Question about Emulex NETQue Print Server
Contact How to get contact with the printer server. I don know the ip adress of the server
  • Erwin Hart Aug 03, 2007
    Well it worked out, but (theres alwayas a but). I resolved the ip adress and changed it to my network range with hyper terminal. If i type in the just assigned ip adress, i get the configuration tool (network printer manager) If i want to change something, it keeps on asking for a password (see jpg). I have administrator rights on the pc. I laso did a "reset to factory default" with hyper terminal, but it seems to remember the password even after the reset to default. I cannot add a printer because of this problem. I hope to have a soon awnser.
    Regards
    Erwin
    President:
  • 1,114 Answers
The following link will tell you how to connect a serial cable & set the address: http://205.200.75.226/support/printer/emulex.html
Posted on Aug 02, 2007
  • Greg Cann
    Greg Cann Aug 03, 2007
    "access" is the default printer server remote login password...
SOURCE:
I'm using ricoh aficio 2045e, it's not printing! I think because I don't have the hostname or the ip address and I don't know from where to get it?
Enter in SP mode and print the ALL SMC report .In this report find the IP adress.Enter in your PC printer device the IP adress.
Feb 17, 2013 | Ricoh Aficio 2045e 2035e Copier...
Hp laserjet P2055dn - print config report indicates IPv6 Address, will not network print. How can I clear this?
IPv6 is upgraded from IPv4 (Internet protocol).. Its implemented in 1994 this adres is stored in DNS, it is no way connection with the printer, when the printer is connected through lan net work, auto IP adress will assign by the DNS server depend up on the settings.. you can change the desire IP adress with the family range. If the printer is not showing IPv6 adress, system administrator can help you in this regards depens upon their permissions. Selected printer IP adress ahould be with in the family range and no IP conflict definately printer will work..
Nov 19, 2011 | HP Office Equipment & Supplies
HP 1312 printer running wirelessly from a laptop (Windows 7). Has always worked fine. Turned printer off when we were on vacation; now printer is "offline." Have reinstalled printer driver and...
Hi!
The problem you described can have multiple causes.
But one is more common:
Every device on your home network (wired or wireless) has its own IP adress. Usualy this IP adress is given automatically by the DHCP server contained in your wireless router. When a device is turned off for some time, it can receive when turned on again another IP adress than before.
So, if your printer has no static IP adress (entered by yourself during printer setup), it is very likely that it has now other IP than the address known by your computer. The computer sends the print jobs to the old adress and of course, nothing is printed.
Please check in your printers proprieties the adress of the TCPIP port assigned tom it, and also check on your router's management site what clients are connected to it.
The network communication between the computer and the printer can be checked by issuing a PING command from a command prompt.
e.g ping 192.168.1.***
the numbers are one example of an IP adress.
Please let me know if it helped, if you need more help ask again, I'll be glad to help you to get the problem solved.
Regards,
Bogdan
Aug 21, 2011 | Office Equipment & Supplies
We are trying to download the drivers for a network but it is asking for the IP address IPv4 and we don't have it. Could you provide it.
well check your printer machine IP address...just like a computer printer machine have their own IP.then use the IP of you printer...
Jul 21, 2011 | Panasonic Workio DP-190 Multifunction...
Attempting to print to my Sharp ARM237 Network printer. It gives me the error Unable to access server. Check server address on device web page" . It used to be networked then I moved the loacation...
you must put the right IP adress for the machine: from the menu
  1. choose system setting
  2. Network settings
  3. IP address setting
  4. copy the the ip adress from your computer and type it in the special field
Dec 06, 2010 | Sharp AR-M237 Copier
Bought a printer server called Networking USB LPR Print server. It`s softwear does not support OKI but the install wizzard asks for installation disk from OKI. When I start the OKI driver installation...
  1. log into router
  2. look at the leases issued by the dhcp server in the router
  3. note the ip address assigned to the printer
  4. change the lease to be permanently leased to the printer server
  5. the print server will have a device name . you should be able to figure out which ip address is assigned / leased to it .
  6. You never assign a print server , or server or printer with a temporary dhcp ip address ! hence why you should change the lease of it to permanent .
  7. Then it will be assigned the same ip address by the dhcp server .
Mar 18, 2017 | OKI Computers & Internet
Adding IP addresses to a HP 5550 DTN printer
ok then install that printer as a network printer to one pc share ti and ad to as much pc you need after that without ip adress
Dec 10, 2008 | HP 5500 Color Laser Printer With Internal...
Email Address Problems
You must enter a DNS server on the "Network Settings > TCP / IP" page. If you're unsure of it, try copying your default gateway.
Jan 31, 2008 | Samsung CLX 3160fn All-In-One Printer
Ip adress config/dns server
when using a static IP you must also get the DNS server addresses from your router's manufacturer. the primary/secondary DNS for D-Link routers are 4.2.2.2/4.2.2.3 respectively. contact the customer support line of your product or do a Google search for"_______ dns" (____ being your product name)
Jan 13, 2008 | Computers & Internet
Cant change or remove the password.
with some system you will have to use ctlr H before the password system
this removes the space so the password is correct
Aug 03, 2007 | Emulex NETQue Print Server
Emulex NETQue Print Server Logo
375 people viewed this question
Top Emulex Computers & Internet Experts
Alun Cox
k24674
Are you an Emulex Computer and Internet Expert? Answer questions, earn points and help others
