Question about Tally T2250 Matrix Printer
Hardware alarm 00032 error showing
2 Suggested Answers
  • 169 Answers
SOURCE: my printer is showing error as "hardware alarm +1308 +131 --- 000004+0381+1317" wat could be the problem
The hardware error indicated on your printer is indicating that the printer is encountering problems when moving the print head.
This error can be indicated if there is any thing which may be preventing print head movement, things you can check include;
The printer ribbon is not jammed and is located correctly in the printer,
You can also check to ensure there is no paper jam of loose paper which may prevent print head movement,
You can also check the carriage shaft to ensure it is free from paper dust or any other obstructions.
With the printer powered off, the print head should slide freely across the width of the printer, you can then see if there is any obstruction to the printhead
Posted on Dec 12, 2011
What is the problem when a Tally T2265+ printer show the error message? How to clear this error message?
it sounds as if this will be a problem with a board and you will need to have it replaced
Jun 20, 2014 | Tally Office Equipment & Supplies
My printer is showing error as "hardware alarm +1308 +131 --- 000004+0381+1317" wat could be the problem
Nov 18, 2011 | Tally Matrix T2280 Printer
Error lost cpu rest
This error on the T6125 may be caused by either a hardware fault with the printer, alternatively the problem may be caused by some sort of external influence on the printer. Passable resolution to the problem include;
Hardware Fault
Locate the main logic board, check the CPU to ensure all pins are soldered correctly on the PCB. Check there is no solder over spill shorting any of the pins.
There may be a fault with the main logic board which may require replacement.
External Influence
1) External Print Server
One of the most common causes for the LOST CPU error is the use of external print servers connected to the Parallel Interface.
These printers are not reliable if connected to external print servers unless the printer parallel interface has been set Uni-Directional. To do this, you need to follow these instructions.
Set the printer to Offline.
Press the Enter and LF keys together for approx 3 - 4 seconds. The alarm will sound. (Tech Access On)
Press the Mode key: display will show Offline Normal.
Press any Arrow key until display shows Offline Config.
Press the Forms/1 key.
Press any Arrow key until display shows Config Parallel.
Press the CPI/2 key.
Press any Arrow key until display shows Parallel Bi-Dir.
Press the LPI/3 key.
Press any Arrow key until display shows Bi-Dir Off.
Press the Enter key and the interface will be set.
Press the Clear key.
Press the Enter and LF keys together for approx 3 - 4 seconds. The alarm will sound. (Tech Access Off)
On the external Print Server, you need to ensure that the unit is also set for Uni-directional working.
Electrical Interference
Check the area around the printer to ensure there is no external electrical interference eg Electric Motors, High Voltage Cables in near vicinity of the printer.
Feb 21, 2011 | Tally T6215 Matrix Printer
What is error code 6500?
This is an error indicating a problem with the Logic Board Assembly. It's probably not worth fixing, with printer prices being fairly low.\
According to the MP800 Service Manual:
2-2. Service Call Errors (by Cyclic Blinking in Orange (Alarm LED) and Green (COPY button), or
Alarm LED Lit in Orange)
Service call errors are indicated by the number of cycles the Alarm LED and COPY button blink, and the corresponding error
code is displayed on the LCD.
*Cycles of blinking in orange (Alarm LED) and green (COPY button) - 20 times
*Other hardware error - Error
*Error Code - [6500]
*Conditions - The PCI bus error is detected by the ASIC.
*Solution (Replacement of listed parts, which are likely to be faulty) - Logic board ***'y
Aug 21, 2010 | Canon MP830 All-In-One Printer
Tally T2250 showing an error..
when power on the printer the printer coming leftside and showing hardware alarm
check ribbon
+0306ne -007 000
000000128 +0304
error in display. how to rectifie the problem
Jan 29, 2009 | Tally T2250 Matrix Printer
Tally sprint pro
Please tell me the hardware alarm number . The number will display onthe control pannel LCD of your printer. Then only I can help you.
Aug 26, 2008 | Tally Matrix T2280 Printer
Please help
I am already faced this problem, This Problem is due to Bad Head cable. Repaced that cable, your Problem will be resolved
Aug 20, 2008 | Tally Dot Matrix T2265C Printer
Tally t2155 - Showing "Hardware alarm wrong board"
change the logic board. your problem will solve.
Jul 29, 2008 | Tally Serial Matrix T2155 Printer
T 2250
tally t 2250 give hardware alam
code +03211 ne -007000 000000 128+0304
Jan 19, 2008 | Tally T2250 Matrix Printer
Tally T2250 Matrix Printer Logo
21 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
