Lg tv str w6554a power supply problem find
I want STR 6554A pin voltage
    Top Expert:
  • Televison & ... Master
  • 75,025 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Circuit diagrams of SMPS section of many popular brand devices are given. Search the site by type in the "brand name" or the "STR number" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
Posted on Nov 19, 2016
SOURCE: tv trouble shooting
what the fuck. speak english
Posted on Feb 03, 2008
change the capacitors in the primary
Posted on Jan 19, 2008
SOURCE: 54cm Goldstar tv Model no: CZ 20A 90Y
ordinary zener diode
Posted on Mar 28, 2010
SOURCE: switching of a str 6707 in onida tv
Posted on Sep 03, 2012
SOURCE: Panasonic television power supply problem
no picrure and filamen got light
Posted on Oct 25, 2012
LG tv str w6754 glows and short. power supply is not working?
Replace that STR. Before replacing, check all the related component/s at the SMPS section [HOT] side. any one damaged component will make the replaced STR to fail. If you wish to get some details; check the site linked here. Pull up older posts.
SMPS Circuit diagrams [STRW6754] of many popular brand TVs and other devices are given.
Search the site by type in the "BRAND NAME" or the STR number; of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 04, 2016 | LG Televison & Video
Need to know which optocoupler ic is used in str 6267 based power supply in sony trintron crt tv
Sony FD Trinitron WEGA... Repair Questions - Fixya
Hello, i have a sony FD Trinitron WEGA #KV-36FV310 ... Need to know whichoptocoupler ic is used in str 6267 based power supply in sony trintron crt tv.
Sony KV-TG21M61 21" TV Repair Questions,... - Fixya > Forum > Standard (CRT) Televisions > Sony
Need to know which optocoupler ic is used in str 6267 based power supply in ... My sony crt Tv totally dead when touch any components and the IC strs6307 ...
Tv code hi i'm looking for a 3 diget programming code for my ...
Dec 21, 2015 | Sony Televison & Video
No power supply regulating and str no x6757
The STR or voltage regulator is probably bad. If you are not familiar with soldering and using a multi meter for troubleshooting then I suggest buying another power supply they are not too expensive. Try e-bay. Good luck
Mar 23, 2014 | Computers & Internet
Sony 2185 mt dead
is k digram nhi hai sony 2165m
Dec 30, 2011 | Televison & Video
No Display, no sound- not working, showing dead. But input Power is ok. Picture tube filamment not getting power. model sony KV-2192M3
Check the input fuse first. If it is blown, there will be some short inside the power regulator circuit. Usually Sony sets uses STR regulated power supply. You can see this STR, and Ic, screwed onto a heatsink. Replace it with a same type and number. Before replacing the STR, check the diodes used in that section for damage, mainlu zener diodes. They might get shorted along the blowing of the STR. Check that section throughly before resoldering the new STR.
If any further assistance you needs, get me through Fixya. Ok.
Nov 27, 2010 | Sony FD Trinitron WEGA KV-21CL10 21" TV
In my tv fuse is blowing off immediately
If fuse blows off immediately, i means that there is a short circuit occured in your telivision. This can mainly due to some diodes or regulators inside your tv. An overvoltage, spikes, ie [sudden high rise and go low], in the supply votage in your home, could damage power supply regulator components inside your tv.
All Sony Tvs has high accuracy power regulating systems inside. It is an onboard assembly, usually take 1/4th of the area of the TV. In older Sony TVs, this section was built in with use of transistors of different types. But your tv is not so old, so its power supply system is built with an STR, an Ic meant only for power regulations. Normally it willb numbered STR S6707, STR S6703 etc; according th the working voltage of the main board, and screen size of the TV.
This STR may get shorted due to power fluctuations, or any other reasons. A I mentioned above this is an Ic look like small squuare biscut of about an inch in square, and will be black in colour.
The rectified main power supply is given to it via an SMPS transformer [Swiched Mode Transformer], and the Ic will swictch it on and off at the rate of sbout 25KHz or more, and this transformeres secondary voltage is used to power up the other part of the ciiruit board.
If the fuse is blowing as soon as the set is switched on, this Ic will be faulty [Shorted inside]. If you put an another fuse, it also will blow up due to short. It is not good to play with power supply system by doing this as it may harm to other components also.
You have done it I thinks. Here in India, we gets 220VAC as home power supply. Sony TVs used here have a fuse rateing of 250V 3.5Amps. If your household supply system voltage is also this you must put only this rated fuse. If it is 110 or 120VAC, the fuse rating may differ; and will go upto 6 to7 Amps. More than this rated fuse should not be used.
You just do one thing. Just open the back cover of the TV, locate the power regulator section, and chech whether any main rectifier diodes for leak. There may four of them. In some sony Tvs, rectifier stalks are used. Check it for leak. If thery are all good, measure the resistance across the main filter capacitor with a multimeter set in Ohms range. If the STR said above is short, the meter will give full scale deflection. Unsoder the STR and pick it out after loosing its fixing screws to the heat sink. Again check the resistance accross the main filter capacitor. It must sho a low deflection or no deflection at all. Never replace the STR with a new one as there may be some other faulty components in that section. Usually when STR fails, there are some Zener diodes, Wire wound resistor etc will also gets shrted. If you replce the STR before checking them for fault, the STR you puts in will get shorted as you swich on the set. It will take just 1/100 part of a second.
So check all the components related with power regulator system, and then only repace the regulator. Caution: Keep chlidren away from you while you open the tv. Never touch any part of the circuit board while power supply is there. Plug out from the wall socket each time you touch the printed circuit board. As your Tv screen size is 32", an approximate of 25KVDC [15,000VDC], will be present at the first anode of the picture tube while it is working. It is too dagerous to contact.
If you haven't through knoledge, skill and patience, never try to repair it. If you knows to follow its schematic digram, buy one book and follow the circuit.
Keep an adult beside you as you try to repair your set, as a precaution.
If you have any doubt, report to Fixya, they will give me alert. Ok
Oct 20, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No power
check voltage at the primary filter then check voltege at pin no 1 of STR dc which should be approx input volt if not then clear the path if present then check check up down volt at pin no 3 if not persent then replace the small capacitor near it the problem will be solved
Sep 10, 2008 | Compaq FS 7550 17" CRT Monitor
Tv trouble shooting
whenever any fusible resistance fails means there is a short ckt in tv. failure is mainly due to main filter cap or rectifire diode os switching ckt failure(here as you cleared str.) remember while servicing power supply isolate hor. section for safety purpose.& connect it only after power supply output is ok &after checking parts in hor. ouyput section. if this seems to be ok then go for hor.output ckt failure like hor output,flyback transformer & cap& diodes connected with it.
Oct 02, 2007 | Televison & Video
Televison & Video Logo
1,126 people viewed this question
Top Televison & Video Experts
