Question about Toshiba Estudio 166 Digital Copier Machine
I have e.studio 166 photocopier machine, i am facing problem with it that it print half paper and shown paper jam on screen
    New Friend:
C144 codin
Posted on May 02, 2013
Photocopy unable
Sir/ Madam
Hear Is The Soluction which Help You To Fix Your Brother MFC 210C Photo Copy Problem,
Description: Issues with the paper feed could include:
  • Feeding multiple pages.
  • Misfeeds the paper.
  • Printed pages are not stacked neatly.
  • "No Paper Fed" or "Paper Jam" messages appear on the LCD.
To prevent these issues, try the following recommendations:
  1. Verify the paper is loaded properly in the paper tray and the paper support flap is unfolded.
  1. Pull the paper tray out of the machine and remove the output paper tray.
  1. Remove the paper from the paper tray.
  2. Pull the paper support out and unfold the paper support flap.
  1. Fan the stack of paper well to avoid paper jams and misfeeds.
  1. Gently insert the paper into the paper tray print side face down and the leading edge (top of the paper) in first. The paper should be flat in the tray and below the maximum paper mark. Be sure you do not push the paper in too far as it may lift at the end of the tray and cause feed problems.
  1. Press and slide the paper guides on the sides of the paper to fit the paper width.
  1. Clean the paper pick-up roller
    NOTE: Illustrations shown below are from the representative product and may differ from your Brother machine.
    1. Pull the paper tray completely out of the machine.
    2. Unplug the machine from the AC power outlet and remove the Jam Clear Cover (1).
    Note DO NOT place the jam clear cover face down as shown in the illustration. You may damage the cover and cause paper jam.
    1. Clean the Paper Pick-up Roller (1) with isopropyl alcohol on a cotton swab.
    2. Put the Jam Clear Cover back on. Make sure the cover is set properly.
    3. Put the paper tray firmly back in the machine.
    4. Re-connect the power cord.
  2. Verify there is only ONE type of paper loaded in the paper tray.
  3. Make sure that you use paper that meets our specifications.
    To see the detail of the specifications, refer to the User's Guide. The latest User's Guide is available in the Manuals section.
  4. Do not use paper that is damaged, curled, wrinkled, or irregularly shaped.
  5. We recommend using Brother paper to ensure the paper meets the proper specifications.
If your question was not answered, please Tell Us More Information About Your Brother MFC 210C Photo Copy Problem Issue And Errors
Jan 03, 2014 | Brother MFC 210C All-In-One InkJet Printer
I have toshiba e studio 163 spanner key is on, the mashine is not working . How cat I reset the spanner key.
I think the paper has moved half- way and may get jammed. Switch off the printer and try again. Remove if the paper is jammed. Sometimes, the frequent electrical power fluctuations also is a reason for it. I do have this problem in toshiba e studio 166 printer. After sometime, it gets alright by itself. The reason is not exactly known to me. Mostly the problem is coupled with paper jam.
Sep 03, 2013 | Toshiba e-Studio 350 Copier
How to reset error code c21 in the Toshiba e studio 166?
how can to reset error code c21 my toshiba e-studio 166 printer
Feb 28, 2011 | Toshiba e-STUDIO166 Printer
How to remove jam paper from photocopy machine
Hi there remove the front cover & side cover there you can find the jam papers. Just pull the paper & start printing. After that if you face same problem then check the paper trey & then turn off the machine for 5 minute & try. after that let me know the result.
Jan 18, 2011 | Canon imageCLASS D660 All-In-One Laser...
I am having problem in taking printout from TOSHIBA E STUDIO 166
You are trying to print to paper size that is not installed in the machine. Check what paper is installed in the machine then set your software application default paper size to the same value and then print away!
Sep 10, 2009 | Toshiba e-Studio163 Copier
Paper jam on my toshiba 2060 model
Exactly where in the machine does the paper jam??If it jams when you hit the print button, try cleaning the paper feed tires with WD40.spray it on a clean cloth, clean the feed and pickup tires thoroughly and make sure to get ALL of the WD40 off the tires before using the machine.If you take the paper cassette out and look with a flashight you should be able to identify the paper feed tires.
Mar 24, 2009 | Toshiba 2060 Copier
Can't print faxes due to error messages
Please check rear door area for paper, can you use manual feed slot? Power off machine with all jams removed and paper loaded, then power on, can you tell us exact error message/lights that are shown in this state?
Oct 15, 2007 | Brother IntelliFax-2820 Laser Fax
Toshiba Estudio 166 Digital Copier Machine Logo
164 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
