Question about Epson Office Equipment & Supplies
Epson TX810FW fake paper jam
Fake paper jam
doc_delphi
  • 11 Answers
SOURCE: Epson AcuLaser CX11N ADF Paper Jam
I had a very similar problem with the ADF, it resulted in ADF paper jam - message and then in Req Code 2011.
I checked sensors and everything else, then called a epson service professional.
After telling him the Req Code, he knew the problem and said that the problem is the board, which needs to be exchanged, mentioning that this spare part is expensive.
I then checked the whole ADF again, now opening the long grey cover on the backside, I disonnected the connector cable from both sides and - using a multimeter - checked this connector cable for breaks.
Result: the violet cable was broken, so I soldered in a new wire, using the last cm of (old) wire on each side - and now the ADF works fine.
This cable is easy to change if you get the spare part, there is a connector plug on each side, on the ADF side is an additional ground wire (green) fixed with a single screw. Thats it !
For the electronic experts: the configuration of the connector:
sourrounding metal cover = ground, thick green Wire on the ADF side
If you turn the plug that way, that the two single contacts are on top, these are the colours:
1st row: brown - black
2nd row: green - yellow - orange - red
3rd row: grey - violet - blue
Hope this helps
Posted on Sep 17, 2008
  • 10 Answers
SOURCE: epson jammed paper
Check for the compatibility of the paper you're using by visiting www.epson.com and selecting your region. Also, I might add that make sure paper is properly loaded.
Posted on Jan 01, 2009
57 varieties
  • 1653 Answers
SOURCE: EPSON R 300 SAYIN PAPER JAM WHEN NO PAPER JAMMED
Make sure that the paper path is completely clear and clean the paper sensors with a q tip. They get very dusty!
Posted on Aug 29, 2009
SOURCE: epson workforce 600. says it has paper jam but
FIXES FOR EPSON RX600 PAPER JAM
Posted on Jan 18, 2010
marked
  • 6487 Answers
SOURCE: Is the epson tx810fw compatible with windows 7?
Yes this printer is compatible with Windows 7 operating system.
Posted on Apr 06, 2010
Epson xp430 paper jam, but I can't find any jam!
They don't tell lies :>) Even the smallest piece of paper over the sensor will record a jam. This often happens when you have a jam and you pull the paper and it tears a piece off. Open all the doors, remove the paper tray, remove all the toner or cartridges and look with a flashlight. Always pull paper jam paper in the direction it was going, undo tensioner clips if present and pull paper evenly and slowly as not to tear the paper. If you do, keep the paper and find the piece that fits the piece that is missing.
Having said that, see the link
Paper Jam Problems - Epson XP-430 User Manual [Page 234]
https://www.manualslib.com > ... > Epson Manuals > Printer > XP-430 > User manual
Epson XP-430 Manual Online: Paper Jam Problems. If you have problems with paper jams, try these solutions: 1. Cancel the print job from your computer, if...
SOLVED: Error says paper jam, but there is not. What could cause this ...
https://www.ifixit.com/.../Error+says+paper+jam%2C+but+there+is+not.+What+could... Dec 18, 2013 - I have an Epson Artisan 837 all in one. It was working perfectly fine yesterday. Today it is telling me I have a paper jam. I went through the steps ...
How to solve paper jam or paper feed error DO IT YOURSELF ...
? 3:43
https://www.youtube.com/watch?v=kHHpVcSJvvA
Aug 16, 2016 - Uploaded by Easyprint-DZ Support
... of commons problem of printer . paper feed error or paper jam error. ... we gonna work on epson ...
Paper Does Not Feed Correctly - Epson
https://files.support.epson.com/htmldocs/pho22_/pho22_rf/trble_4.htm Paper does not feed. Multiple pages feed. The paper jams. Paper is not ejected fully or is wrinkled. Paper does not feed correctly when using the double-sided ...
Epson XP-430 ' XP Series ' All-In-Ones ' Printers ' Support ' Epson US
https://epson.com/faq/SPT_C11CE59201~faq-293729 Mar 24, 2016 - If paper jams when you load only one or two sheets, try loading more sheets at a time. Do not load more than the recommended number of ...
Epson xp430 paper jam Google Search
Oct 23, 2017 | Epson Office Equipment & Supplies
How to clear a fake paper jam in oki B6250 printer
The usual cause of "fake" paper jams is a prior "real" paper jam. One of two things occurs.
  1. A small bit of paper tears off the jammed stock and hides from view, but keeps the printer jammed. These can be hard to find and remove, depending upon where they are.
  2. In the process of yanking the jammed paper out of the unit, the sensor(s) become damaged or misaligned and give false jam indications. This usually needs repair or replacement.
Jul 30, 2015 | OKI Office Equipment & Supplies
With the espon TX810FW can i print on clear paper / over head projector sheets?please answer quickly it is important
You can get special overhead film for your Epson printer. It is coated for use in your printer, and has a backing sheet so the paper sensor can see that paper is loaded.
Sep 03, 2014 | Office Equipment & Supplies
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Is the epson tx810fw compatible with windows 7? Thanks.
Apr 06, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Epson CX3900 printer indicates paper jam
Check the paper road and paper sensor.Probably have a piece of paper or something else in the printer.
Sep 29, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Aug 29, 2009 | Epson Stylus Photo R300 InkJet Printer
Fake paper jam
I had the very same problem unitl a moment ago!! I found some A4 card and forced it through the printer. I tried to print a document as usual, as the rollers (inside the printer) lifted, i pushed the card through in an attempt to clear any blockage which wasn't visible to me. It cleared the block and is now working perfectly again !! give it a go.
Aug 16, 2007 | Epson Stylus Photo R300 InkJet Printer
134 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
