Ron,
I am not sure which codes were used, but you can check out http://www.mydish.com/support/apps/remotecodes.aspx to view our entire list available. I am unsure if the AUX mode will work with the OTA converter. I have listed the steps below to do a power scan which lets it go through all available codes. If you have a model 20/21.0 remote, you can also utilize the learning function on the remote.
With the OTA Converter on, press and hold the AUX mode button (about six seconds) on the top of the remote until all mode buttons light up, then release. Press 2, then press STAR (*)
Press the Up arrow button once per second while pointing the remote at the converter. If the code for it comes up, the equipment power off.
When it does, press the POUND (#) button. If the code entered is valid for the remote, the mode light will flash three times. To verify the code works try several different functions for that equipment.
Tommy Faust
DISH Social Media Representative
SOURCE: I'm adding an over-the-air antenna to my DISH
You shouldn't need to. You should get your local channels from Dish on the low channel numbers, like 2 through 70.
SOURCE: Is it possible to have two remotes for the dish
Hello my name is Mike Houston of DISH Network customer service. There is a way to have two remotes on one TV, the first thing we need to push the menu button two times to get to the system info screen on the working remote. Then there will be a number in a white box at the button of the screen, we will want to remember that number so we can put it in for the second remote. Now once we are on the SYSTEM INFO screen we will want to get the remote we want programmed to that receiver, we will hold down the SAT button on the remote until all the buttons light up on the top of the remote. We will let go and then press the number that we wrote down and press the # button. Now both remotes will change the satellite channels.
SOURCE: what are the Dish Vip 211k receiver codes
Hi turk0050 my name is Mike Houston of DISH Network, there are manydifferent codes that go to our DISH remotes. There are steps that will allowyou to program your DISH Network remote to your TV. The first step is to holddown the clear TV button for 6 seconds and then press and release the red Powerbutton. Then press and release the Channel Up button until the TV turns off.Once the TV is off press the # button and tries your volume and mute button tomake sure the remote is working. I will send a link to help with the setup ofthe remote. http://www.dishnetwork.com/SupportSection/power-scan-instructions
SOURCE: I just got a new Dish VIP 211K system. I am
Hello, Cheri Torres with DISH Network Customer Service here.I came across your post and wanted to see if I could help. We have a fewdifferent codes for each of our different models of remotes. I will list herefor you the best codes for the more popular models of remotes and also theinstructions for addressing the remote to the TV. The best codes for the SonyDVD/VCR are 817, 778, 818, 768,005 and 002. I hope you find these codes andinstructions useful but if you do not I will also list here for you theinstructions for running a power scan which can sometimes find the code foryou. If you have any other questions or concerns feel free to email me [email protected]. :)
Instructions for addressing your remote to your DVD/VCR
Instructions for running a power scan
Then Press STAR (*)
SOURCE: what is the code for dish receiver vip 211k
Eugene Sebik,
I would be happy to look into this further with you! What are you trying to address? There isn't a code required for our receivers, but to program a remote to a TV needs a code. If you can provide more details, I would be happy to assist you! I have included a link below that has codes for programming the remote to most devices!
Link: http://www.mydish.com/support/apps/remotecodes.aspx
Tommy Faust
