder OHV & V- Twin OHV do.
Jul 13, 2014 | Briggs & Stratton Garden
Craftsman 21 hp lawn tractor motor seems frozen
Did it leak oil & seize up
Can you turn it over by hand
Is a belt or bearing preventing the motor
from turning?
May 08, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
WHAT WEIGHT OF OIL IS NEEDED FOR A YS4500 W/ A 21 HP BRIGGS AND STRATTON MOTOR
I have used 30 WT oil in all my 4 cycle engines. You could google Briggs & stratton to get some info. Sears will sell you an operators manual. Try googling Sears, you might get lucky & get the manual for free..
Louie Almond
Mar 27, 2011 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
I have a sears craftsman tractor,18 hp electric start. No. 917.254860. engine no. 422707,type no. 1522.01. briggs and stratton. engine won,t turn over. Replaced plugs,coil,carborator rebuilt to specs. New...
From your description it seems that the starter is not engaging to turn over the engine. First ensure all the connections of the thicker cables to the battery, starter and tractor frame are clean and tight. If starter motor is turning but still not engaging it will mean that the pinion on the starter motor is binding on the shaft. You can buy a new starter pinion gear from your local B & S agent.
To replace pinion, remove starter motor from engine, remove old pinion and put on new one and reattach starter to engine. If fuel & spark are right you should be up amd running.
Sep 16, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Craftsman 17.5 LT1000 Won't Start - Need Help
pull the flywheel and check if the key(latter models the flywheel itself will need replaced if stripped)is damaged. This is a possibility.
May 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lawn Tractor won't start Craftsman LT1000 17.5 OHV
The starter bendix is not engaging properly the bendix pushes the starter gear into the flywheel gear when the starter spools up, it may need minor lubrication.
It sounds like the engine is not getting fuel as it should, the main jet may be restricted from varnish if she stumbles under a load especially if the plug tips are white after running for 1/2 an hour.
Remove the float bowl and clean the jet, make sure the fuel is still good, gas that smells like a library is more like varnish and less like fuel.
Garden Logo
37 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
