Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
Need to reset security codes on rowe 100g series
I have a rowe starlight 100G series. After full initialation it still will not play. What can I do next?
If the selected disc is being delivered to the player, and it spins briefly and then puts the disc back in the magazine, chances are the player is defective. Check that all connectors are tight, if so, you probably need to replace the player. You can send it to AB Jukebox for evaluation and repair, I have sent in several of them and had good results from Bruce at AB. Go to abjukeboxrepair.com for details.
Apr 20, 2013 | Wurlitzer Jukebox CD Player
Need to do a master reset on a nextel motorola i870
Press, in order in a row # * [Menu] and the screen will change from asking the lock code to asking for the security code, which by default is six 0's.
May 28, 2010 | Motorola Mobility i870 Cellular Phone
Nokia 3110c mobile, i forgot security code.now how...
SIM pin code:
This is a pin code that locks the sim card until you enter the correct code. This protects your account, even
if your sim is put into another handset. To reset it, you need the PUK code:
Pin Unlock Code (PUK)
If you miss key (or forget) your SIM pin code, and enter the wrong one 3-5 times in a row, the SIM will lock up, and you’ll need to enter the PUK unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don’t try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled.
Phone Security Code:
This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code code:
Master Reset Code
Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security Code wrongly too many times.
Which is the one that you want?
The default security code for Nokia is 12345
Not sure if this is the right thing...
Mar 02, 2010 | Nokia 3110 Cellular Phone
Have forgot my securitycode for my mobile nokia 3110c
SIM pin code:
Master Reset Code
Hope it helps!
Dec 10, 2009 | Nokia 3110 Cellular Phone
Security code
The default security code for nokia is 12345, if you enter an incorrect security code five times in a row your nokia phone will not accept the correct code for the next five minutes, if you forgot your security code you will have to contact your service provider to see if they can reset your nokia.
Mar 05, 2009 | Nokia 2626 Mobile Phone
How can i change security code which i forgot nokia 3110 classic?
SIM pin code:
Master Reset Code
Apr 23, 2008 | Nokia 3110 Cellular Phone
Security code
SIM pin code:
Master Reset Code
Same problem
SIM pin code:
Master Reset Code
I need the IMEI (International Mobile Equipment Identity) number. Type this code in your phone to get it: *#06# you can also find it beneath the battery.
Then I’ll give you the Master code to reset your Security code.
"Sex is not the answer. Sex is the question. Yes is the answer"
Apr 21, 2008 | Nokia 1600 Cellular Phone
Help me out
SIM pin code:
Master Reset Code
"Atheism is a non-prophet organization."
Apr 21, 2008 | Nokia N70 Cellular Phone
Lock code
SIM Pin Code.
if your sim is put into another handset. ---
To reset this Pin number you need the:
If you miss keyed (or forget) your SIM PIN code, and enter the wrong one 3-5 times in a row, the sim will lock up, and you'll need to enter the unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don't try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled.
This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a "new" sim if the phone security code is entered.
To reset this Security number you need the:
Master Reset Code
For IMEI 356404010441953 this is the Master Code:
3520316615 to use it:
You type in the security codes (any) until the phone request the Master code; when it does, leave your phone still, don't use it for 15 minutes, then type in the Master code.
Mar 25, 2008 | Nokia N73 Cellular Phone
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
46 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
John Robertson
John Robertson
Level 1 Expert
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
