Question about Carrera Mens Swiss Two-tone Stainless Steel 200 Meter Bracelet Watch. Model Cw516.12.8
Carrera model N66501 stainless steel
Strap available
I have a Gant mens chronograph watch s/n 1008 which has a stainless steel bracelet do you know where I can obtain some extra links to make the strap longer
Ask via http://www.gant.com/contact/ you will probably need the watch model name rather than the s/n. It may also help if you give the distance (in millimeters) between the lugs
Feb 01, 2018 | Stainless Watches
Looking for band for invicta sea spider 1261..i want to replace it with a stainless steel band..
Sea Spider 1261 INVICTA Sea Spider Men 50mm Stainless Steel Gold Black dial 3600K Mechanical watch located attached link offers multiple compatible straps
Nov 11, 2017 | Invicta Watches
Where to get a new. Watch strap
You can get Watch strap and everything of watch from The Prime Luxury Boutique. It is an authorized luxury watch retailer. http://theprimewatches.com/
Aug 09, 2014 | Rado Diastar Anatom Jubile watch
Omega 196.0167 cal 1342
The watch part number and a knowledgeable watch maker will provide the correct bracelet. If you WANT a leather strap most models can accept one - unless the case is sculpted to integrate seamlessly with the bracelet, in which case you may not be able to insert the spring bars that are necessary to mount the strap.
Sep 09, 2012 | Omega Watches
Dz4107
Some sprint bars need to be curved, get them in stainless steel.
You need to know the MM size of the spring bar, yu may find that on the strap if its the original strap.
Search for - SWISS REIMAGINED Curved Stainless Steel Spring Bar Pins.
For a box of mixed size straight spring bars look for - Ritche Professional 360pc Watch Band Stainless Steel Link Pins.
Pick up the spring bar tool as well. Amazon sells all of it.
Feb 10, 2018 | Diesel DZ4107 Watch for Men
I own an Invicta Russan Diver Model #4578 and I nee replacement screws for the rubber strap. Do you know where I can find them ?
mcdevito75 here, I would contact shop NBC for info, here is their contact number, 800-474-6762 They should guide you to Invicta parts.
Aug 13, 2010 | Invicta Russian Diver Quinotaur Ccp...
How do I remove pins to size an Invicta Sea Spider model #0140
mcdevito75 here, Aren"t the spring bars (pins) built into Invictas Strap?? Look on the back of the Strap real close to where ot attches to the watch, see a little tab you can move with your fimger, this tab should compress the spring bar (pin) and allow you to remove the strap.
Jul 03, 2010 | Invicta Sea Spider Chronograph...
Carrera Mens Swiss Two-tone Stainless Steel 200 Meter Bracelet Watch. Model Cw516.12.8 Logo
177 people viewed this question
Top Carrera Watches Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Carrera Watch Expert? Answer questions, earn points and help others
