Question about Yamaha YPT400 61 Key Portable Keyboard with Touch Sensitive Keys
How to fix Yamaha PSR 400 dead keys?
I have this old yamaha keyboard that has already dead keys. I am trying to figure out how to fix them. I can't afford to buy a new Yamaha keyboard, so if someone can help me, that would be really great
  • Arnold Aguilar
    Arnold Aguilar Jun 14, 2017
    I had also this kind of problem. I got my psr400 from a junk and i want to revive it. some of the keys are dead and some are on a high volume even when touched lightly, then displays on the screen "batt" and it freezes and there's no sound at all when you touch the keys. Your only option is to turn it off and then on again then when you hit that loud key its the same problem again. I'm planning to open it and clean the contact points myself and see the difference.
    Top Expert:
  • Yamaha Master
  • 3,141 Answers
Normally this would be from dirty or broken key contacts.
Posted on May 16, 2015
robocop
  • 90 Answers
SOURCE: Instruction manual for a Yamaha PSR 195 keyboard.
Try going to http://www.yamaha.co.jp/manual/english/index.php. There, you can try to find your owners manual for free.
Posted on Jan 22, 2009
SOURCE: Yamaha PSR-510 Keyboard
There is no need for a manual. It is so easy to operate because it is designed for easy opeating. If you need a manual to operate the PSR-510 then you really won't be able to operate it even after studying the manual. But here it is just in case you can by some miracle!
http://www2.yamaha.co.jp/manual/pdf/emi/english/port/PSR510E.pdf
Posted on Feb 10, 2009
  • 1138 Answers
SOURCE: Yamaha PSR 75
You have to completely remove the circuit boards. If this is the keyboard I'm thinking of then the keys are all mounted on the same part like parts on the sprue in a model airplane kit. If its a different one then you have to remove the assembly and take the spring of the key you want and at the other end when you flip it over there is a strip glued on the metal frame to secure the keys that you have to peel off for that sector.
Posted on Jul 10, 2009
  • 1126 Answers
SOURCE: Can we connect ipod touch with yamaha psr 2100
http://www.yamaha.com/yamahavgn/Documents/KeyboardsDMI/PSR2100E1.pdf
On page 155 it looks like the only input for device(s) in a 1/4" mono jack for microphone or guitar, not stereo that would be needed for iPod. However, if you could set the iPod to mono output, this 1/4" input would work for you.
Posted on Sep 10, 2009
  • 1121 Answers
SOURCE: 3 keys don't work on my Yamaha PSR-150 keyboard.
yes. you must change keyboard pad, below the keys, and check for dirt and deteriorated board.
Posted on Oct 30, 2009
Yamaha Piaggero NP12 all "A" and "Eflat" keys are dead.
If all A & Eb are dead it would point to either a bad connection between the keyboard circuit and the motherboard ( ribbon cable ) or possible diode problems on the keyboard PCB.
Initially open up and check connections are all tight and correct.
Did this just happen or has the keyboard been opened up?
Nov 27, 2016 | Yamaha Music
Does it have an internal battery?
HQRP AC Adapter / Power Supply for Yamaha PSR ... - Fixya
www.fixya.com/search/...hqrp_ac_adapter_power_supply_yamaha.../60...
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, 600 related issues. ... is there an internal battery to protect memory and if so, do i need to replace it? yes there ...HQRP AC Adapter / Power Supply for Yamaha DGX-620 / DGX620 / DGX- ...
www.fixya.com/...hqrp_ac_adapter_power_supply_yamaha_psr/adapter
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, adapter related ... need a new one, you could try to get a replacement from casio or try to get an ... It MAY appear to operate on DC BUT it can't generate the +/- voltages internally for sound .
Musical Instruments - Keyboard Accessories on Pinterest ...
https://www.pinterest.com/.../musical-instruments-keyboard-accessories/
HQRP AC Adapter / Power Supply compatible with Fulltone CATALYST / CHORALFLANGE Guitar Effects pedals Replacement plus HQRP Coaster by HQRP. $7.91. ... The MS-90 is a column monitor stand that features three internal channels - .... Yamaha SK88 Survival Kit for 88-Key YPG Series Keyboards by Yamaha.
Dec 25, 2015 | HQRP AC Adapter / Power Supply for Yamaha...
Install PSR E413DRIVER
What driver do you want to install?
Jan 14, 2014 | Yamaha PSR-E413 Portable Keyboard
Dead keys yamaha psr e413 keyboard
Dead keys on Yamaha PSR e413 keyboard: Flip keyboard upside down, remove cover screws (use marked cardboard template to remember where they came out), spray suspect key-contacts with fast-drying contact cleaner, (usually a PCB with a matrix of contacts under keys), re-assemble base cover, wiggle faulty keys as far as possible to 'scrub' any dirt or oxidization. If this cleaning trick doesn't work, get a pro to check it.
Dec 08, 2012 | Yamaha PSRE413 Keyboard
I need a replacement board XE771 for my yamaha clavinova cvp-20
406-582-5849 if you want to talk about it. I have one here and I'm repairing it. Maybe if yours has part of the upper surface intact I can figure out how to fix mine from yours and fix yours at the same time and test it here
Apr 28, 2012 | Yamaha Full-Size Keyboard
I own a Yamaha YPT-220 portable keyboard. The "c", "b" and "f" keys (all octaves) just stopped producing a sound. Anyone else have this problem?\r\n The dealer's service...
That's the thing with today's electronic and why warranty length is so important. Where did you buy your keyboard? It's strange that they won't fix it if it's still under warranty. My Casio CTK-2100 came with 1 year free service and they fix one key that stopped function in few days. I'm pretty sure Yamaha has the same warranty length. You sometimes have to be very persistent with them though...
Jul 18, 2011 | Yamaha Full-Size Keyboard
L am looking for PSR 620.yamaha keyboard.it is a musical instrument. l want to get the manual.
http://music.manualsonline.com/manuals/mfg/yamaha/psr620.html there you go please give me some thumbs up!
May 10, 2011 | Yamaha PSRS550B Workstation PSR-S550B...
The keys are broken and some at no sound can I order the notes and sound kit. Yamaha PSR-295 . Regards Elias
Hi, i think you can. You can go to any of the Yamaha companies around you area and explain to them the problem of the keyboard. They will give you good and quality replacement part for your Keyboard.
Make sure you go to only Yamaha company to avoid getting a wrong part for your Keyboard.Avoid road siderepairsforissue like this,it's more complicated to handle
I guess that will do.
Thanks for using fixya...
Jan 12, 2011 | Yamaha PSR-295MS Portable 61-Key...
Do you have yamaha keyboard psr 2000 spare parts?
My keyboard yamaha psr2000,so I want parts silicone rubber keypad 61 and including electronic board,thank you.
Feb 12, 2010 | Yamaha Full-Size Keyboard
Yamaha YPT400 61 Key Portable Keyboard with Touch Sensitive Keys Logo
729 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
