Question about Dell Inspiron E1505 Notebook
Dell ispiron e1505 system halted nmi check ioc chek
Hardware mulfuction nmi check ioc check has system halted call your hardware wander
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 69 Answers
Any new hardware installed recently? check event viewer (start>control panel>(small icon view) Admin Tools> Event Viewer> Filter to System and catagorise for Hardware failure.
Posted on Apr 19, 2013
3 Suggested Answers
  • 110 Answers
SOURCE: my computer is experiencing problem right now. It
Pls try to restore the laptop in last know good config mode.
Posted on Nov 19, 2009
joecoolvette
  • 5660 Answers
SOURCE: Call your hardware vendor for support NMI: Parity Check / Memory Parity Error *** The system has halted
1) ALL power removed, AC adapter (Charger), and Battery
2) Lay a soft cloth down on the table you are working on.
(DO NOT work on a bed, couch, or directly on a carpet floor. HIGH areas of Static electricity)
Lay the Dell Notebook PC upside down on the cloth.(Helps prevent scratching the notebook, and the table)
3) Remove all Ram Memory module/s. ('Stick')
http://support.dell.com/support/edocs/systems/xpsM1530/en/SM/memory.htm#wp1180190
[From,
http://support.dell.com/support/edocs/systems/xpsM1530/en/SM/index.htm ]
Handle the Ram Memory module by the BODY.
The Body is everywhere on the Ram Memory module, EXCEPT the gold plated contact pins on the bottom.
The Body is coated with a see-through protective plastic,
http://en.wikipedia.org/wiki/File:1GB_DDR2_SO-DIMM.png
Use a pencil eraser to clean the contact pins. ALL pins, BOTH sides.
If you are using a pencil eraser on the end of a pencil, and not a solid eraser, refrain from letting the metal band of the pencil, touch the gold plated contact pins.
Rub up, and down on each contact pin. Doesn't take much pressure, nor rubbing to clean them.
In fact when you are done the contact pins may not be bright, and shiny.
It's okay I assure you that you have cleaned them.
(Doesn't take much 'corrosion' to make a bad contact surface)
Use air to remove the eraser dust. If you have a can if compressed air available use it. (Also use on the ram memory slots)
If not air pressure from your mouth will be sufficient.
Reinstall all Ram Memory modules.
Reinstall the Battery, and then plug the AC adapter in. (Then plug the AC adapter into power)
WAIT 1 minute, turn the laptop on.
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Oct 18, 2012
Nmi channel check iochk
Go to your device manager and check if there is any hardware driver missing or malfucntioning then re-install that driver.
Sep 29, 2013 | Dell Inspiron Computers & Internet
Hardware malfunction call your hardware vendor for
It appears you have one or more bad memory chip. If you have more than one try removing one at a time to see which is bad.
Jul 14, 2011 | Dell OptiPlex 330 Desktop Desktop Computer...
Bij doorstarten moet ik steeds f1 indrukken en bij het afsluiten krijg ik een blauw scherm met de tekst Hardware malfuction call your hardware vendor for support NMI:parity check/memery parity...
NMI parity error (Non-maskable Interrupt) is generally a motherboard or a RAM issue.
You can try flashing the BIOS to A04 (You'll need to copy the flash executable to a bootable CD or bootable USB drive to run the flash.
Try individual or different RAM modules
if all those do not resolve, issue is most likely the motherboard.
Jul 07, 2011 | Dell Dimension 3100 PC Desktop
My laptop has crashed and gives the following message hardware malfunction call your hardware vendor for support NMI: parity check/memory parity error The system has halted
could be a defective Ram memory. or some bigger problem with the motherboard
follow this link how to replace or workaround with your problem.
http://support.microsoft.com/kb/315223
i hope this help.
Dec 18, 2010 | Computers & Internet
HARDWARE MALFUNCTION CALL YOUR HARDWARE VENDOR FOR SUPPORT NMI : PARITY CHECK / MEMORY PARITY ERROR THE SYSTEM HAS HALTED what should i do now
Hello sumeetbapu,
Here are 2 suggestions which might be helpful in determining the cause of the nmi error:
• 1. Use the Windows Memory Diagnostic tool to test the RAM on your computer:
http://oca.microsoft.com/en/windiag.asp
• 2. Review this article from Microsoft Developers Network: What does an NMI error mean?
http://blogs.msdn.com/b/oldnewthing/archive/2007/02/27/1769274.aspx
Finally, you may need to replace a memory module. If you need help with replacing the memory, please be sure to ask.
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Jul 07, 2010 | HP Pavilion dv6000z Notebook
No sound on ispiron 6400 it says i have codec hd sound card
If the device manager says hardware is installed, then you have an issue with the hardware. Call Dell for replacement system board.
Nov 10, 2009 | Dell Inspiron E1505 Notebook
Dell Inspiron E1505 Notebook Logo
180 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
