Question about IBM ThinkPad T40 2373 Notebook
Ibm t40 is overheating and locking up
It boots up fine without the battery attached...but locks up after running a few minutes...fan seems to be operating ok...it gets hot after a few minutes...could it be a logicboard problem or the fan?
I have a userid and password which I forgot on my IBM Thinkpad T40 2373 and was told I need to take out the internal battery for a few minutes and put back in. Where can I find it?
Get a program called Ophcrack, burn this onto a cd, so Boot from cd when you start the pc, you have to go in to boor menu the set the pc to boot from cd first not hdd
Sep 09, 2010 | IBM ThinkPad T40 2373 Notebook
BIOS locked out on IBM T40 and T42
visit this page to answer your problem. God Speed
Apr 07, 2010 | IBM ThinkPad T40 2373 Notebook
Thinkpad 2373: boot and freeze problems.
raodonald
If you are having trouble with your fan running it is possible that the notebook is over heating.
Think about when it ran good and when it did not. Was the fan running and/or was it cooler at that time. Also if you are in a place where it is cool outside you might take the system outside in the cool to see if this makes a difference.
If is does work more when it is colder then most likely the fan is not cooling the system properly.
Let me know if you have any more problems or questions
Issken
Jan 18, 2010 | IBM ThinkPad T40 2373 Notebook
Laptop does not boot except when on AC, not a battery problem.
estas en lo correcto hazle revisdar el cmos y la ram que cuando estan por dañarse ocasionan alogunos problemas
Aug 24, 2009 | IBM ThinkPad T40 2373 Notebook
Ibm thinkpad t41 does not boot up...just black screen...fan works
hehe...I used to have some problems
and then came up with the solution to install other OS such as linux, lindows or anything else
and then reinstal it with windows booting...and then it works, u can try it
Jun 21, 2009 | IBM ThinkPad T40 2373 Notebook
T40 intermittently crashes and recovers "from a serious problem"
If you have not upgraded of changed your power supply, you probably should. Also, you could be having troubles with your RAM. Have you try to perharps repair or re-intall window?
Let me know
Apr 13, 2009 | IBM ThinkPad T40 2373 Notebook
T40 hangs after boot up. Sometimes does not show anything on boot
it may be because of the cpu cooler is so full of dust that the fan cant go around and the cpu gets hot and the whole system freezes or something else is totaly screwed up
Jan 04, 2009 | IBM ThinkPad T40 2373 Notebook
IBM T40 Laptop screen goes black, will not come back
First of all, you have to check whether you can see video signal with surrounding light tilting the screen.
If you can see dim image, all you have to do is replace back-light inverter or fix it. Usually, the fuse is open and you can connect it by simple soldering.
If you can't see dim image, it is another problems.
Give it a try.
Dec 09, 2008 | IBM ThinkPad T40 2373 Notebook
IBM Thinkpad T40 Problem Booting Up
I have a T41 doing this, and pressing on the big ATI video chip (under the wireless card, under the touchpad) would change the machine's mood from bad to good (or vice versa). There are sites saying motherboard flex is the problem, and the solder balls of the video chip (GPU) are the weak link. There is a service on ebay the repairs the solder balls of ATI GPUs for $50, which I will be trying out. Or check Youtube for how to reflow the solder yourself with a 1500 watt heater and an infrared thermometer.
Aug 11, 2008 | IBM ThinkPad T40 2373 Notebook
T40 2373 ibm fan error
One of three things; 1- when the fan codes on some IBM's, the code locks in the bios, there is a download the has to be ran in order to clear the code and the machine to run properly. Check IBM's support site to see if this is the case for your machine 2- If the machine overheated in the process of the fan going out, then the processor may have been damaged, causing the problem and 3- if there was a malfunction with the motherboard which initially caused the fan to stop working, a new fan won't work either. Test the old fan by hooking power up to it, it is power direct and has two leads positive and negative, when power is applied it will run or not. If it does run then the problem is with the motherboard. Try these and get back to me.
Jul 29, 2008 | IBM ThinkPad T40 2373 Notebook
IBM ThinkPad T40 2373 Notebook Logo
289 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
